Got the truck tonight. Premimum 2wd edition and thing lays posi pretty easy im surprised. One things for sure IT NEEDS A DROP BAD
Stock front 35.75 ground to fenderlip
Stock rear 38 7/8 ground to fenderlip. Rear needs help bad.
magnaflow cat back and I will be cutting off the 3rd waste of space cat and doing the full 3.5 inch from the y pipe back. I have to see if I can make the y pipe a 3 inch fill unit also since bottom is flattened
Front/rear lowering kit ordered along with the front/rear swaybars from djm
also bought the djm rear hardware kit with bumpstops for free travel mod
oh i forgot AFE INTAKE
whipple 2.9 ordered
parts started coming in
if you need afe intakes just holler can save you over summit or jegs. I will be doing a before/after dyno of the intake also
I got the suspension parts powdercoated.
ok so the outside of the eskys are all led.... except the horrible lights above the license plate
i ended up doing 2 of these
5K WHITE 6 LED HIGH POWER 360° 180LM 194 | 1 EACH - 360 - 194 - 168 - 158 LED - Shop Bulb #
Looks much better
whipple 2.9 ordered
Looks much better
