Page 7 of 8 FirstFirst 12345678 LastLast
Results 91 to 105 of 114
Thread: New 2007 Imperial
  1. #91
    Sandy's Avatar
    Sandy is offline Cadillac Owners Master
    Automobile(s): '93 Cadillac 60 Special; '03 Lincoln TownCar Limited ED
    Oct 2003
    Northern New Jersey
    70
    5,929
    Re: New 2007 Imperial
    He He He, so...you know about the ole blend door, do ya?
    I actually kept my 98 MK8 FIVE years. During that tme, I averaged a
    serious problem every 6 weeks. I kept it that long as I was keeping
    a log of the world's worse luxury car. Everything that could, went
    wrong. It had every option, and was an end-of-the -run "Collector's~Edition" ~~ one of 1265 (I think) it was # 903. Pearl White with tan interior. ONLY reason I bought another Lincoln was the terrific care my dealer took of me, with free loaners of Town Cars, and alot of other perks.
    Now, I've had the TC for 2 years & 9 months, and have yet to have "Problem #1" ~ So, I am happy with it. I think that the T.C. competes with the DeVillle and (2006) DTS at Cadillac, for the same buyer.
    Nice Cutlass, put some red-line tires on her.
  2. #92
    ted tcb's Avatar
    ted tcb is online now Cadillac Owners Connoisseur
    Automobile(s): Previous STS' 1995/97/99/01/03
    Ontario Canada
    1,194
    Actually, since I snapped the Cutlass pics, I've put on some nice whitewalls.
    It made a huge difference in the car's appearance ... I even had it featured in a major Toronto daily paper. There's something to be said for exiting a turn with rwd, top down, and gunning that rocket 350.
    Its the only car I've owned that goes up in value ... I have to get her appraised every 5 years for collector's insurance.
  3. #93
    Jan 2003
    Newtown, PA
    6,472
    Needs RWL tires IMO. I LOVE those old Cutlass's!!
  4. #94
    I~LUV~Caddys8792's Avatar
    I~LUV~Caddys8792 is offline Cadillac Owners 10000+ Posts
    Automobile(s): 1992 Town Car Cartier & 2014 Accord LX MTX
    Roseville, MN.
    34,087
    Quote Originally Posted by Sandy
    I actually kept my 98 MK8 FIVE years. During that tme, I averaged a serious problem every 6 weeks. I kept it that long as I was keeping a log of the world's worse luxury car. Everything that could, went
    wrong. It had every option, and was an end-of-the -run "Collector's~Edition" ~~ one of 1265 (I think) it was # 903. Pearl White with tan interior. .
    How bad was it, what were the major problems? I really love the Mark VIII's and I would love to get one, but I dont wanna buy a car with a lot of problems.
  5. #95
    Sandy's Avatar
    Oct 2003
    Northern New Jersey
    70
    5,929
    1. The HID headlights blow out, because of an ill-installed exterior headlight cover, allowing moisture in along with dampness, that finds its way to the socket . Thusly, they blow. Not bad under OEM warrantee, as I was, but $250.00 apice, afterwards.
    2. The driver's side bucket seat is known to suddenly, without warning, nor provocation, RRRRrrrrip right thru the floor pan, providing the driver with "instant recliner" option. It order to repair, the car goes on lift, and needs steel plates welded BOTH to the underside of the chassis AND under the carpet, on the inside, because the bolt causes the floor pan to "mushroom".
    3. The LED crystal in the wall to wall taillamps goes limpy (light-to dark-to normal-to light- to dark) sections. EXPENSIVE !
    4. AM Radio has incurable terribble horrible constant static. Useless.
    5. Actually eats up brake rotors every 3,000 miles. I had 18,000 miles when I sold it @ 5 years of age and was on set # 6 of front brake rotors.
    6. Steering Wheel ShAkE ! Going down looong hills, and using the required braking, - about 1/2 down steering wheel begin JuMpInG all over the place, with Parkinson's decease.
    7. Rear Window. The rear window has an exterior moulding (black) that goes 360 degrees, all around the perimeter of the glass. After 3-4 years in the sunshine, the cold and the climaticx changes, said moulding get lumpy wavey l
    un un nu and it cannot be replaced use the electric rear window defroster glass window is also replaced $ 1,200.00 for a nice new moulding.
    8. Then, there's the old blend door on the Air Conditioning. Of the 5 summers I had the car, 4 of them it suddenly began blowing heat on me in July / August. Under warrantee the first 3 years, it cost me $ 1,000 to "fix" the 4th year.
    9. Fuel Release button on driver's side lower door panel (you push it & the fuel door releases) but.... push just slightly TOO hard and the little button falls down doen down into the lower door panel. Removing door panel is then necessary to re-fuel.
    10. Ash Tray. I don't smoke in any car, ever, but I did fill it with hard candy for "dry mouth" syndrome. You push a spot on the top cover door and she 1st dips downward, and then opens up. EXCEPT for when she slightly dips downward and the thin plastic mechanism breaks, the the ash tray cover falls down INTO the compartment. The Fix? An entire new center console ($1,475.00), as it's NON-fixable, but you will get a new one WITH the new console.
    Other than that, they are fine
  6. #96
    Roseville, MN.
    34,087
    Goddamn Fords!
  7. #97
    Sandy's Avatar
    Oct 2003
    Northern New Jersey
    70
    5,929
    You asked!
    Sorry about the many typos, but the telephone has been ringing every 10 minutes tonight.....I do NOT miss my Mark 8 even one little bit
  8. #98
    Roseville, MN.
    34,087
    Well im not gonna think of all Mark VIII's as a "stinking pile of dogshit" but I will take your advice into consideration...I'm positive there are many Mark VIII owners out there that are ecstatic with their cars, and have never had a bad experience with them, but I think you are just unlucky with yours. Like my deVille leaks coolant through the block, now I know that this was caused due to neglect of the previous owners, and I dont think all 4.9's will leak coolant, its just something to keep in mind
  9. #99
    Lord Cadillac is offline Cadillac Maniac
    Automobile(s): Cadillac Escalade
    Dec 2002
    Royal Palm Beach, Florida
    13,703
    You asked!
    Not to change the subject, but holy crap am I glad I chose the Eldorado Touring Coupe over the Mark VIII!
    Have an iPhone or Android? Then you can be connected with everything automotive in your area.
    Download the Cars Connected app for your iPhone or Android device today! Or you can check out Cadillac Magazine and Kia Stinger Forum.
  10. #100
    ReagansRollsRoyce is offline Cadillac Owners Fanatic
    Automobile(s): 1987 Cadillac Fleetwood Brougham
    Connecticut
    183
    NOTE THE SIDE SCULPTURE LINE ON THE REAR QUARTER PANEL, THE DIP ON THE REAR DOOR,
    AND HOW IT MEETS THE HORIZONTAL LOWER SCULPTURE. IT'S QUITE PRONOUNCED ON THE DOOR.
    Hmm. I would rank it above Art & Science Cadillac but for a new car today I'd still buy either the Lincoln Town Car L (if that's still made since it's the only properly long car out there) or the Jag XJ8 for classic appearance.
    I do think it looks awfully short and psuedo-Rolls.
    I ditto whoever said above that they wished GM had Chrysler's balls though.
  11. #101
    Jan 2003
    Newtown, PA
    6,472
    My son had a MKVIII and the car was actually very reliable. Sandy, your list DID ring a few bells but, after knowing several Lincoln/Cadillac owners, I can tell you that the grass IS NOT greener on either side. For every sad story from a MKVIII owner, there's one from a Seville/Eldo owner. IMO, overall, those cars are close to even as far as headaches and heartburn inducing problems but at least the MKVIII has that wonderful engine! Styling is subjective of course but for my money, I like the looks of the MKVIII better than a Seville/Eldo.
  12. #102
    Mar 2004
    1,063
    Parts of the car work, just not together. Anybody that thinks that brown lump of llama shit looks better than a newer Caddy, probably likes Rossane better than Jennifer Love Hewitt!
  13. #103
    Mar 2004
    1,063
    That in stock form gets a beating from the ETC/STS!
    The Ford engine used in Lincolns is easy to mod though, just like the Chevy engine in your Cadillac. Most people with these cars don't mod them, but for those that do, having a less unique engine pays off.
  14. #104
    ted tcb's Avatar
    Ontario Canada
    1,194
    Sandy, count yourself lucky with your MkVIII ownership.
    What, no tranny or air suspension woes?
    I always felt my 89 LSC looked far tougher than the next generation marks, which definitely had a more feminine look.
    I guess a used Eldorado makes more sense from a mechanical perspective.
  15. #105
    Roseville, MN.
    34,087
    I think you can put the springs or coils from the Thunderbirds onto the Mark VIII's
