Page 4 of 5 FirstFirst 12345 LastLast
Results 46 to 60 of 72
Thread: How to clean the EGR valve - different year Northstars
    Eldyfig's Avatar
    Eldyfig is offline Cadillac Owners Connoisseur
    Automobile(s): 13 Challenger RT, 11 CTS Coupe Premium, 94 Eldorado (RIP)
    Jan 2003
    Folkston, GA
    1,306
    Re: How To Clean The EGR Valve
    When I took my egr out to clean it, I didn't use a new gasket. Never had a problem with it.
    Talamant3z's Avatar
    Talamant3z is offline Cadillac Owners Enthusiast
    Automobile(s): 1997 Eldorado
    637
    how do you clean one from a 97 eldroado i got one bolt off but the other is under the fuel line which i cant get off
    82,281
    You have to lift the fuel rail.
    Seville44 is offline Cadillac Owners Member
    Oct 2007
    Sorry, I can't tell by the last picture, where exactly do you spray the carb cleaner? everywhere but inside the allen ekey looking hole?
    diablo69 is offline Cadillac Owners Member
    Automobile(s): 1996 STS
    Dec 2009
    Is there anything called a "PVR" valve? Someone told me that was my problem but it was probably the EGR valve he was thinking of. Suggestions"
    82,281
    No such thing.
    Krashed989's Avatar
    Krashed989 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 Eldorado, and a 99 ETC
    Sep 2004
    Hilo, Hawaii
    3,887
    Quote Originally Posted by Seville44 View Post
    You can spray it in there just as long as you're careful not to get it into the big canister portion of the valve. The carb cleaner will eat away at the insulation on the electrical windings of the valve if it does go in that area.
    NeMiZiS is offline Cadillac Owners Member
    Automobile(s): 1995 Cadillac Seville STS
    Jul 2009
    Nice write up!
    Frep85 is offline Cadillac Owners Member
    Automobile(s): Seville STS 1994
    Jun 2010
    I just followed the instructions and cleaned out the EGR-valve. Replaced air filter as well. The car runs perfect without the jerky rpm at low speed. But here's a problem: the cruise control as well as the left power window on the backdoor stopped working.
    Does anyone know why? I know this is a pretty common problem but I really don't want my top condition Cadillac suffer from this
    Great thread! I just cleaned my EGR and it did the trick. Biggest problem I had was that the last person to replace/clean the valve didn't put the brace for the fuel rail back on correctly, so it (the brace) was over the nut. I had to pry the fuel rail over with a screwdriver with one hand and remove the bolt with the other. That was sorta scary because I didn't want to kink up the fuel rail, but it was fine. I figured the guy who did the last job couldn't find the hole. I never have that problem.
    Bigjack21000 is offline Cadillac Owners Member
    Automobile(s): Seville 1988 and 1990
    46
    13
    Thank you for the pictures!
    farmerjohn is offline Cadillac Owners Member
    Automobile(s): Eldorado ETC 1995, SRX V8 2005
    Feb 2011
    52
    Great tips here.
    But I wonder about the pintle. My Chilton repair book says the pintel should be cleaned. They have a picture on page 4-7 that shows the assembly of the EGR valve. It looks like the hole you are not spraying solvent in has a screw that allows to take the EGR valve apart.
    Is it possible to get it back in correct function if I take it apart? I'm especially worried about the spring tension.
    Electric cleaner should not dissolve the insulation, but clean out the dirt. Do you think that would lessen the risk of ruining the mechanism if it came into the hole beneath the valve?
    82,281
    I spray it in the opening under the "can" where you can see the pintle valve and use a dental pick to scrape the carbon loose. Tedious and time consuming, but with the right tool you can do a good job.
    Jan 2006
    105
    I tried to get the EGR out on my 95 STS and the steel fuel line is in the way and won't budge! What do I have to do to get the fuel rail out of the way. Looks like the factory upgrade was done.
    82,281
    You need to separate the rail from the supply line and then remove the hold downs. Then lift the rail and injectors out.
