Results 16 to 30 of 62
Thread: 2003 STS - Rough idle and hesitation on takeoff
    Re: 2003 STS - Rough idle and hesitation on takeoff
    Put the car up on a lift, let it cool down, grab the heat shield (to preclude that possible rattle) and judiciously thump the converter end pipes with a rubber mallet - Rattles ?
    Time to look at www.easterncatalytic.com and find one of their direct replacement units. Probably from RockAuto.
    The OP never complained of poor acceleration or road performance - a misfire/poor idle characteristic, hesitation, and a rattle.
    Adamhon is offline Cadillac Owners Member
    Automobile(s): 2003 Cadillac STS
    Indiana
    I have clamped the heat shield so I know it is not that. I asked about the cat in my first post because that was my thought but I thought Ranger said the cat would not do that in one the the first posts. I will have to try to get some money together for one. Thanks everyone.
    82,278
    Quote Originally Posted by Adamhon View Post
    Post #5
    You will not get a DTC for a dirty TB, but it can be the cause of a rough idle.
    That said, it sounds like your CAT is on it's way out.
    Based on your DTC's, I'd start by replacing the MAF sensor.
    No
    Indiana
    That no at the bottom of that post was after you quoted my question of if my cat would cause the problem. It doesn't matter though, I just misunderstood. Thanks for the help.
    Indiana
    Ok, I went to the muffler shop today to have them put on the Eastern catalytic converter I bought, he told me the cat is bad because of the rattling but it is not what is causing the miss (rough idle) and if he puts on the cat it will go bad without finding and fixing the problem of the miss. I reset the SES light about 2 weeks ago and the light has not come back on. I don't know where to go from here other than to take it to a garage, any other ideas?
    Again it seems to run fine other than in idle when it runs rough and has a slight hesitation when you first push the gas but clears up immediately. My gas milage is down quite a bit as well, my car says 10 mpg in town when I typically would be around 14.
    kaceyseldo's Avatar
    kaceyseldo is offline Cadillac Owners Fanatic
    Automobile(s): 97 eldorado
    Nov 2013
    398
    I know I said this already, but I had a 99 Deville that went through 2 cats before someone told me to change the bank 2 02 sensor. It went back to running perfect.
    Indiana
    Kaceyseldo, Did it set off a code?
    kaceyseldo's Avatar
    Nov 2013
    398
    I didn't know how to check codes then. I just felt serious hesitation on cold start up and I took it up to a buddy who said it was the cat. Two replacements later, an ase mech straightened me out.
    2kflhr's Avatar
    2kflhr is offline Cadillac Owners Enthusiast
    Automobile(s): '10 Escalade, '97 Eldo ETC (Z)
    Mooresville, NC
    905
    Have you checked the plug wires? The insulation on plug wires breaking down can do mysterious things at idle and even at WOT.
    2kflhr ................Adamhon drives a 2003 STS ........
    2000 and later have no plug wires. It's coil-on-plug: 8 coils in 2 cassettes with short connector boots for each coil-plug. Waste spark disappeared at the end of the 1999 run, and a slew of engine changes came in - mechanical, electrical, electronic. Different engine. Look in my albums - 6 pages of later Northstar stuff.
    98eldo32v's Avatar
    98eldo32v is offline Cadillac Owners Connoisseur
    Automobile(s): 98 eldo/KD54 w/N37,T96,QA1,D55,DS3,U1Z. U3R next
    51
    2,125
    If you haven't changed spark plugs, boots and springs do so.
    I would also check fuel pressure......
    Indiana
    Ok, I am getting some codes again:
    P0300 random misfire
    P0507 high idle
    I changed the sparkplugs (I used the original spec AC Delcos) and liked at the boots and springs, they looked fine.
    98eldo32v's Avatar
    51
    2,125
    Check fuel pressure.........
    vincentm's Avatar
    Kennewick WA
    4,848
    Have the codes pulled by an auto shop to pin point which exact cylinder is misfiring and replace the coil to it. You should get a P0301, 2, 3 etc..
    Indiana
    I just noticed today (my wife usually drives this car) that the miss doesn't start until the car is warmed up.
