Page 3 of 7 FirstFirst 1234567 LastLast
Results 31 to 45 of 92
Thread: MY ATS LED Conversion obsession
    Kalibr's Avatar
    Kalibr is offline Cadillac Owners Member
    Automobile(s): 2016 Cadillac CTS 2.0T Luxury
    Sep 2006
    West Palm Beach, FL
    72
    Re: MY ATS LED Conversion obsession
    Quote Originally Posted by vwall View Post
    Has anyone switched the trunk bulb to LEDs? How do you get in there to remove the bulb?
    Yes. It's pretty straightforward. The bulb housing slides out by prying from the right side with a flathead screwdriver. It uses a 194 T10 type bulb. I used a 4 SMD Canbus as in pic.
    matthewmugar is offline Cadillac Owners Member
    Automobile(s): ATS Luxury 2.0 Turbo
    Aug 2013
    Quote Originally Posted by Stevo Supremo View Post
    I'm honestly still having trouble here with those looks. how "flush" are those lamps with the bumper? Do they stick out any from the bumper?
    Stevo, the LED's are almost flush. I have been having the same thoughts and am planning to cut the molding a bit so i can push it through so its completely flush against the grill. It's about 3/4 inch on top of the original housing. I am planning to call dealership to find where i can find replacement moldings in case the cutting doesnt work, I will be ok without the led's if need be...as long as i have the HID's i am good. I got new rims the 18" upgrades and they are awesome...so content either way.ats rims 2.jpg
    pissedoffwookiee's Avatar
    pissedoffwookiee is online now Cadillac Owners Connoisseur
    Automobile(s): '16 CTS V-Sport Black/'16 CTS Luxury w/V-Sport Pkg White
    Carlsbad, CA
    4,145
    got mine a couple days ago the mounting studs have flange that prevents a full flush mounting, I plan on drilling out so as to achieve a more pulled in look I also plan to mount against the inside edge of the brake duct instead of the outside. I want the upturned part to point at/line up with my soon to be non amber turn signal and also the inner part of the duct is deeper
    vwall is offline Cadillac Owners Member
    Automobile(s): 2013 Cadillac ATS 3.6L V6 Premium - Opulent Blue
    AR
    11
    Quote Originally Posted by Kalibr
    <img src="http://www.cadillacforums.com/forums/attachment.php?attachmentid=140530"/>
    Thanks a lot. On another note, can someone tell me how to get to the map lights so I can change them to LEDs? I'm not sure how to pry open the plastic console.
    Carlsbad, CA
    4,145
    get your fingers under the whole upper console and tug firmly it's held up with clips, probably easiest starting at a corner
    ok found found a hyper flash fix cable and bought it night before last, then found a mounting plate for the resistor. so now will be fully ready for those LEDs going to try the plug and play cable first if doesn't work I'll splice in the resistors. actually more accurately my mechanic friend and I will not comfortable doing this without a babysitter.... lol besides it seems to me doing this on his lift beats wear and tear on my ass and knees (let the jokes begin)
    Kalibr's Avatar
    Sep 2006
    West Palm Beach, FL
    72
    Vwall, in order to access the map bulbs, you need to remove the entire plastic panel that houses the two map lights, On-Star, Homelink and sunroof controls. I recommend using a plastic tool to pry the panel away from the headliner just enough to fit your fingers and complete the removal. The panel is held in place by metal clips so it takes a bit of force to remove. Keep in mind that the panel will be connected by wires, so be careful not to pull any of them loose.
    mechevar is offline Cadillac Owners Fanatic
    Automobile(s): ATS 2.0T RWD
    105
    You know..you can almost recreate the stock look if you can get a small led to fit vertically alongside the stock lamp cover. Don't know if there is anything close, but thats any easy way to get the lights flush.
    http://www.ebay.com/itm/2013-2014-13...0ae434&vxp=mtr
    Dec 2011
    82
    Quote Originally Posted by matthewmugar View Post
    (I am 34, married no kids yet)
    Me too bro, keep living the dream!
    105
    Looks like D3 has plans to address to this very thread!
    http://www.cadillacforums.com/forums...oad-sport.html
    Carlsbad, CA
    4,145
    OK here's mine, i had it installed using a vibration activated DRL relay, this is what it looks like when i use the remote start
    105
    No go on the private video?
    Carlsbad, CA
    4,145
    Quote Originally Posted by mechevar View Post
    sorry fixed
    5.0 lsc's Avatar
    5.0 lsc is offline Cadillac Owners Fanatic
    Automobile(s): 2013 XTS Premium
    Philadelphia
    214
    Hey not to hijack, but I have an xts and I installed the can bus proof LEDs in my reverse lights, and now after the car is locked the handles, reverse lights, and cue buttons stay on dim. I'm guessing you didn't run into this problem at all?
    malaka1 is offline Cadillac Owners Member
    Automobile(s): 2013 Cadillac ATS 2.0T 6 speed manual
    Jul 2013
    Quote Originally Posted by pissedoffwookiee View Post
    I like! Where did you buy those?
    Carlsbad, CA
    4,145
    Quote Originally Posted by malaka1 View Post
    the lights were from ebay, they're the mustang DRL that several others here including the OP installed, i think the link is at the beginning of this thread, and the relay is from ijdmtoy.com. My mechanic and i had to do some filing and grinding to get them to sit flush, wasn't difficult, but if i had to do it again i would just get the these or these for an easier install.
