Results 61 to 75 of 97
Thread: Troubles with the 77 CDV
  1. #61
    Bro-Ham's Avatar
    Bro-Ham is offline Cadillac Owners Connoisseur
    Automobile(s): 1979 Sedan deVille d'Elegance
    Oct 2005
    Sarasota, FL
    4,152
    My fingers AND toes and arms and legs are all crossed for you Craig!
  2. #62
    77CDV's Avatar
    77CDV is offline Cadillac Owners 10000+ Posts
    Automobile(s): 77 CDV, 06 DTS III, 69 FWB
    Newbury Park, CA
    10,022
    Re: Troubles with the 77 CDV
    Quote Originally Posted by Bro-Ham View Post
    Sounds like you won't be going anywhere fast with all that!
    Thanks, Dave.
  3. #63
    The Ape Man's Avatar
    The Ape Man is offline Cadillac Owners Connoisseur
    Automobile(s): '80 Fleetwood Coupe, 1994 and 1995 Mercedes 140 Coupe
    Feb 2005
    Southern NJ
    54
    2,096
    The problem with having a shop diagnose this is they need to make a profit for their time. Your problem is not constant and requires a warm-up and test drive.
    I hope they finally get it.
    Best of luck.
  4. #64
    CadillacLuke24's Avatar
    CadillacLuke24 is offline Cadillac Owners Master
    Automobile(s): Alexandra - 96 SDV --- Clyde - 15 Silverado
    Wyoming
    5,748
    Good luck!
  5. #65
    Koooop's Avatar
    Koooop is offline Cadillac Owners Master
    Automobile(s): 300 SRT8, 392 cubic inches of tire smoking power!
    So Cal
    53
    8,189
    Baffling issue. I have one of those in my old vette, I'm down to it being a fuel system issue. At least I hope it's a fuel feed issue .
    I've driven 425's Hundreds of thousands of miles, never experienced this.
    On another note, I never saw 18. MPG either not even downhill with a tailwind. 18? Someone is feeding exhaust into the interior.
  6. #66
    Feb 2005
    Southern NJ
    54
    2,096
    First mistake is disconnecting the EGR valve. It needs to work for max fuel economy. Sorry so many of you guys belong to the friends of OPEC club.
  7. #67
    My money is on the egr or cat also. Maybe get it to repeat the problem and take the temp before and after the cat. I'd also do the vacuum test to test the egr valve also. The egr feeds right off the cat converter, right? Does it hesitate a little off the line?
  8. #68
    Koooop's Avatar
    So Cal
    53
    8,189
    Come to think of it, I did have somebody put a plug in place of the EGR in an LT1. That caused a similar issue. That's easy to test, Just pull the EGR off the valve cover and take it for a ride. Cover it or you will have a big Oily mess on your hands.
    Once I drove the LT1 with that issue for a while, the vacuum pressure buildup inside the motor made it buck, cough and stall but it took 20 minutes or so. It was over pressurizing the crankcase.
    I do recall having some bizarre EGR problems with some of my 1977 sedan Deville's. the giant poof of blue smoke going up a steep hill every now and again was a real stumper to figure out.
  9. #69
    Feb 2005
    Southern NJ
    54
    2,096
    It isn't the EGR in this case. He already went down that road. I mentioned that only for the fuel economy scoffers.
    Hey did you guys see my fly by while you were stopped at the gas station?
  10. #70
    akimball442's Avatar
    akimball442 is offline Cadillac Owners Fanatic
    Automobile(s): '81 CDV, '64 SDV, '73 MB 450SL
    Sep 2005
    upstate ny
    218
    Quote Originally Posted by The Ape Man View Post
    ... no..... EGR actually measurably reduces fuel economy, on all older engines. It's particularly obnoxious in diesel engines, but certainly doesn't do anything for performance or fuel economy in a gasoline engine.
    EGR is particularly evil on older high mileage engines because of the amount of carbon deposits it forms, eventually negating its own purpose because carbon deposits in the combustion chamber cause the pre-ignition condition (say that 3 times fast) that results in excessive NOx emissions to begin with.
    Now if everything on the engine was new- that would be a different story. It still would likely not cause a major increase in mileage, but it would definitely not cause as big of a decrease as a malfunctioning system. PS. most EGR systems are not operating optimally on 30+ year old engines. There are exceptions, of course. But I just replaced an EGR valve on a 22K mile 368 that was leaking.
    The systems used today are significantly better with electronic controls, but the standard vacuum operated EGR valve on pre-computer cars ONLY helps reduce NOx emissions (which is a good thing, don't get me wrong), and does so at the expense of performance and fuel consumption.
  11. #71
    So was the egr valve replaced or tested with a vacuum guage? Can you get a temp gauge on the exhaust? Any original rubber gas lines in the system that may be collapsing when it warms up? Just thinking out loud.
  12. #72
    Bro-Ham's Avatar
    Oct 2005
    Sarasota, FL
    4,152
    I grew up with 77 and 78 deVilles from new, they were 15 MPG max cars even then, I chuckle when I remember my Dad always madly calculating mileage during the gas crisis in 79 so we could make it between rationed fuel ups.
  13. #73
    Feb 2005
    Southern NJ
    54
    2,096
    Quote Originally Posted by akimball442 View Post
    EGR is part of the fuel system and spark timing calibration. If it is removed the calibration must be maximized. Your theory may be correct but practice requires more than plugging a vacuum line.
    I speak in terms on old Cadillac manufacture engines. Old Cadillac engines do not have issues with carbon deposits in the combustion chambers. The entire innards of most of these engines are usually remarkably clean except intake valve stems which need periodic decarbonization. This holds true for old high mileage engines also. The usual death of a factory 368/425/472/500 is from main bearing slop resulting in low oil pressure to rod bearings.
  14. #74
    deVille33 is offline Cadillac Owners Connoisseur
    Automobile(s): 1977 Coupe (blue), 1977 Coupe (yellow), 1977 Coupe (green)
    Western Massachusetts
    1,493
    I grew up with 77 and 78 deVilles from new, they were 15 MPG max cars even then, I chuckle when I remember my Dad always madly mileage during the gas crisis in 79 so we could make it between rationed fuel ups.
    I don't want to burst your bubble of observation here, BUT, one of my '77 CDV's got 16.5 mpg on the average and our venerable Bruce Roe has tweaked his efi '79 close to 20. 15 may be common, but it is possible to tweak more out of the beasts.
  15. #75
    Koooop's Avatar
    So Cal
    53
    8,189
    It seems silly to try to get good MPG out of a big block.
