Results 46 to 60 of 97
Thread: Troubles with the 77 CDV
    jeff_herry is offline Cadillac Owners Member
    Automobile(s): 1978 EFI fleetwood brougahm d'elegance
    Oct 2012
    Angouleme / france
    46
    Re: Troubles with the 77 CDV
    Hello 77CDV,
    sorry to see that you got in trouble with your cad. I hade the same issue than you with my 77 fleetwood 4 years ago, and more recently with my 78 fleetwood fuel injection. Exactlty the same things: good idling, and bucking at high speed. With my 77 carb, there were no evidence of backfiring. just a gazoline smell int he exhaust system, just like the engine was running a little bit too rich. With my fuel injected 78, I had lots of bacfiring. I solve the problem when I replaced the vacuum timing advance on the distributor, and the pickup coil. Have you check these part? of course you need to open the distributor, and remove quite everything inside to get the pickup coil and the timing advance system. I have the shop manual, so if you need any other info, just let me know !
    Good luck. Jeff.
    Garys's Avatar
    Garys is offline Cadillac Owners Fanatic
    Automobile(s): 1968 CDV / 1970 FWB /1979 FWB / 1995 Eldo
    San Diego
    228
    Quote Originally Posted by The Ape Man View Post
    Guess some of you guys would have a stroke if you saw the mileage I got from my 1980 Fleetwood when it was all factory eqipped. Not to worry. I've dropped in a 500 now and am way down to 15 MPG mostly highway, 70 MPH.
    Maybe not a stroke, but I would go ape man!
    The Ape Man's Avatar
    The Ape Man is offline Cadillac Owners Connoisseur
    Automobile(s): '80 Fleetwood Coupe, 1994 and 1995 Mercedes 140 Coupe
    Feb 2005
    Southern NJ
    54
    2,096
    Quote Originally Posted by Garys View Post
    The FCC made me the Ape Man.
    Bro-Ham's Avatar
    Bro-Ham is offline Cadillac Owners Connoisseur
    Automobile(s): 1979 Sedan deVille d'Elegance
    Oct 2005
    Sarasota, FL
    4,152
    If they made you that way in the 70's I bet it is a CB handle!
    talismandave's Avatar
    talismandave is offline Cadillac Owners Master
    Automobile(s): 1980 Eldorado, 1974 Talisman, 2004 Volvo C70,
    Madison WI
    7,894
    Quote Originally Posted by Bro-Ham View Post
    KXW 3878 mobile here, "The Shenandoah", ya got your ears on!
    Bro-Ham's Avatar
    Oct 2005
    Sarasota, FL
    4,152
    Quote Originally Posted by talismandave View Post
    21-50, by
    Madison WI
    7,894
    I can't remember what I walked into the bedroom for, but my FCC number I haven't used in 40 years, that I remember!
    Feb 2005
    Southern NJ
    54
    2,096
    Nah it was a ham callsign. Sri fer hijack.
    77CDV's Avatar
    77CDV is offline Cadillac Owners 10000+ Posts
    Automobile(s): 77 CDV, 06 DTS III, 69 FWB
    Newbury Park, CA
    10,022
    Sadly, your prediction is correct. Test drove the car last night. Got about 15 miles on the freeway when the symptoms reappeared. Got off ASAP and headed home on surface roads. The car could barely maintain 30 and stalled out completely a dozen times. I barely managed to limp her home and at this point, she's basically undriveable. I'll have to have her towed in Wednesday. The saga continues.
    If the carbonator was not getting a good power source from the oil pressure switch the car would have hung up on high idle and the gas mileage would have been very poor.
    The diverter valve being bad would cause exhaust pops under high vacuum deceleration.
    Vac advance not working would make the car idle smoother and really lousy fuel economy.
    None of these things would cause the car to do what you described.
    I'd be real careful before doing any long trips.
    Just put 500 miles on my own car with a 1975 drivetrain last week. I'm a fellow who likes to weigh risk too : )
    Bro-Ham's Avatar
    Oct 2005
    Sarasota, FL
    4,152
    This seems so uncharacteristic of a 425 Cadillac, I hope it turns out to be something severely simple! My thoughts and prayers are with you for quick resolution of this madness!
    Feb 2005
    Southern NJ
    54
    2,096
    Sorry it isn't fixed but at least you didn't get stuck in da 'hood.
    I remember you said there's a booster fuel pump somewhere. If the car is still also using the factory mechanical pump take a look at the 2nd line in post #10.
    The pump has a pressure release valve that's suppose to circulate fuel back to the tank. Keeping the fuel circulated helps with vapor lock.
    Sometimes these valves get gunked up or just plain don't hold pressure. When that happens the carbonator only gets enough fuel to keep the car moving at slow speeds. Usually a cold restart allows almost normal pressure.
    Easily the worst pre-computer Cadillac problem to diagnose I've run into in 34 years. My car had an almost new fuel pump when this happened to me.
    Pinching off the smaller return line with needle nose vice grips with a couple of fuel lines slid on their teeth is a quick way to check. Watch out for steering linkage clearance if you try this.
    If this IS your problem I'm really sorry I didn't take the time to describe it in detail earlier.
    Been there in 1983 or so.
    Bro-Ham's Avatar
    Oct 2005
    Sarasota, FL
    4,152
    Ape is the greatest! Craig, I hope this helps you get your car fixed! Now, Ape, when are you going to reveal all the secrets to having a trouble free 81 Cad with V8-6-4?
    Feb 2005
    Southern NJ
    54
    2,096
    There's nothing in an 8/6/4 that wasn't in later DEFI cars which were regarded well except the modulated displacement itself which was extremely reliable.
    Cut the 3rd gear pressure switch wire and poof, no more modulated displacement. It didn't save much gas anyway.
    The V6 mode vibrated and made these cars feel like something one would want to trade in. Another annoyance was the idle speed motor could make drivers feel like the car was controlling them. Imagine waiting to pull out into traffic with just enough brake pedal pressure to hold the car. The AC compressor kicks in, the idle motor tries to compensate for the load and the idle increases 125 RPM. Now the car seems to lurch forward....................
    Probably best for a seperate thread.
    CADforce69 is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac Sedan de Ville 1969, Dodge 3700GT '73, Audi A3 1.8T
    Madrid (Spain)
    1,634
    Sorry to know the problem is not solved yet but I hope you get it solved soon with this good info, Craig.
    77CDV's Avatar
    Newbury Park, CA
    10,022
    Back in the shop today. We'll see what happens. Fingers crossed here.
