Results 31 to 45 of 48
Thread: 99 STS - where is my brake fluid reservoir ?
    Ranger is online now Cadillac Owners Member
    82,275
    Re: 99 STS - where is my brake fluid reservoir ?
    Curiously enough, brake fluid "moves" throughout the system, not simply back and forth in the lines during brake application/release. It's a hydraulic system phenomenon, but the actual movement and migration is real and it happens.
    That doesn't make sense to me, but if that's the case, then I stand corrected.
    JimD is offline Cadillac Owners Connoisseur
    Automobile(s): '98 STS (RIP @ 206,xxx miles)
    Metro ATL
    4,854
    The process is known as diffusion which is the mixing effect resulting from molecular activity/motion.
    To demonstrate, gently place 20 drops of food coloring on top of 6 ounces of water in a clear container. Do not shake or stir or apply any external pressure.
    Leave the container undisturbed for an hour and observe what has color change takes place in the fluid. What happened to the 20 drops of food coloring?
    The only reason to stir cream/milk into coffee or water into Scotch is to speed up the mixing process.
    Quote Originally Posted by jaybee86
    Thanks for the help guys I've found new mc for 75 and 200 for calipers all around what else would I have to do
    All of the brake hoses, and the EBTCM.
    basscatt's Avatar
    basscatt is online now Cadillac Owners 10000+ Posts
    15,696
    Quote Originally Posted by jaybee86 View Post
    call a tow truck - and have it hauled away -
    you are making a DEADLY mistake -
    jaybee86 is offline Cadillac Owners Member
    Automobile(s): 99 sts pearl
    baltimore,md
    I'm going to replace it this week can get parts new thru a friend who gets retarded prices so if I replace with new parts
    It will be fine
    vincentm's Avatar
    Kennewick WA
    4,848
    This thread reeks of epic, and i mean epic...failure..
    82,275
    So new master cylinder, EBTCM & 4 calipers. Cha-ching $$$$$$$$$$$$$$$$$$$$$$$$$
    baltimore,md
    Mc for $75 and 4 calipers from my friend who has same car but his died blown gasket so he can just give them to me for freer and his had 89,000 miles on it don't mind buyin the nc and hoses and ebtcm I can get from him too and I have sumone to do work for me cause they owe just need to kno if that will remedy the problem don't have money to get rid of n start over
    basscatt's Avatar
    15,696
    NO
    and PLEASE don't take this the wrong way -
    YOU ARE BEING AN IDIOT -
    and for what? - a couple LOUSY DOLLARS -
    Drain the system, replace the MC, EBTCM, hoses and calipers, then THOROUGHLY flush the lines.
    The system might be able to be recovered BUT it will take a good mechanic, dedication, time, and a LOT of DOT 3 brake fluid with a pressure fluid bleed machine. As posted, every piece of the system with any rubber/synthetic rubber must be replaced. Personally, I would disconnect, isolate and flush out every brake line (the steel ones) before installing any new part.
    My advice on the GOOD mechanic: This exercise is NOT something for a novice to learn on - this is expert car repair. No bones about it.
    baltimore,md
    Ok so I got hooked up wit a great Cadillac mechanic and he saw the bottle and took 2 hrs to look at the brake system and he said it was messing up the master but we caught in time where we can recover now my question is he said the master I need cost 286 but I don't have heavy duty brakes can't I get one the is a direct replacement fit for car it only cost 125?
    EcSTSatic's Avatar
    EcSTSatic is offline Cadillac Owners Master
    Automobile(s): 1999 STS - diamond white
    Wichita, KS
    5,212
    $125 is likely. try rockauto, they range from $45 - $200 for a new one. Don't buy re-manufactured.
    baltimore,md
    Well my bro paid for it anyway so ac delco it will be thanks for the help guys now in a couple more hours it will be done
    EcSTSatic's Avatar
    Wichita, KS
    5,212
    I would have gone with ACDelco too, but they are much cheaper at RA if you can wait a few days.
