Results 16 to 25 of 25
Thread: K&N Air filter
    Whitestone, NY
    3,211
    Re: K&N Air filter
    Does the defendant have any proof that they let more dirt into the engine?
    Quote Originally Posted by Guy.Seminerio
    Absolutely:
    Testand Corp of Rhode Island performed a ISO 5011 Test of several filters for a Duramax diesel.
    The ISO 5011 Standard (formerly SAE J726) defines a precise filter test using precision measurements under controlled conditions. Temperature & humidity of the test dust and air used in the test are strictly monitored and controlled.
    Here are the efficiency results:
    The K&N also plugged up 3 times faster than the AC Delco.
    Whitestone, NY
    3,211
    Re: K&N Air filter
    Haha wow. Case closed.
    carter's_sts is offline Cadillac Owners Connoisseur
    Automobile(s): 06 STS-V & 06 STS 4 (sold 2016)
    2,019
    I had one in my V6 for about a year, then went back to a regular one because I realized it was pointless and a waste of time (the cleaning, re-oiling).
    BaTu is offline Cadillac Owners Enthusiast
    Automobile(s): '05 STS4
    May 2008
    668
    Re: K&N Air filter
    Quote Originally Posted by MikesCaddy06 View Post
    I notice slight changes in performance, and even better gas mileage!!
    There's an old, universally accepted, axiom (might have come from Smokey) that in the seat-of-your-pants, you can't "feel" less than a 10% performance improvement.
    dkozloski's "delusional" comment is perfect!
    Re: K&N Air filter
    It's curious that GM never took advantage of this performance and fuel mileage change to get better advertising figures and better CAFE specs.
    (The K&N sticker is where the real horsepower is - especially when stuck on the RR passenger window so the ricer driver sees it at stoplights.)
    The "arguments" for using oil wetted filters are laughable ..........
    dkozloski's Avatar
    dkozloski is offline Cadillac Owners 10000+ Posts
    Automobile(s): 2006 STS V8 AWD, '95 Ford Ranger
    Jul 2004
    Fairbanks, Ak
    28,287
    Re: K&N Air filter
    Quote Originally Posted by BaTu View Post
    The quote is from "Stroker McGurk" which was a monthly cartoon with McGurkisms in Hot Rod magazine. The one I liked best is, "If a little is good, more is better, and too much is barely enough". Sub409 is partial to, "If it don't go, chrome it".
    K&N built their reputation with wetted foam filters for dirt bikes. They worked better than the alternates for the time. If your bike was outside when it rained, you were going nowhere until you took the filter off and wrang it out. I quickly reverted to paper filters on my 810cc Dunstall Norton.
    Don't mess with Binky Bear!
    Yes, they have their place in powersports and offroad.
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,287
    Re: K&N Air filter
    The K&N dirt bike filters had a foam rubber element that was wetted with motor oil. AC made a similar filter for aircraft to replace Donaldson filters that were constructed like the current K&N wire and flock. The foam element was never to be cleaned and reused on the AC filters because they were wetted with a special proprietery fluid, only replaced.
    The air filters on heavy construction equipment with engines that may cost $100,000 or more have pleated paper filters and may consist of three or more filter elements, one inside the other. Those barrel sized filters you see on 18 wheelers contain multiple nested paper filters. The idea of oil wetted flock filters seems plausible. Too bad it doesn't work.
    EChas3's Avatar
    Cedarburg, WI
    8,178
    Re: K&N Air filter
    The AC filter appears to be treated with some substance; it's kinda tacky, like nearly dry paint.
