Results 16 to 24 of 24
Thread: 98 eldo front brake stuck
    carnut is offline Cadillac Owners Master
    Automobile(s): 1999 BMW 740 Il. 2005 Jag XK8, 1988 Mercedes Benz 300 SE
    Feb 2003
    california
    6,688
    Re: 98 eldo front brake stuck
    How could they align the car with worn tie rods??? You say the rotors measure fine, but you're replacing them? try www.rockauto.com for strut pricing.
    eldorado_sean's Avatar
    eldorado_sean is offline Cadillac Owners Enthusiast
    Automobile(s): 98' Eldorado ESC
    Burbank, California
    740
    Quote Originally Posted by carnut View Post
    The right one looked fine. But on the left side the cv axle boot was leaking really bad. The grease was all over. the tires are wiggling a bit but we can save those until after suspension. Its either ball Joints,tie rods(outer) or the "clown" of a mechanic didn't tighten something enough.
    And rotors were at the minimum..and if we wanted to re surface them it would've been too thin.
    82,278
    Quote Originally Posted by eldorado_sean View Post
    Geez this cars turning into a piggy bank
    Man you can say that again.
    Burbank, California
    740
    Ok so after everything I did
    Cleaned maf, changed front rotors, pads, new caliper bolt,
    Got a price from a warehouse for front and rear struts part number 90011 and 40046 cheaper than ebay and amazon. Cv axle boot ill check Monday. And o2 sensor my dads going tomorrow to pick it up and will try to install the o2.
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    mpls mn
    2,527
    New struts? No way this car will have ride height issues like bob Ross. Unless u change the strut mounts too and they don't work with your new struts.
    Feb 2003
    california
    6,688
    That Oxy sensor code does not say replace the sensor, it says that bank is too lean. why is it lean? faulty injector? That code needs to be diagnosed before ANY part is purchased!
    O2 sensor codes are for the sensors themselves, not fuel mixture.
    basscatt's Avatar
    15,698
    oxy sensor CODES do NOT reflect a lean or rich mixture -
    they DO reflect the operation of the oxy sensor -
    you need to read the posts more carefully -
    the OP has TWO codes -
    P0135 o2 sensor bank 1 sensor 1 -
    P0171 lean bank 1
    in this case - the faulty O2 sensor COULD cause the lean mixture -
    Burbank, California
    740
    Pcm p0131 also came up. Its low voltage for sensor 1 bank 1. So everythings leading to the sensor. Ill have it done by Monday. Then hopefully will pass smog.
