Results 16 to 24 of 24
Thread: Front Window gets little hazy inside after wiping it down every couple days or so
    56,813
    Re: Front Window gets little hazy inside after wiping it down every couple days or so
    System OFF, last setting 60 degrees, and sunroof in VENT.
    9302Eldug is offline Cadillac Owners Fanatic
    Automobile(s): 93 and 02 Eldorado
    Apr 2012
    Oakley CA
    60
    226
    Wow air freshener. My car does the same thing and it started when I started using those air fresheners that clip onto the HVAC vents. And I thought it was from me smoking!
    82,263
    I use those air fresheners as well. No such problem. It probably IS the smoking.
    P.S.
    Don't let that stuff leak. It'll eat the paint off the dash panels.
    purelux is offline Cadillac Owners Enthusiast
    Automobile(s): 2003 deville
    May 2011
    501
    Try using a quality glass cleaner and some newspaper. 1 wiping usually doesn't work wipe left right, then next up and down. Usually 2 or 3 if you smoke maybe more.
    I've seen overuse of air fresheners cloud the windows, some protectants as well.
    Newspaper works fine, the reason they're suggested is that some of the better paper towels contain setting agents that can cause streaks. I use cheap paper towels and Invisible Glass.
    carnut is offline Cadillac Owners Master
    Automobile(s): 1999 BMW 740 Il. 2005 Jag XK8, 1988 Mercedes Benz 300 SE
    Feb 2003
    california
    6,688
    I did mean "should" I read all the time about people using this system like a manual A/C heater. Letting the system work as designed prevents early wear on fan switches, blower motors and related components. And like Ranger I very seldom have windows down.
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,474
    On my Cadillacs I've always left the climate control on econ unless I wanted AC and rarely adjust anything else. If it's summer and hot out it's usually left in auto.
    SissyBoyFloyd's Avatar
    SissyBoyFloyd is offline Cadillac Owners Member
    Automobile(s): 99 Eldorado ETC
    Jun 2013
    North of San Diego
    68
    Well so you will know: I cleaned the window good with Windex and clean towel and it has been a couple days now with no haze returning. Will update if that changes. I just sprayed Armor All on towel and rubbed down the dash and door areas last evening. Haven't checked it out today yet. Will see how she looks in a bit.
    Armor All has never given me a problem.
