Results 16 to 25 of 25
Thread: Dreaded SERVICE CHARGE SYS in DIC
    torched10's Avatar
    torched10 is offline Cadillac Owners Enthusiast
    Automobile(s): 2008 sts v, 2011EXT,65 GTO,08 vette,gt500
    Jan 2010
    atlanta
    621
    Re: Dreaded SERVICE CHARGE SYS in DIC
    output voltage should be at least low 14s--dont underdsatnd why its "climbing" its either over 14 or not--unless your battery is low--the battery should be 12volts and its parallel to the alterntor which should be 14 and charging the battery as you drive--if the battery is lower than 12, it might be using up the alternator output and battery is in charge mode--let it sit in driveway for an hour or so running and see what happens--dont leave ac on--too much load still sounds like you may have a ground issue
    TimmyC is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS-V and 2007 STS-V The Murdalac
    1/2 hr S of Grand Rapids, MI
    1,897
    These don't work like that. They vary voltage to keep the battery topped off. It's not always over 14v. Check it out when you drive yours next time.
    wake's Avatar
    wake is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 STS-V, 2007 Escalade, 2003 Escalade EXT
    Stafford, VA
    812
    Quote Originally Posted by TimmyC View Post
    My Escalade does the same thing. Supposedly it's to help increase fuel economy by varying the field on the alternator.
    A few times the gauge has dropped below the 14v mark and I thought I had another problem with the alternator, found out it was normal though.
    hammerheadv is offline Cadillac Owners Member
    Automobile(s): 2006 STS V
    24
    Thanks everyone for the input and advice on this thread. Wake was right, the remanufactured alternator just did not cooperate with the car. I took it in on Friday, they replaced it with an AC Delco alternator and it's been running like a champ ever since. I thought I could cut some corners and get a remanufactured alternator and have a friend put it in for for half of what Cadillac would charge me... Well here's a list of my expenses. $125 from Cadillac to diagnose, $183 for Pep Boys alternator, $150 for friend to put it in, problem still existed so I bought a new battery $190, problem still existed so I took it back to Cadillac and had them install the AC Delco alternator $800. I can get the money back on the Pep Boys alternator, and perhaps the battery, but I wasted $125 having it diagnosed twice, and $150 for my friend to install it. Moral of the story, stick with the AC Delco alternator on these cars.
    Milwaukee, WI
    115
    I used to drive BMW's and I learned the hard way as well to stick to OEM parts. Long story short, check engine light, scanner says camshaft position sensor, replaced with a reputible aftermarket replacement, reset light, comes back on. Failed emission test due to check engine light, off to dealer, they replaced the Camshaft position sensor with a BMW one and that was the culprit. I am now a firm believer that anything electrical related, go with OEM. Nowadays unless it's brake pads, suspension, or exhaust I stick with OEM. Fortunately OEM parts can be found much more reasonably priced online. The only downtime is waiting for them.
    Carlosg's Avatar
    Carlosg is offline Cadillac Owners Fanatic
    Automobile(s): STs v
    San Antonio Texas
    148
    Its back up to 14.0 and my friend told me to buy a oem and glad I did it would sux to have to do iy again.
    YoungBlood_STSV is offline Cadillac Owners Fanatic
    277
    Quote Originally Posted by hammerheadv View Post
    ... so I took it back to Cadillac and had them install the AC Delco alternator $800.
    Out of curiosity, how much was the alternator and how much was labor?
    Milwaukee, WI
    115
    I'll bet it cost less than the BMW liquid cooled ones. I almost crapped my pants when I was quoted $630 for a reman from Napa.
    Whitestone, NY
    3,211
    I think cadillac used to do liquid cooled alternators and then they stopped.
    24
    It was 2 hours of labor, plus the $125 for diagnostic, and I believe the alternator was $390.
