Results 16 to 29 of 29
Thread: Ebcm module
    Aztec ETC ECS's Avatar
    Aztec ETC ECS is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC ECS#533, '05 Escalade, '05 AWD Magnum, '74 455 OLDS
    NYC
    1,948
    Re: Ebcm module
    Quote Originally Posted by SUPER LAC DEVILLE View Post
    Sounds like u may have a BS Mechanic in your Pockets
    He may think the car won't be returned for completion if it's drivable.
    Caddy-EaRL's Avatar
    Caddy-EaRL is offline Cadillac Owners Enthusiast
    Automobile(s): 2000 DTS 194,000 miles, 2000 DHS 203,000 miles
    Ky
    51
    718
    Perhaps he didn't know easy removal is by removing splash shield, and instead removed battery, air cleaner assembly and computer....just a thought. Heck he may haven even removed the whole pump assembly.
    SUPER LAC DEVILLE's Avatar
    SUPER LAC DEVILLE is offline Cadillac Owners Enthusiast
    Automobile(s): 1998 Cadillac Deville
    Tampa Florida
    854
    Quote Originally Posted by Aztec ETC ECS View Post
    I Agree ...
    but an honest mechanic will gain a loyal customer by stating Facts
    I would be instantly suspicious of the statement that my car will not start with the removal of a device that has nothing to do with starting my vehicle... Regardless if I should drive it or not is another aspect all together
    Personally, I would take it somewhere else immediately... I wouldn't give him the chance to finish the job jus for his deceit
    If he didn't really know if what he said was true, I would still take my vehicle bc now I see him as incompetent
    Firestone lost my business simply bc the manager said their tire machine wasn't the type to remove or put on my specific tires... When I jus had them done there less than a year ago
    His employees disagreed with him and told him they've never had any problems changing any type of tires
    Once they completed the job I told them I would Never come back
    You either know your Dept or u don't
    Experimenting or doing crash course learning on a customers vehicle is absolutely an incompetent approach to motor vehicle services
    Jus my opinion tho
    Sent from AutoGuide.com Free App
    82,272
    Re: Ebcm module
    I have to admit that telling someone that removing the EBCM would prevent starting does sound have a ring of incompetence to it and would make me think twice. I expect a "professional" who I am paying to do a job to know more than me.
    bobstanster's Avatar
    bobstanster is offline Cadillac Owners Fanatic
    Automobile(s): 2004 Deville
    Apr 2012
    165
    Picked up deville today. A/C is working , vent doors are working , 'abs' 'brake' traction' lights are off but the ' service electrical system ' message is displaying and ' avg mpg ' and ' range' readings are way off and the 'airbag' light is on . Checked for codes but none are showing. Love this car but man it drives me crazy
    Tampa Florida
    854
    Quote Originally Posted by bobstanster View Post
    Wow,
    Sorry to say but I'm not surprised with that but only thing I could think of is Check ur battery connection terminals?
    Maybe Loose ground wires?
    Fuses
    Relays
    Ask ur Mechanic if he disconnected the Battery before working On the car... Pretty sure that's a must do when removing or installing anything electrical in these cars
    Might have fried something if he didn't do that 1st
    Apr 2012
    165
    Got a PCM P1574 code
    56,842
    Re: Ebcm module
    Stoplamp switch circuit. Above the brake pedal arm, wiring, trunk wiring and grounds.
    82,272
    Re: Ebcm module
    That could simply be from pulling battery power. Not positive, but I think that will reset them.
    Apr 2012
    165
    If it is the stop lamp switch circuit , could that also be the cause of pc7041. ( tcc)
    82,272
    Re: Ebcm module
    No. P0741 (I assume that's what you meant to type) is a leaky seal in the trans. It's a mechanical problem, not electrical. IF it is accompanied by P1860, then it is the TCC solenoid and IS electrical. Either way, the stop lamp switch is completely unrelated.
    Apr 2012
    165
    Break lights do not come on when step on brake so I will assume stop lamp switch is malfunctioning . How hard is it to change ?
    82,272
    Re: Ebcm module
    Other than doing it upside down and on your back in the front seat, no. It's at the top of the brake pedal.
    Apr 2012
    165
    I'm 6'5" 300lbs
    There are two switches? Going from bottom of the pedal to the top is it the first or second
