Results 16 to 24 of 24
Thread: S/C coolant level???
    carter's_sts is offline Cadillac Owners Connoisseur
    Automobile(s): 06 STS-V & 06 STS 4 (sold 2016)
    2,012
    So I'm still biting.....no leak? Someone drained it or what?
    Ludacrisvp's Avatar
    Ludacrisvp is online now Cadillac Owners Connoisseur
    St Michael, MN
    4,548
    Factory forget to fill it and previous owner never pushed the car.
    2,012
    Re: S/C coolant level???
    Nice. Didn't even think they would do (not do) that.
    Whitestone, NY
    3,211
    That's a double dose of humble with extra humble on the side, hold the pride. That's one of those things where it happens and you start sweating in your car. Just gets real hot all of a sudden. Good story.
    1madstsv's Avatar
    1madstsv is online now Cadillac Owners Connoisseur
    Automobile(s): 08 STS-V,10 escalade,80 sedan deville diesel 13 cts vagon
    York pa
    1,602
    Car had been sent to d3 and had installed most every thing they sell for a Stsv. And it must have slowly leaked out. And the owner at the time never drive it hard.
    Oct 2013
    Quote Originally Posted by 1madstsv View Post
    When you buy a car with only 7500 miles you just assume its all good. Wrong 20 miles in to the 180 mile ride back home with the car and a E550 mb with a dad and two teen boys in it come up along side me and start pointing at my car. So I gunned it and it went in to limp mode coasted to side of road car stalled out and would not stay running. I tought I killed it but it turns out the s/c had no coolant in it at all topped it off and went on my way after I reset it.
    My car just went in to limp mode. How do I rest it?
    theotherguyssn's Avatar
    theotherguyssn is offline Cadillac Owners Fanatic
    Automobile(s): 06 sts-v
    columbia sc
    261
    i mixed a little royal purple purple ice try and keep it running a tad cooler with my dexcool when i upgraded to timmy c heat exchanger and had to put new coolant pump on for supercharger system, took a while to get all the air out, gm service information states to pull cover off top of charger and the cap off the resvoir and fill resvoir until you see it about to run out top of charger, even after doing that and manually cutting the pump on and off i still kept having ot add coolant to mine for a week or so to bleed all the air out.
    CMNTMXR57's Avatar
    CMNTMXR57 is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS-V, 2004 Pontiac GTO, 1999 Chevrolet Suburban LT 4x4
    Chicago
    1,328
    It doesn't leak. It evaporates I'm pretty sure. The charged air cooling system isn't a sealed/pressurized system that purges air like your regular cooling system (at about 15psi). It is somewhat sealed, but not to the extent of the regular cooling system.
    Your intercooler gets VERY hot. Especially for those of you in the southern climates. Pop your hood after driving it. Touch that big black thing on top of the engine with your hand. Chances are you'll burn it. That is where that coolant runs through (in 4 laminer cores).
    And can we quit calling it GM coolant. It's Dexcool and more than GM uses it. It was just a proprietary mix developed by GM and Havoline (or maybe Texaco), I forget. G-05 on the market also, is a modified version of Dexcool (for the simplest explanation here, I am not going to get into the exact chemical breakdown between the two), and that is what Chrysler and ford like to use. But the rest of the world uses a Dexcool or similar substitute. Many other brands make suitable Dexcool coolants. You don't need to go to the GM dealer and get specific "GM coolant".
    choigilligan is offline Cadillac Owners Fanatic
    Automobile(s): STS-V
    195
    They sell Dex-Cool at every auto parts store.
