Page 7 of 45 FirstFirst 1234567891011121314151617 ... LastLast
Results 91 to 105 of 662
Thread: 1983 Fleetwood Brougham d'Elegance Project
  1. #91
    talismandave's Avatar
    talismandave is offline Cadillac Owners Master
    Automobile(s): 1980 Eldorado, 1974 Talisman, 2004 Volvo C70,
    Madison WI
    7,894
    Re: 1983 Fleetwood Brougham d'Elegance Project
    The part is threaded into the center of wheel mount. It just unscrews. It has been a couple months since I did mine but if I recall correctly I just kept moving it with lever, and remounting lever in next holes until it could be moved by hand.
    If you have a pin spanner wrench to put in the two center holes it would be easier. I think I opened up a needle nose plier and put it in the holes and used it as a handle to spin it out.
    You will need a wheel puller once you get all that out of the way. If you don't have one I used a piece of steel, and three bolts to do mine.
    Just unscrew the center bolt until it pushes the wheel off. 5/16 in. 18 threads/in. IIRC?
  2. #92
    grauhst's Avatar
    grauhst is offline Cadillac Owners Fanatic
    Automobile(s): 83 FWB d'Elegance, 83 CDV, 83 FWB, 74 Lincoln Mark IV
    Stralsund, Germany
    371
    Thanks, that worked fine!
    installed the new one. In my opinion it looks way better.
    comparison
    Best Regards
    Felix
  3. #93
    Buxton, Maine, United
    4,192
    wow very much better!
  4. #94
    Robin Banx's Avatar
    Robin Banx is online now Cadillac Owners Enthusiast
    Automobile(s): 1983 FWB (Mac), 1981 SDV (Junkyard Dog)
    Vancouver, B.C. Canada
    725
    ^ And I'm pleased that the steering wheel from my car has found a good new home.
    Cheers.........R.
  5. #95
    grauhst's Avatar
    Stralsund, Germany
    371
    It's so great, I love it!
    Thanks a lot!!!
    Felix
  6. #96
    jamespowers is offline Cadillac Owners Connoisseur
    Automobile(s): 1986 Brougham, 1975 Eldorado, 2008 Escalade
    1,100
    Quote Originally Posted by grauhst View Post
    comparison
    Best Regards
    Felix
    Save that leather wrap. You never know when you might be able to use it if it is still in good shape.
  7. #97
    cadillac kevin's Avatar
    St. Louis, MO
    6,397
    Quote Originally Posted by jamespowers View Post
    This. The wheel looks to be in good shape aside from being faded. If your wood trimmed wheel cracks, you can always redye and reinstall the leather wheel.
  8. #98
    1,100
    Quote Originally Posted by cadillac kevin View Post
    One of the reasons I would keep it that is for sure.
    You can also use it to repair small bad spots in the leather or vinyl.
  9. #99
    Madison WI
    7,894
    Looks great, just like new.
  10. #100
    grauhst's Avatar
    Stralsund, Germany
    371
    Yes, sure I will save the leather one as a spare. Unfortunately someone has wrapped an additional layer of leather on it. It looks a bit purple.
    Regards
    Felix
  11. #101
    St. Louis, MO
    6,397
    Regards
    Felix
    That's faded. It probably used to be burgundy or brown. Both of those colors can fade to purple.
  12. #102
    Madison WI
    7,894
    If you want to have fun and experiment on your spare wheel, I fixed my cracked wheel and replaced the foil woodgrain with real wood veneer. I am not sure if your wheel still used the same system as the 74 or not but it might be worth checking out?
  13. #103
    grauhst's Avatar
    Stralsund, Germany
    371
    The original wheel that I took out is an original leather wheel and someone wrapped another layer around it.
    I don't know how it looks underneith but I think the leather is worn, cracked or whatever. If I need a replacement sometimes I think I would dye it brown and put it in.
    It is in good shape but I like those thin wheels more.
    Regards
    Felix
  14. #104
    Madison WI
    7,894
    I am sure it is the same thin wheel under the leather cover. If it is the same system as on the older ones the plastic covering the fake wood grain cracks off and the foil tape starts to cut your hands. (Someone with a mid 80s may confirm or refute this.)
    If so what I did was pull out the plastic and cut real wood veneer in the slot the plastic was in then applied chrome pinstripe tape on outer edges and covered it all in clear poly.
    Here is a link to CadForce69's thread where he shows what is involved. http://www.cadillacforums.com/forums...oration-9.html
  15. #105
    St. Louis, MO
    6,397
    The leather wheels do not have a hard plastic wheel under the skin. I asked about that a while ago, and someone showed a torn open one.
    As for leather over the leather, maybe, but that would make a very fat wheel. The factory leather always looked a bit awkward where it meets the spokes.
