Page 4 of 5 FirstFirst 12345 LastLast
Results 46 to 60 of 74
Thread: Mod progression/route? (for track/street)
    JFensty's Avatar
    JFensty is offline Cadillac Owners Enthusiast
    Automobile(s): 04 Blk Cts-V
    Allentown PA
    39
    594
    My first guess is sway bar bushings, or the collars.
    2,045
    Re: Mod progression/route? (for track/street)
    Quote Originally Posted by JFensty View Post
    My first thought was that he might've failed to sufficiently torque the shock top nuts with the wheels down.
    liqidvenom is offline Cadillac Owners Connoisseur
    Automobile(s): cts-v
    Long Beach Ca
    2,741
    Fuzzy i was puttin on my LG's and my stock 100k mile end link came apart in my hand...i just ordered a set of the Miata ones you mentioned
    OneFast V is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 Raven Black CTS-V
    San Jose, CA
    979
    Quote Originally Posted by UnsafeAtAnySpd View Post
    P/S: There's a good writeup around on how to throw an upgraded unit in the stock location. I have a pretty big Fluidyne unit. Do this mod as it is cheap and I used to boil the PS fluid everytime out on the track. Oil cooler is in the future for me. Check the stickied thread on some more info.
    Axles: No personal experience. I'm going with the 9" kit (sitting on my bedroom floor, uninstalled)
    Your inbox is full tried to PM you! Anyways I figured I would ask how much track time you have on the PS cooler? Mine exploded after 4 HPDE sessions at Laguna Seca on Sunday. I'm concern this cooler really may not be adequate, either that or I got a faulty one.
    Andringa is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 CTS-V Blk/Blk
    Nov 2009
    Wisconsin
    785
    Quote Originally Posted by OneFast V View Post
    Do you have pictures of how it failed.
    Anybody have any idea what kind of pressures the Power Steering system can generate?
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,208
    The power steering pump specification in the Service Manual (pressure relief) is 1,640 to 1,740 psi.
    San Jose, CA
    979
    Quote Originally Posted by Andringa View Post
    Its not visible but you can just see the bottom portion of the cooler drenched in PS fluid as well as the underside of my car. There is no fluid anywhere upstream of the cooler either.
    I will probably be switching to a cooler like this:
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,208
    I cannot imagine the PS system is carrying 1700psi. That seems extremely high
    Well that is the specification. Since it is the "relief" spec it likely contemplates "spikes." For the purposes intended here, I suspect all we really need to know is that power steering systems operate with at pounds of pressure in the hundreds and therefore, are high-pressure as opposed to low pressure systems.
    Finally, the pressure ratings are at the output side of the pump (pressurized-line) and not at the return-line side where the pressure would presumably be substantially reduced.
    San Jose, CA
    979
    Quote Originally Posted by darkman View Post
    I guess I'm just suprised this system runs at such high pressures. Knowing this now I don't think the faq recommended cooler is adequate for such pressures which is likely why I had an issue.
    odla's Avatar
    odla is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac platinum 04 & Blk 05 cts-v
    Nov 2006
    miami ,Fl
    2,372
    I thought that others had tracked their car with the one in the faq. No? I will be holding off on this now. Thanks onefastv.
    San Jose, CA
    979
    Quote Originally Posted by odla View Post
    That's what I am trying to find out. It may just be a one off failure but I haven't heard anyone else's track experience with it.
    AAIIIC's Avatar
    AAIIIC is online now Super Moderator
    Automobile(s): '05 CTS-V
    Where the Navy takes me...
    6,463
    The PS cooler should basically be at ambient, since it's in the return line to the reservoir and the reservoir is vented to atmosphere.
    I, too, would be interested in seeing pics of the failed cooler, but I have to think it was just a faulty cooler. There are tons of OEM PS coolers on all sorts of vehicles and none of them are anything special / heavy duty.
    San Jose, CA
    979
    Is the hose routing on the power steering important? I would not think so but wanted to confirm.
    nikdsctsv is offline Cadillac Owners Fanatic
    Automobile(s): none
    Jul 2009
    139
    Yup! Waitin for pics before i do this to my V!
    San Jose, CA
    979
    Here is what the cooler looks like now. you can see the area where oil has soaked the cooler but there is no apparent gross leak, it is definitely a fine leak.
