Results 31 to 44 of 44
Thread: 05 STS Remote start not working??
    EChas3's Avatar
    Cedarburg, WI
    8,178
    Re: 05 STS Remote start not working??
    The fob's number has no real meaning. Your car can match up to four fobs and one of yours may be a replacement that is not matched to the car as one of the first two. Only those two can remote start your car.
    Anything else will not be inexpensive to repair.
    Good luck.
    curtc's Avatar
    curtc is online now Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    6,061
    Yeah, I would think it has to do with the fob's and their respective settings in the system. Make sure you are saving the setting for enabling the remote start, it has to be something easy, just not real obvious...keep trying!
    Cadzilla8's Avatar
    Cadzilla8 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Cadillac STS Northstar V8
    NY
    247
    Remote start in the system is on. This is the same key I used 4 days ago that worked
    Ludacrisvp's Avatar
    Ludacrisvp is online now Cadillac Owners Connoisseur
    St Michael, MN
    4,548
    how old is the 12v car battery?
    any corrosion on the battery posts?
    Cadzilla8's Avatar
    NY
    247
    The battery is 8 years old not really any corrosion on the terminals
    Cadzilla8's Avatar
    NY
    247
    Ok I'm convinced it's a car battery issue if I turn the car on and check the battery it's at 12volts and charges up to 14 quickly. If I turn the car off then the remote start will work. So I guess the battery drains slowly over a few days and doesn't have enough power to start it up
    curtc's Avatar
    Jul 2005
    Oakdale, MN
    6,061
    that is pretty much how mine works too...random cold starts won't work on the first attempt, but will on the 2nd typically...I'll be getting a new battery soon.
    Ludacrisvp's Avatar
    St Michael, MN
    4,548
    Yeah the STS is REALLY REALLY picky about its battery. 8 years on a 5yr? Battery is definitely on borrowed time. Consider yourself lucky it even starts. When mine died in my DTS there was zero warning just one day it wouldn't even try to turn over and a truck couldn't jump it. New battery put in and it started without any effort.
    EChas3's Avatar
    Cedarburg, WI
    8,178
    Series 99 (or is it 109) are hard to find, but a 78 w/o top posts may fit. Optima makes one that does. We love ours.
    Cadzilla8's Avatar
    NY
    247
    Yeah what's the best type of battery to put in it and where can I get one
    Ludacrisvp's Avatar
    St Michael, MN
    4,548
    Service manual says it needs to be 690 CCA (cold cranking amps), model number is 101-6YR, should provide 63 A/H (Amp hours) and a 110 minute reserve capacity.
    If you feel there might be parasitic draw:
    Check and record the current reading.
    Note the battery reserve capacity, amp hour rating. Refer to Battery Usage.
    Divide the reserve capacity by 4, amp hour rating by 2.4.
    Compare this to the multimeter milliampere reading taken in the previous step. The parasitic current drain should not exceed this number.
    Example: If a battery has a reserve capacity of 100 minutes , (60 A/H) the current drain should not exceed 25 mA .
    Cadzilla8's Avatar
    NY
    247
    Thanks for the help guys glad I'm finally sorting battery issue out before it dies somewhere inconvenient haha
    EChas3's Avatar
    Cedarburg, WI
    8,178
    When I decided to stretch the life of my OEM battery, I caught a jump-pack for $40 on sale. I've used it for camping & backup power around the house. I never did need it in the car.
    Nov 2013
    I've got an '06 STS with about 70k miles, battery in FOB and Car are both fairly new, but that's probably not the issue. I've got the amber radio setup. I go into the settings and the "remote startup" is not checked. I go into the sub-menus, uncheck everything, re-check everything, and press the back button. Everything EXCEPT "remote startup" is checked. I then look at the sub-menu's again....everything is still checked. Oh, and no..no check-engine light.
