Results 16 to 30 of 44
Thread: 05 STS Remote start not working??
    fly187's Avatar
    fly187 is offline Cadillac Owners Member
    Automobile(s): 2006 Cadillac STS4
    Dallas Texas
    84
    Re: 05 STS Remote start not working??
    Neko98 is offline Cadillac Owners Member
    Automobile(s): 2006 sts
    41
    Seems once I remote start and it shuts down after it times out, it won't let me re remote start, is that normal?
    KRSTS Guest
    No! Should allow you to remote start twice in a row
    wake's Avatar
    wake is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 STS-V, 2007 Escalade, 2003 Escalade EXT
    Stafford, VA
    812
    Are you maybe canelling out the remote start by hitting the lock button twice? For my 07 you hit lock once then press and hold the start button. If you hit the lock button twice it flashes the lights and chirps the horn on mine.
    Ludacrisvp's Avatar
    St Michael, MN
    4,549
    Quote Originally Posted by KRSTS View Post
    If you remote start and it runs for 2 minutes and you tell it to run another 10 it will run for 12 mins and shutdown until you start normally again, it will refuse to remote start again or allow you to extend it again.
    ddalder's Avatar
    ddalder is offline Cadillac Owners Connoisseur
    Automobile(s): 08 STS-4 N* 1SG, 08 DTS Luxury II, 04 Bonneville GXP N*
    Aug 2008
    Canada
    2,852
    Yup, it will let you remote start twice in a row, however when you remote start for the second time, it resets the timer for 10 minutes. If it only ran a short time during the first remote start cycle, you lose whatever time remained in the first 10 minute cycle. If you want a full 20 minutes of run time, you need to wait until the timer runs out from the first remote start, then restart again.
    As for my 2008, I only push the lock button once (watch for the lights to flash) and within 5 seconds, press and hold the remote start until the engine starts. I only need to hold the remote start button again (until the engine stops) to terminate the cycle.
    B1n2fra's Avatar
    B1n2fra is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 1SG STS v8 awd
    Nov 2011
    Chicago
    502
    Quote Originally Posted by Cadzilla8 View Post
    Actually there is I just figured it out if you did the remote start hit and hold start and unlock
    You only have to hold the start button for a couple seconds to shut it off.
    EChas3's Avatar
    Cedarburg, WI
    8,178
    Twice and you're out.
    Have we killed this topic yet?
    Cadzilla8's Avatar
    Cadzilla8 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Cadillac STS Northstar V8
    NY
    247
    Ok so I haven't started the car in about 3 days and I go to use the remote start to let the car run.. Same issue lights flash no start up but when I get in it starts fine with push button. Is the battery too weak to remote start it after a few days? Do I need a new battery? I believe it is original battery and the car is an 05 so may be time for a new one. If so any suggestions on battery
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    6,061
    Doubt it's a battery issue, if the lights flashed when you locked it and flashed when you held the remote start button the car got the signal...But, any CR2032 3v battery will do. Energizer has always had a special place in my heart when it comes to batteries
    Thanks for the reminder though, I've been needing to get a replacement battery for my fob, the range is slowly inching closer to the car....off to the hardware store!
    Cadzilla8's Avatar
    NY
    247
    Quote Originally Posted by curtc
    I actually meant the car battery being the original and maybe no having enough juice to remote start it but I don't see how remote start would need more power than a regular start. Idk I'm confused why it worked for 2 days than after 3 days of sitting back to kaput.
    EChas3's Avatar
    Cedarburg, WI
    8,178
    I'd check the saved settings again and also ensure your fobs are properly matched with the car. One fob matched as #3 or #4 will confuse troubleshooting beyond belief.
    Cadzilla8's Avatar
    NY
    247
    It's key #1 and #2 that I used/tried nothing has changed since a few days ago when remote start worked
    curtc's Avatar
    Jul 2005
    Oakdale, MN
    6,061
    I know my remote start will not work sometimes on the first attempt on a cold start, just get a click from the starter...That's clearly battery related and will be addressed soon. The starter is new so I know that isn't the issue.
    If the car doesn't attempt to start at all and just flashes the lights it's disabled for some reason, that's the same behavior you get if you try 3 times.
    Cadzilla8's Avatar
    NY
    247
    Man I was excited to have the remote starter working again to warm the engine up I will investigate further tomorrow
