Results 16 to 26 of 26
Thread: EFI to Carb swap ? - 1976 Eldorado
    BRUCE ROE is offline Cadillac Owners Fanatic
    Automobile(s): Eldorado
    390
    The 76-79 EFI book you really want is on EB*Y a lot, like Item number:330668089237. I
    have a couple spares too, cover smudged some. I also have seen the 500 ECU listed.
    Though, the 350 ECU can be retuned as a backup (wrong brackets). I should put how to
    do that on my PHOTOBUCKET. Bruce Roe
    davidp1561 is offline Cadillac Owners Member
    Automobile(s): 1976 eldorado convertible
    Re: EFI to Carb swap ? - 1976 Eldorado
    yes i have ordered the efi diagnostic book. glad for the info tho you guys are great.
    f_zechetti is offline Cadillac Owners Member
    Automobile(s): 76 Eldorado Convertible
    São Paulo, Brasil
    Hi, here in Brazil I have a 76 Eldorado EFI and tired of trying to fix the fuel injection source. I installed the FuelTech, which is a programmable fuel injection and had no more problems. All original parts have been exploited and appearance of the engine remained the same. For the 500 engine, the fuel injection models used are the FT 300, FT350 and FT400
    Not cheap, but solved my problems.
    Manufacturer's website http://www.fueltechems.com/home.html
    390
    Quote Originally Posted by f_zechetti View Post
    Hi, here in Brazil I have a 76 Eldorado EFI and tired of trying to fix the fuel injection source. I installed the FuelTech, which is a programmable fuel injection and had no more problems. All original parts have been exploited and appearance of the engine remained the same. For the 500 engine, the fuel injection models used are the FT 300, FT350 and FT400. Not cheap, but solved my problems.
    Did you use the same injectors at the same pressure? Still bank injection, or change to sequential? The same ignition, or an ECU programmed advance? Did you change the temperature sensors? How long did it take to get everything tuned up? Did you use an OX sensor? Did you change the idle air motor? Is your old ECU available for another Cad owner? Bruce Roe
    São Paulo, Brasil
    Quote Originally Posted by BRUCE ROE View Post
    Everything remains the original, except for the replacement of TPS, temperature sensor, idle air valve and coil. Hall sensor was adapted in the original distributor (before has a mallory distibuidor was installed but did not work out). The mechanic took about 3 weeks to deliver the car. Yes, I installed the O2 sensor. The original ECU I do not intend to sell. You should also install a Peak and Hold and Spark Pro 1
    Sorry for the delay in answering and the errors in your language.
    São Paulo, Brasil
    The ECU was installed underneath: Car dashboard and tells you in real time various data such as engine temp, air temp, opening time of the injectors, etc..
    There is two other versions with touch screen, the FT 350 which has the same functions of the FT 300 and FT 400 which is the most complete.
    390
    Thanks for the pictures. Looks like the old wiring was redone for a new computer? That would imply you
    are still using bank injection, not sequential? And a different cold idle air valve? Bruce Roe
    ShedOfRedemption is offline Cadillac Owners Member
    Automobile(s): 1977 deville coupe 425 efi
    Nov 2015
    6
    Hi! any bode can tell me what i need to swap on carb in my caddi 77 425 efi ?? What carb ? and what other parts ?? please help!
    caddydaddy's Avatar
    caddydaddy is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Escalade 6.0L 2WD, 2007 Jeep Grand Cherokee Limited CRD
    Jan 2003
    Gales Ferry, CT
    3,717
    Quote Originally Posted by ShedOfRedemption View Post
    Just a Q-Jet off of a '77-'79 425 should work fine.
    Nov 2015
    6
    Thank you caddydaddy, i need something more to completly swap?? intake mainfold ?? some ignition moduje etc?? cheers
    caddydaddy's Avatar
    Jan 2003
    Gales Ferry, CT
    3,717
    I think the carb should bolt to the EFI intake manifold, but you'd need to install a fuel pump from a carbureted engine, since the in tank pump would have too much pressure. I'm not sure if the EFI distributor would work, but a swap to one from a carb'd engine is an easy fix.
