Page 3 of 9 FirstFirst 123456789 LastLast
Results 31 to 45 of 131
Thread: Door projectors
    GProdigy's Avatar
    GProdigy is offline Cadillac Owners Fanatic
    Automobile(s): cts
    320
    Re: Door projectors
    Is there a good link to how to install these for our car?
    I received mine, however there are no instructions.
    blunted is offline Cadillac Owners Enthusiast
    May 2004
    NYC
    585
    Re: Door projectors
    Quote Originally Posted by C "T" ess View Post
    Think about it for a second. If you open your door during the day; on a car without the projectors, can you see the door courtesy lights come on? The key is that for you to be able to see the projection, the surrounding light has to be darker than the projected image.
    LOL... yes your absolutely correct and the question did seem a bit retarded. However, I've seen some youtube videos of these and the image is still projected.. lightly.. with some ambient light.
    Cuest is offline Cadillac Owners Fanatic
    Automobile(s): 2013 ATS 2.0T Performance w/Red & Carbon Interior
    May 2010
    NYC / Florida
    157
    Re: Door projectors
    None of these projectors will be visible in broad daylight.
    C "T" ess's Avatar
    C "T" ess is offline Cadillac Owners Connoisseur
    Automobile(s): 2015 ATS Performance Coupe 2.0T
    May 2007
    Tampa,FL
    66
    2,773
    Re: Door projectors
    True, when my car is in the garage; even during the day, the ambient light is muted just enough that I can see an image.
    pacman2011 is offline Cadillac Owners Member
    Automobile(s): Black 2008 CTS Premium
    Re: Door projectors
    Finally got around to doing it!
    The key (for me anyways) was to make it as seamless as possible, without doing a "hole" lot of drilling into my doors. I elected to drill into the pre-existing light covers instead, which gives me all the electrical hookups i need too, and removes them from the equation as i wasn't sure if the extra light would cause the projected display to be harder to see. There is a chunk of door-removal and puddle light-bulb removal that i won't go into here. If you are taking a mod on like this, you should probably be comfortable doing that on your own (or find another guide as i did).
    Another good thing to note is that the projectors that i bought didn't fit quite right into the plastic shield. This is fixed by only using ONE of the TWO screws they give you attached to the divice. Fit like a glove with the other one just not in use.
    0) I used the included hole saw to drill through the plastic shield for the door light, after removing the bulb.
    1) I soldered the wiring, really easy to do if you have the tools. Helpful hint if you don't know your electric 101 - BLACK TO BLACK - then match the other colour (should work for 90% of all 2 wire systems....ground to ground after all).
    2) Assemble the damn thing (the top of the projector comes off if you forgot to thread it through b4 your soldering job. Saved me some serious hassle.
    3) Finished product:
    (keep in mind that this is a poor quality picture on really rough concrete...i'll take a higher resolution picture if even one person would like to see it)
    Tbbt is online now Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS4 Premium Wagon-Diamond White-Cashmere Interior
    Castle Pines, CO
    73
    2,401
    Re: Door projectors
    Pacman,
    Great job! Thanks for the info and pix.
    Marv
    jeffc83's Avatar
    jeffc83 is offline Cadillac Owners Connoisseur
    Automobile(s): 2008 CTS4 DI Premium (SOLD) / 2013 XTS Luxury (TOTALLED) / 2015 BMW 328i XDrive Lux
    Southeastern PA
    1,957
    Thanks for the write up pacman2011! I may just have to swap out my LEDs with these
    C "T" ess's Avatar
    May 2007
    Tampa,FL
    66
    2,773
    Re: Door projectors
    I did the same thing but with the gen4 version which does not use the set screw. I like that I can switch back to stock just by replace the light housing only..
    dekes1 is offline Cadillac Owners Member
    Automobile(s): 2016 ATS Coupe 2.0T 8A
    Jan 2010
    Re: Door projectors
    Another example. I did the wiring nearly identical to pacman2011, but did not drill out the existing lights (created a new hole)
    jeffc83's Avatar
    Southeastern PA
    1,957
    I'll have to look for these...so it was an easier install then?
    C "T" ess's Avatar
    May 2007
    Tampa,FL
    66
    2,773
    Re: Door projectors
    Quote Originally Posted by jeffc83 View Post
    I would think the degree of difficulty with either one is about the same since you can attach it to the light housing while is out of the car. The one advantage I saw was the gen4 was easier to tighten since projector housing was threaded and the retainer nut simply screwed on. I used a touch of thread lock to keep them tight.
    jeffc83's Avatar
    Southeastern PA
    1,957
    Thanks for the info!
    Corvettekid82's Avatar
    Corvettekid82 is offline Cadillac Owners Member
    Automobile(s): 2009 CTS Coupe Blue Diamond Tricoat
    Jun 2013
    Deland, FL
    6
    Re: Door projectors
    Great find!
    I used the 4th gen projectors as well and they worked great. I took the approach of mounting them to the existing lenses as I couldn’t bring myself to drill into the door of the new (to us) vehicle. Hardest part of the entire install was wiring it up and that was pretty easy. I used the factory harness for the entrance light and removed the wire retainer, soldered on the new wires to the existing ones and replaced the retainer.
    C "T" ess's Avatar
    May 2007
    Tampa,FL
    66
    2,773
    Re: Door projectors
    The biggest problem I've had was on Father's Day when I visited my daughter; she was unimpressed when she opened her door. I don't know how I could have raised such a rotten kid. (just kidding of course)
    GProdigy's Avatar
    Automobile(s): cts
    320
    Re: Door projectors
    We followed Pacman's instructions and here's the results...Thanks dude
    It still took some work to make sure it was flushed so Im not saying it was a piece of cake. lol..but its def smarter than drilling into the door.
