Results 16 to 26 of 26
Thread: spring rates on REAR coil-over conversion????
    crankedupforit's Avatar
    Cheese land
    1,596
    Re: spring rates on REAR coil-over conversion????
    Quote Originally Posted by darkman View Post
    true coilovers.
    True coilovers in the rear have a different wheel rate as the inboard config on a stock location spring. Darkman used the magic word "true". KWs and GCs are not true coilovers in the rear so the control arm has much more leverage on the spring thus requiring more rate as Fuzzy has recommended. For true coilovers Angelo's' recommendation make sense.
    etcts-v's Avatar
    etcts-v is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 CTS-V, 423 RWHP / 380 RWTQ
    Seattle, Washington,
    578
    700 seems a little stiff for a daily driver am I incorrect on this assumption? I'm wondering if I should bump to 700/750?
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,207
    Quote Originally Posted by etcts-v View Post
    The 700 level is not too stiff for daily driving, IF the shock is set up to control it. In the two cases cited in this thread (Anze's Penske setup and LG Motorsport's setup) the supplier presumably matched the shock to the spring. That does not mean 700 is the right answer for any shock.
    etcts-v's Avatar
    578
    Gotcha, so many variables with setting up the best suspension for your required use! Been reading grips of books on frequency, camber, caster, toe, rebound rates, etc but still a bit foggy..
    Junior1's Avatar
    About to pass you...
    1,248
    900/500 on my Penske setup by Angelo at Anze...
    runsfromdacops is offline Cadillac Owners Fanatic
    Automobile(s): twin turbo rear mount V1 CTS-V built 383. 875/860RW pump/met
    Oct 2011
    WA
    177
    Dam. 900/500. Sounds stiff. Im thinking about 450 as a rear rate for my car. Keep in mind that the car make 875/860 and is used mostly for roll racing and drag racing. I also can NOT lower the car at all becuse of my charge pipe
    JDB's Avatar
    JDB is offline Cadillac Owners Connoisseur
    Automobile(s): '05 Raven/Ebony CTS-V with toys
    PA
    1,070
    Quote Originally Posted by OneFast V View Post
    You misread. This is exclusively if you are converting the rears to coilovers. If std setup then yes you are correct.
    Oops. Sorry. I did miss that.
    I wish we had more coilovers options at reasonable $.
    Oct 2011
    WA
    177
    looks like my rears just shipped form strange, i went with 450# rears
    nikdsctsv is offline Cadillac Owners Fanatic
    Automobile(s): none
    Jul 2009
    139
    And fronts?
    Oct 2011
    WA
    177
    stock fronts for now. i will be adapting the some satrage fronts in the near future.
    OneFast V is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 Raven Black CTS-V
    San Jose, CA
    979
    Quote Originally Posted by runsfromdacops View Post
    Stock fronts with 450# true coilover rears will make for a very sloppy ride. You've essentially doubled the rear wheel rate while leaving the front wheel rate unchanged. The differing Frequencies could cause a lot of issues as far as handling goes.
