Page 3 of 11 FirstFirst 1234567891011 LastLast
Results 31 to 45 of 162
Thread: Project HUD
    ddalder's Avatar
    ddalder is offline Cadillac Owners Connoisseur
    Automobile(s): 08 STS-4 N* 1SG, 08 DTS Luxury II, 04 Bonneville GXP N*
    Aug 2008
    Canada
    2,843
    Re: Project HUD
    Well it seems you are quite capable for sure. I really can't see why this won't work, but it is a PITA if it doesn't. When the dealer replaced my HUD under warranty, they broke away pieces of my carrier instead of removing the steering column the way they should have. If you take out the column, you may be able to clear the shifter. This is another area they broke to save a little work.
    BTW, there is a problem with the link in your last photo. It isn't displaying properly.
    1BadCadSTS's Avatar
    Automobile(s): 05 STS4
    4,224
    Re: Project HUD
    retried it!
    i agree i would rather not waste my time or money if this proves to be fruitless but I think it will work (in theory on paper it looks legit!)
    Lets hope the RCDLR pans out...
    http://www.ebay.com/itm/120839227693...84.m1439.l2649
    07 module should have everything SET, we shall try this....
    i think i take on too many projects at once... this is why my Camaro never gets done...
    ddalder's Avatar
    Aug 2008
    Canada
    2,843
    Re: Project HUD
    Give it a shot. Hopefully it will work for you.
    1BadCadSTS's Avatar
    4,224
    Re: Project HUD
    Worst case for that one Ill need to reprogram my keys back to my OE RCDLR and I wasted $25 bucks if it doesn't work, or if it does Ill need to have the dealer clear it with the VTD...
    The HUD is what I really want though hahaha
    Ill wait till I head the status on the RIM once you shut off the HUD to decide if I wait to pick this HUD carrier up (pointless to waste money)
    I may have them turn on the HUD in the RIM program the brake pedal and clear the VTD for the new RCDLR all at once, maybe Ill get away with just an hours diagnostic hahaha
    ddalder's Avatar
    Aug 2008
    Canada
    2,843
    Re: Project HUD
    If you have a look at the Hollander information on that eBay listing, it says "STS 07-08 Theft/Locking; w/o keyless entry". Hopefully this doesn't create a problem. I'm not aware of an STS without keyless entry, but for an 07-08 part, it does have a different part number on the case than mine.
    1BadCadSTS's Avatar
    4,224
    All of them say that if you dig into it. No idea why. Maybe because our cars technically don't have keyless entry. It's called passive proximity or something special since you only need the fob on your person and not to actually press the unlock for access. I forget the exact name for it.
    Re: Project HUD
    with regards to MDI/SPS programming vs the TechII if you want to flash a module or option that a vehicle doesn't have you have to call GM TechLine and get them to add that option to the VIN so when you program it with the MDI using the VIN the option is there
    we ran into this recently turning on cruise control for a chevy cruze
    (oh the irony of a cruze that didnt' have cruise)
    the customer didn't explain themselves clearly to us and the tech and I worked for about a half hour trying to figure out why the customer would say that cruise wasn't working when the car clearly didn't come with the cruise control option
    when we went back to the customer they explained better that they wanted us to turn cruise on... that was news to me
    so my tech called techline and they said that this is the new normal - lots of simple options will no longer require new parts but just new software
    so techline added the option and my tech reflashed with the MDI and all was good
    Ludacrisvp's Avatar
    St Michael, MN
    4,548
    Re: Project HUD
    That sounds frustrating.
    1BadCadSTS's Avatar
    4,224
    So can I mail you this rcdlr rippy and have you turn on the secure car feature?
    Also ever find out if the headlamp switch has a pigtail?
    Ludacrisvp's Avatar
    St Michael, MN
    4,548
    Re: Project HUD
    @1BadCadSTS - what is on your bumper on the STS in the last pic with the XLR (next to passenger headlight)?
    Also, as you apparently have intimate relations with the XLR are there any parts for the XLR that could or should or that someone might want to be used on the STS?
    Not really sure of all its features.
    1BadCadSTS's Avatar
    4,224
    Quote Originally Posted by Ludacrisvp
    It threw a headlamp washer cover. Had to order and have painted. I promptly deactivated the system right after. Great system, lets spray water all over the front of the car while its crappy out... Got tired of my car looking all streaked in the front, but it was amusing to hit my GF with the washers while picking her up all the time....
    XLR...share.... the shift knob, ecm, tcm and the throttle body... seriously thats about it... Engine accessories are routed all different so the engine cover isnt even the same. HUDS different, only green but it has a really cool boot up, vette suspension, sway bars, brakes, wheel bolt pattern, trans tube... The block and heads MAY be the same but I never dug that much into it to check.
    Re: Project HUD
    we can't program it like that
    it has to be in the car to be programmed
    there probably is some way to bench program but dealers don't have access to the equipment, tools or knowledge info
    another consideration is if GM TechLine will alter the option for you or not
    some option adding (like the cruise control i mentioned earlier) maybe sanctioned and some may not be sanctioned
    the only way to know is to try i guess
    1BadCadSTS's Avatar
    4,224
    Gotcha. Thanks. How about the headlamp harness. Pigtail or no?
    Re: Project HUD
    that was the driver's info switch connector (88988295) not the headlamp switch
    it was not a pigtail ... the parts catalog says "without leads"
    1BadCadSTS's Avatar
    4,224
    Re: Project HUD
    Well HUD came today I found something which made me VERY happy.
    The XLR-V front clip I bought to section on to the XLR I rebuilt for my boss included most of the wiring. As luck would have it I cut and kept every single left over plug of that front clip just in case because you never know when you might need a GM plug for something. Well with those plug was the XLRs HUD plug which is a DIRECT plug in for the STS HUD. 1 pin needs relocated and I need one extra wire but I have the major (and way overpriced!) HUD plug!
    Once I hear back from Daddler about the RIM HUD on/off programming is how I will proceed next. Hoping to know tomorrow (if not I fully understand), so I can plan on the 2 hour road trip to Ohio to get the dash carrier assembly with HUD provisions.
    From there Ill hit up Rippy for the dash nozzle, info control switch and plug and with 1 solid days work I'm assuming Ill be set!
    So far total cost in this project is only $25 bucks!
