Results 31 to 44 of 44
Thread: 06 3.6 srx horrible gas mileage
    ktr-sb is offline Cadillac Owners Fanatic
    Automobile(s): 06 SRX 3.6L 2WD
    Mar 2004
    427
    Re: 06 3.6 srx horrible gas mileage
    Quote Originally Posted by repnatl View Post
    And I've replaced the oil filter bypass valve so no more rattle on startup.
    Why didn't you post this to your timing chain rattle thread?
    repnatl is offline Cadillac Owners Enthusiast
    Oct 2012
    975
    Good point I probably should do that too
    Professor Wizard's Avatar
    Professor Wizard is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 SRX-4 Sport / TriCoatWhite
    May 2009
    St. Louis, MO
    62
    1,096
    I just finished a road trip - St. Louis, MO, to Omaha, NE and back... Mind you, I did get caught in a snow storm on the return, so drove sporadically and slow from Omaha to the Missouri Boarder because of the ice/snow storm. I also used the secondary highway, instead of the super highway, to avoid sharing the road with tractor trailers. I also detoured for a scenic tour along the Mississippi from Hannibal back to St. Louis- which I am sure lowered the MPG average just a bit.
    Average over the entire trip was 20.9 MPG.
    09' V6 with 64k miles on it.
    Oct 2012
    975
    Well its to the point that my 96 ram 5.2 1500 gets the same gas mileage as the v6 srx
    Bob25thTA is offline Cadillac Owners Member
    Automobile(s): 2012 CTS-V M6 Coupe WD
    Fort Worth, TX
    My 03 Corvette gets 26 mpg on highway. What kind of mileage do you expect to get when you are pushing a heavy square box through the air at 70 mph?
    Oct 2012
    975
    Lol true but the ram should be worse though you would think
    08SRX's Avatar
    08SRX is offline Cadillac Owners Connoisseur
    Automobile(s): 2008 SRX Sport Pkg
    Jun 2011
    1,049
    A few other thoughts:
    - has your air filter been replaced lately?
    - do you have any dragging brakes? Sometimes, caliper pins can get stuck. You can check to see if one wheel is much hotter than the others after a long drive.
    - do you need a tune up?
    Oct 2012
    975
    Quote Originally Posted by 08SRX View Post
    Trust me I know I'm certified lol new brakes Jo dragging aftermarket intake just did a tuneup and fuel filter my issue is this engine is worn out from previous owners neglect. I'm hearing the v8 guys get better mileage
    conedoctor is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS AWD Wagon 2010 BMW X5 35D 2008 GL320
    2,621
    With the awesome aftermarket intake as you not getting more air into the engine, would this not also need more fuel to be added to all this nice extra dense air?
    08SRX's Avatar
    Jun 2011
    1,049
    Yeah, I agree with conedoctor. If you add a custom CAI, then don't complain about your fuel mileage...
    Oct 2012
    975
    Typically intakes improve gas mileage cause the engine cab breathe better. Trust me its not the intake the engine is the problem
    2,621
    Not saying the engine is not the problem but the intake will not get you better economy IMO, you will get more power from it. Now your saying the engine is bad on gas because it is worn out, what part being worn out causes less economy? You thinking rings or valves?
    Clips from the K&N site, even they say a mileage gain is theory, if they were able to increase mileage I would think it would be all over the website and on the front page and I can't find one single thing on the site that says better mileage, maybe cause they can't prove it and it is just a myth?
    So if your flowing more air into the engine fuel must be added to keep at 14.7:1 right?
    To make more power with no ECU upgrades you have to be adding more fuel don't you?
    1. How will a K&N filter affect my vehicle's fuel economy?
    There is a relationship between air filter restriction and mileage. The theory behind this is simple, the harder an engine has to work to suck air through the intake tubes and air filter, the more gas gets wasted in the process. Many K&N users report an increase in their fuel economy after beginning to use our air filters, as noted on our testimonial page. However, these experiences do not mean you will also experience a change in your mileage. We certainly understand why it is theoretically possible for a consumer to experience a mileage increase after installing a K&N air filter or intake system, however, we do not go so far as to make a general claim that our air filters and intake systems will provide an increase in mileage.
    It is virtually impossible to make sweeping and general claims about mileage. Even the EPA fuel rating numbers for new cars are often not representative of the mileage you actually experience. There are many variables that affect mileage such as: tire inflation, the type of fuel, weather, elevation, the speed at which you drive, the gear in which you drive, the speed with which you accelerate, engine maintenance, excessive idling, cruise control, the grade of motor oil you use, and of course, the condition of your air filter. In short, mileage is complicated.
    K&N filters are less restrictive than disposable paper or synthetic air filters and K&N Intake Systems are less restrictive than the factory installed air path. So K&N filter technology could be an important tool, when combined with other elements, to help keep mileage as high as possible.
    Oh yeah, there's one more limitation imposed by science. If you take advantage of added power by driving more aggressively, you will reduce mileage. You cannot have your cake and eat it too.
    7. Can a K&N filter give my engine too much air flow?
    No. An engine can only draw in a certain volume of air depending on the engine's size (measured by such things as bore, stroke and number of cylinders). Vehicles are designed to accommodate large changes in air pressure so they can operate at sea level or at an altitude of 14,000 feet. Engine computers adjust the amount of fuel required as a result of changes in air pressure (density). Air filter restriction when the filter is new and especially as the filter loads with dust will result in lower air pressure and availability similar to being at a high elevation. High-flow air filters that were invented by K&N were designed to reduce the work necessary to pull air through the filter and to increase air pressure. Increased air pressure is one of the key elements in producing more power.
    Oct 2012
    975
    Yeah I understand now. Pretty sure its the valve stem seals
    Fort Worth, TX
    I was always concerned about K&N filtration ability and have not used them, here is a link to a guy that did a filtration test on his Miata, using various filters.
    http://www.bobistheoilguy.com/airfilter/airtest3.htm
