Results 16 to 26 of 26
Thread: Passenger Side Door Sill Plate Light
    nemosr is offline Cadillac Owners Member
    Automobile(s): 2012 SRX, 1941 61-27
    Jan 2013
    7
    Re: Passenger Side Door Sill Plate Light
    Captain, my SRX is a 2012 Luxury Edition. Since it is not Base, should I be expecting that Passenger Side Sill Plate Light should illuminatie when the door is opened? I look forward to your reply and thanks.
    TheCaptain's Avatar
    TheCaptain is offline Canadian ATS & SRX Mod
    Automobile(s): 14 ATS AWD 3.6L Performance - Son of a Gun Grey Metallic
    Moosomin Saskatchewan
    3,075
    Yes it should light up.
    FYI the Collections go as follows:
    Base -> Luxury -> (2010 has a Luxury/Performance before Performance) Performance -> Premium (2010 had a Premium Performance as well - 2.8T)
    When you turn your car on, does it return the favour? '14 Cadillac ATS Performance 3.6L AWD in Son of a Gun Grey Metallic and Morello Red Interior
    **Cadillac Owners Forum RULES & Guidelines**
    *Cadillac CANADA Online Manuals***Cadillac USA Online Manuals & Guides*
    Kauai 1 is offline Cadillac Owners Fanatic
    Automobile(s): 2012 SRX Lux; 2013 XTS Lux
    Jun 2006
    116
    I was curious after reading the above, so I experimented with my 2012 Luxury last night and this morning. The passenger-side sillplate light does NOT come on when only the passenger door is opened, regardless of the amount of external light. Both sill plate lights come on when the driver-side front door is opened. If the driver door is opened first, then closed, the interior lights remain on during the delay period. If you open the pasenger door, the sill plate light is on....but, of course, the other interior lights are still on as well.
    79666 Guest
    [QUOTE=Kauai 1;3275965]I was curious after reading the above, so I experimented with my 2012 Luxury last night and this morning. The passenger-side sillplate light does NOT come on when only the passenger door is opened, regardless of the amount of external light. Both sill plate lights come on when the driver-side front door is opened. If the driver door is opened first, then closed, the interior lights remain on during the delay period. If you open the pasenger door, the sill plate light is on....but, of course, the other interior lights are still on as wel
    Same results as your 2010 Premium
    TheCaptain's Avatar
    3,075
    Hmm, no passenger sill light with just the passenger door? I'll have to go check mine again...
    Turbo Dude's Avatar
    Turbo Dude is offline Cadillac Owners Fanatic
    Automobile(s): 2013 CTS4 Premium Coupe |Platinum Ice Tricoat
    Apr 2012
    Witness Protection (KC metro)
    129
    Quote Originally Posted by SRX CADDI View Post
    I have a 2010 premium and it does illuminate. I also had a 2013 srx base model and did not illuminate. maybe it depends if you have a base model compared to a full option pkg..
    My 2010 premo does the same
    TheCaptain's Avatar
    3,075
    Ok, my old '10, the Passenger side doesn't illuminate unless the driver's side has already opened; my '13 illuminates the passenger side upon door opening.
    Rocky4052 is offline Cadillac Owners Member
    Automobile(s): 2010 Cadillac SRX Luxury
    Apr 2014
    24
    Ok...I understand all of this. In my case, the passenger side lights up, but the driver side does not. How do you repair this? Is it just a bulb? How is it replaced??
    TheCaptain's Avatar
    3,075
    You have to find out what is damaged or non functioning in order to replace it. Which will take some electrical testing done at the source (sill plate). Maybe the door sensor isn't operating, or maybe you just need to change out the sill plate light?
    Apr 2014
    24
    Yes, but how is the unit taken apart...I see no screws or anything holding it.Don't want to break anything.
    Quote Originally Posted by TheCaptain View Post
    TheCaptain's Avatar
    3,075
    If someone has a drawing (Rippy? ) It's most likely push/pull clips. Everything is these days. Just have to find out what direction to pull (most likely straight up).
