Results 31 to 41 of 41
Thread: Engine Hot - AC off . . no temp guage . . rad fans on high
    Scotty454 is offline Cadillac Owners Member
    Automobile(s): 2007 Black Raven STS-V
    Nashville, TN
    Re: Engine Hot - AC off . . no temp guage . . rad fans on high
    Quote Originally Posted by Berger 93 View Post
    Well yesterday while doing some Christmas shopping with the wife the DIC popped up the message . .
    The temperature gauge in the cluster would not move, and the radiator fans are running on high.
    Made three - four stops and it came up every time after a few mins of driving.
    Was not hot . . the engine oil was around 163 degrees . .
    I still am on GMPP warranty . . concerned that without a SES code it will be like chasing a ghost.
    This just happened to me about three weeks ago. Exactly as you described and just when it started to get cold around here. I reset it the first two times with my scan tool, but would come back in a day or two. My car is still under GMPP, but I went ahead and replaced the t-stat last week. Its not a hard job at all...less trouble than going to the dealer. It fixed the problem and its not been back since.
    PGA2B's Avatar
    PGA2B is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 OBM CTS-V Coupe
    USA
    2,662
    Quote Originally Posted by Scotty454 View Post
    Did you keep the hose on like I said to? It really is easy. That is as long as you don't drop one of the bolts like I did. It was a perfect time to put in my 160* Stat.
    Nashville, TN
    I did take the smaller hose off but left the other one on. That way I could pull the housing up, and out of the way. The smaller hose came off really easy. If it had been stuck on there, I probably would have left it on.
    GoFish is offline Cadillac Owners Member
    Automobile(s): 2008 STS-V; 2000 STS
    Aug 2006
    Denver
    My 2008 has done this intermittently for a year or so, mostly in colder weather just as written here by others. Local dealer (live in Denver) replaced sending unit a few months ago, did not fix. Happened again yesterday and took it in this morning and they are getting TS code and replacing it today. My question is if computer is kicking this up because engine is not in expected heat range, how does it happen on cold startup? And how does it happen after I've parked and it's sat for an hour. It's up immediately upon startup. Oil temp stays fine, fans are running, I'm not seeing overheat issues, just curious how the code is there on cold startup. Reading through forum posts that's what I don't understand.
    Hopefully replacing TS is the cure, problem is a nuisance and had me in a panic first time it happened.
    neurotictim is offline Cadillac Owners Fanatic
    Automobile(s): 2006 STS-V mostly stock
    Jun 2011
    Virginia Beach, VA
    461
    I'm about to dive into this one - notice came on while I was driving to band practice. Came up again and then reset itself, I guess. I'll pick up the 160* t-stat this week and knock it out.
    KingOfLacs is offline Cadillac Owners Fanatic
    Automobile(s): 06 STS-V Allante, 2 Eldo's V8 STS CTS-V DTS CTS Fleetwood
    Dec 2011
    320
    After months of dealing with this and keeping a scan tool with me I replaced to 160 mr gasket t-stat. Been off ever since thanks cadillac forums your the sh**. I replaced with the stock t-stat the first time and p0128 kept coming back so yes Mr Gasket os the way to go.
    mjs182004's Avatar
    mjs182004 is offline Cadillac Owners Enthusiast
    Automobile(s): 91Broughamd'Elegance,06STS-V,76FWBd'Elegance,98SevilleSTS
    Dec 2008
    Eastlake, Ohio
    769
    Quote Originally Posted by PGA2B View Post
    Lol, That was the worst part of the job when I did mine! I dropped one of the bolts. I was so mad lol, it took me a while to find the darn bolt!
    2zs1v is offline Cadillac Owners Member
    Automobile(s): Sts v
    Jan 2013
    8
    I had this same thing occur on my wife's V three times.
    The first time it cleared itself up after a day. The next 2 times I cleared the code with a scanner and it went back to normal. So I'm not sure it's the thermostat at fault?
    Whitestone, NY
    3,211
    Yep it's the tstat. It'll be intermittent. You might not see it for months. But it'll be back. It's like herpes.
    mjs182004's Avatar
    Dec 2008
    Eastlake, Ohio
    769
    Quote Originally Posted by Guy.Seminerio View Post
    LOL That is Funny
    Whitestone, NY
    3,211
    Hahha yeah thanks. Except this herpes has a cure. Replace the tstat.
