Page 3 of 7 FirstFirst 1234567 LastLast
Results 31 to 45 of 92
Thread: Needed: Stock rear shock top mount (for upgrade design work by Vorshlag Motorsports)
    lollygagger8's Avatar
    lollygagger8 is offline Cadillac Owners Connoisseur
    Automobile(s): Platinum 2004 CTS-V
    Apr 2008
    Indiana
    4,913
    Re: Needed: Stock rear shock top mount (for upgrade design work by Vorshlag Motorspor
    Quote Originally Posted by heavymetals View Post
    I hate it when a vendor thinks they are doing me a favor selling me their product.
    Preach it brother!!!
    heavymetals's Avatar
    heavymetals is offline Cadillac Owners Master
    Automobile(s): 05 maggied CTS-V, 03 maggied Z06
    Nov 2004
    8,788
    Thanks to heavy for the initial lead and to you for doing the legwork!
    I gave several leads to several RSM suppliers.
    Banski (any relation to the artist?) happens to make a C5 RSM, so I know that will work in the V.
    2,045
    Actually, the C5 RSM doesn't include an eyeball plate, so it won't work on the CTS-V.
    Nov 2004
    8,788
    It will if you get the eyeball plate.
    It won't work in the C5 without the plate either.
    If you bother to read, I said you need the C5 plate.
    The V1 plate center hole is a bigger diameter then the C5's (I believe), however the dimensions and mounting hole(s) placement is the same as a C5 (that I know).
    2,045
    Based on my concersation with Tom, it sounds like the C5 doesn't need/use the eyeball plate. They interface directly with the mushroom & cap assembly. I can only surmise that a lot of vendors include a C4 eyeball plate with their kits for convenience.
    Nov 2004
    8,788
    The C5 doesn't need/use the eyeball plate at all. It sounds like a lot of vendors include a C4 eyeball plate with their kits for convenience and because they're easy to make.
    You are wrong.
    You need the plate to hold the bearing and mount to the frame.
    It doesn't work to well not mounted to the frame with the shock floating.
    You should do some research on C5 suspensions.
    There is a reason why it is called a Rear Shock Mount.
    Ya know what?
    I am not hear to argue a point that you obviously don't know anything about.
    Take a look at the AST C5 RSM and tell me there is no eyeball.
    When you get and install a pair of RSM ( with spherical bearings) take some measurements.
    2,045
    You are wrong.
    When I asked for a comparison to their C4/C5 part, but specifically referenced the C5 compatibility, Tom said that I actually needed the C4 design. If you want to argue with someone, argue with him. We both agree that the CTS-V require an eyeball plate. Design details regarding the C5 are irrelevant from here on out.
    By the way, you might want to note that I was already in contact before you Googled them and posted it up on this forum. So the forum-ites that are attributing 50% of the credit for this idea to you are incorrect. I wasn't going to bring it up until you started waving your e-peen around.
    Nov 2004
    8,788
    HAHAHAHA
    And CF people wonder why I hang around LS1.
    Ya Fuzzy, I stole all your glory.
    2,045
    Insulting the intelligence of the entire forum won't get you anywhere. We're all on both forums.
    Nov 2004
    8,788
    Your lack of intelligence is the only thing that cries out to be insulted.
    What else did you not post that you want to take credit for?
    AAIIIC's Avatar
    AAIIIC is online now Super Moderator
    Automobile(s): '05 CTS-V
    Where the Navy takes me...
    6,449
    AAIIIC's Avatar
    6,449
    Good stuff coming. Tom (president) and I have been trading measurements and CAD drawings to ensure a perfect fit. Should have more tonight and tomorrow--my schedule for today is filled with work and grad school.
    Did anything ever come of this, Fuzzy? I sourced an extra set of stock upper mounts from a FS thread over on LS1tech. Not sure if I even need those to make the Banski pieces work, but I have them just in case.
    2,045
    Yes. I let the issue drop after Heavymetals crashed the thread, but I recently began talking to Tom again. First and second blush is that the C4 part will be a direct fit, but we need to square away a potential issue with the side through-bolts on the eyeball plate before I put up an official group buy thread. The good news is that the solution will be a perfect replacement for the OEM part and include all necessary hardware (Grade 8 / Class 10.9). You can help me out by expressing your intention to buy a set, if that's what you plan to do, so that I can get a headcount and we can get these parts delivered to your doorsteps in the next couple of weeks.
    AAIIIC's Avatar
    6,449
    I will definitely buy a set. I can send him one of these CTS-V parts to compare to, if that would help.
    2,045
    It's already taken care of.
