i read allot of post here but never found one that can help my problem!
just replace radiator! got one from junk yard, mine was creaked year ago due to overheat but was solved by jb welder glue but after year start to fail. after i replace radiator i used temperature switches that was already on the radiator when i got it from junk yard, now fan between radiator and engine dont work (i tested fan it self, it work!!!!). that could cost by upper switch that next to the battery, i will try to replace it with my old one tomorrow, to see whats gonna happened!
but the biggest problem is in auxiliary water pump the one that next to the battery, it just dont work, i never notice if it was working before i replaced radiator or not. pump work it self when putting
12v on it, but from wire it self no power coming to the pump. WHY????
on passenger side pump working all the time (is it suppose to be like that ????) upper temperature switch related to that pump and please tell me how that crazy cooling system work step by step. like what start or stop to work in the order and with what temperature.
Thank you
Thank you
