Page 3 of 6 FirstFirst 123456 LastLast
Results 31 to 45 of 82
Thread: exhaust sound
    B1n2fra's Avatar
    B1n2fra is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 1SG STS v8 awd
    Nov 2011
    Chicago
    502
    I just wanted to know what the stock exhaust would sound like without the resonator. Guess I won't know untill I do it.
    shortfur7's Avatar
    shortfur7 is offline Cadillac Owners Fanatic
    Automobile(s): 2014 ATS4 2.0
    Jul 2011
    143
    Re: exhaust sound
    Quote Originally Posted by B1n2fra View Post
    I will be able to show you on Friday. I'm cutting mine out and putting in a H pipe. I will make a video and post it after that.
    B1n2fra's Avatar
    Nov 2011
    Chicago
    502
    Quote Originally Posted by shortfur7
    What's the difference between straight pipes, h pipes, and x pipes.
    CapnCurt's Avatar
    CapnCurt is offline Cadillac Owners Fanatic
    Automobile(s): 2014 VSport 2014 SRX
    Fayettteville
    107
    Re: exhaust sound
    it will equalize the exhaust pressure coming out of both exhaust pipes, so it would definitely alter the sound of the exhaust with aftermarket exhaust anyway, can't wait to hear how it sounds though.
    maiahsdad's Avatar
    maiahsdad is offline Cadillac Owners Fanatic
    Automobile(s): 05 STS AWD 1SG
    Apr 2009
    Fishers, Indiana, USA
    484
    Is this your car 1badcadsts? Or did U find this on the tube?
    1BadCadSTS's Avatar
    Automobile(s): 05 STS4
    4,224
    Quote Originally Posted by maiahsdad View Post
    That's mine. I just filmed it for this.
    Quote Originally Posted by CapnCurt View Post
    Damn Swype on the cell phone! Lol
    Sounds good, corsa has more of a harder sound sure to the smaller tip, I prefer the sound of mine though, simply BC I love three way it sounds, much deeper I'd say! Nice though!
    Smaller tip? it has dual 3.5 inch tips. The reason they state for use on the 05-07 only is the 08+ Fasica has a lower curve for the exhaust and smaller outlet, the tips wont fit unless you install a longer hanger to move them down.
    B1n2fra's Avatar
    Nov 2011
    Chicago
    502
    Re: exhaust sound
    which is better str8 pipes x pipes or h pipes and what are the differences in all. Do they all produce different sounds.???
    1BadCadSTS's Avatar
    4,224
    H pipe sound x better performance straight eghhhh
    CapnCurt's Avatar
    Fayettteville
    107
    Re: exhaust sound
    yeah smaller tip, it's smaller than my tip. bigger tip deeper tone! I'm sure you can distinguish the difference between my sound and yours.
    1BadCadSTS's Avatar
    4,224
    How big is your tip again mines 3.5 inches and the tip has little effect on the sound. The corsa runs a straight through muffler nicknamed a can no baffles. Your Gibson uses baffles which is why it is flat style. I worked at an exhaust shop for 10 years I know how exhaust systems work and flow better than most. Tips effect how it's projected not the true tone of the system.
    CapnCurt's Avatar
    Fayettteville
    107
    Re: exhaust sound
    I will measure it soon, the way a sound is reflected has allot to do with the overall sound! since no one seems to be riding around tipless its a factor that sculpts the overall sound. Would live to hear your caddy in action, get that video up!
    If you don't mind man, give me a lil more insight between the pros and cons of baffle vs straight through design. I love that popping sound when you let off the gas on your ride, my baffles are restricting that I assume.
    1BadCadSTS's Avatar
    4,224
    Difficult to drive film and play with auto stick so short idea will film better later
    Baffle can adjust sound tones that's how you can have a dohc motor sounding like a 60s pushrod motor. Corsa uses a straight flow design with an almost resignatior like perforated muffler designed to cancel out bad tones (drone) and allow the exhaust to free flow for better performance than a restricted baffle design. This also gives the true tone of the motor which is why Corsa sounds more exotic like a dohc high revving motor.
    Projection and amplification are two things tips project they don't amplify the sound. Made a tone with your mouth and cup your hands around it. If you keep the same volume throughout the difference in size does nothing to amplify the sound it just adjusts how it's projected.
    The baffles in your mufflers do far more to hinder its performance than my .5 less size tip (assuming you have a 4 inch tip to my 3.5).
    B1n2fra's Avatar
    Nov 2011
    Chicago
    502
    Re: exhaust sound
    what is this video supposed to be showing???
    malatu's Avatar
    malatu is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS 3.6 AWD
    Dec 2005
    1,005
    Re: exhaust sound
    Sound
    chazglenn3's Avatar
    chazglenn3 is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 White Diamond STS N* 1SF RWD ACC/HUD
    Sep 2004
    Tacoma, WA
    54
    1,959
    Re: exhaust sound
    Sounds very nice!
