Page 3 of 11 FirstFirst 1234567891011 LastLast
Results 31 to 45 of 153
Thread: My Trifecta ECM/TCM tuning experience - 2010 CTS-4 3.6L DI Wagon
    Wag-O-Neer is offline Cadillac Owners Fanatic
    Automobile(s): 2010 CTS-4 Wagon Premium 3.6 w/FE2
    Dec 2011
    Maryland
    214
    Re: My Trifecta ECM/TCM tuning experience - 2010 CTS-4 3.6L DI Wagon
    Quote Originally Posted by Wag-O-Neer View Post
    [B]Here's a 3rd gear pull I did, to take logs of timing advance, pre-tune. I should note that car has been running 93 octane for the past 3 fill ups.
    Looks like at 6K RPM, the stock file is running (positive)20 degrees of timing. You can also see the car pull 4* at 5220 rpm.
    datetime Timing Advance RPM
    06:40.6 36 2543.75
    06:40.7 18 2543.75
    06:40.8 18 2542
    06:40.9 17 2619
    06:41.0 17 2619
    06:41.1 24.5 2626.75
    06:41.2 24.5 2626.75
    06:41.3 12 2739.75
    06:41.4 12 2739.75
    06:41.6 12 2669
    06:41.7 12 2669
    06:41.8 12.5 2727
    06:41.9 12.5 2727
    06:42.0 12.5 2772.75
    06:42.1 12.5 2772.75
    06:42.2 12.5 2831.25
    06:42.3 13.5 2831.25
    06:42.4 13.5 2876.5
    06:42.5 13.5 2924
    06:42.6 13.5 2924
    06:42.7 13.5 2967.5
    06:42.8 13.5 2967.5
    06:42.9 15 3033.25
    06:43.1 15 3033.25
    06:43.2 15 3081
    06:43.3 15 3081
    06:43.4 15 3138.25
    06:43.5 15.5 3138.25
    06:43.6 15.5 3175
    06:43.7 16.5 3175
    06:43.8 16.5 3232.25
    06:43.9 17 3232.25
    06:44.0 17 3269
    06:44.1 17 3269
    06:44.3 17 3332.5
    06:44.4 17 3332.5
    06:44.5 17 3385
    06:44.6 18 3385
    06:44.7 18 3425.25
    06:45.8 18 3425.25
    06:45.9 17 3699.75
    06:46.0 17 3743.25
    06:46.2 18 3743.25
    06:46.3 18 3813.25
    06:46.4 18.5 3813.25
    06:46.5 18.5 3872.5
    06:46.6 18.5 3872.5
    06:46.7 17 3920.25
    06:46.8 17 3920.25
    06:46.9 16.5 3973.75
    06:47.0 16.5 3973.75
    06:47.1 16.5 4031.25
    06:47.2 16.5 4031.25
    06:47.4 16.5 4031.25
    06:47.5 16.5 4082.5
    06:47.6 16.5 4082.5
    06:47.7 16.5 4149
    06:47.8 16.5 4149
    06:47.9 16.5 4206.5
    06:48.0 16.5 4206.5
    06:48.1 18 4257
    06:48.2 18 4257
    06:48.3 18.5 4306
    06:48.4 18.5 4306
    06:48.6 18.5 4306
    06:50.0 20 4345.5
    06:50.1 20 4683.75
    06:50.2 20 4683.75
    06:50.3 20 4743.5
    06:50.4 20 4743.5
    06:50.6 20 4794.75
    06:50.7 20 4794.75
    06:50.8 20 4849
    06:50.9 20 4849
    06:51.0 20 4913.25
    06:51.1 20 4913.25
    06:51.2 21 4963.75
    06:51.3 21 4963.75
    06:51.4 21 4963.75
    06:51.5 21 5011.5
    06:51.6 21 5011.5
    06:51.7 21 5070.75
    06:51.8 21 5070.75
    06:51.9 21 5125
    06:52.1 21 5125
    06:52.2 21 5125
    06:52.3 21 5173.25
    06:52.4 21 5173.25
    06:52.5 21 5220.75
    06:52.6 17 5220.75
    06:52.7 17 5262.25
    06:52.9 18 5262.25
    06:53.0 18 5323.25
    06:53.1 18 5323.25
    06:53.2 18 5363.75
    06:53.3 18 5363.75
    06:53.4 18 5419.75
    06:53.5 18 5419.75
    06:53.6 18 5419.75
    06:53.7 18 5473
    06:53.8 18 5473
    06:53.9 18 5514.5
    06:54.1 18 5514.5
    06:54.2 18 5568.75
    06:54.3 18 5568.75
    06:54.4 18 5603.5
    06:54.5 18 5603.5
    06:54.6 18.5 5654.75
    06:54.7 18.5 5654.75
    06:54.8 18.5 5695.75
    06:54.9 18.5 5695.75
    06:55.1 18.5 5695.75
    06:55.2 18.5 5733
    06:55.3 19.5 5780
    06:55.4 19.5 5780
    06:55.5 19.5 5780
    06:55.6 19.5 5818.25
    06:55.7 19.5 5818.25
    06:55.8 19.5 5859.25
    06:56.0 19.5 5859.25
    06:56.1 19.5 5901.25
    06:56.2 20 5901.25
    06:56.3 20 5941.75
    06:56.4 20 5941.75
    06:56.5 20 5979
    06:56.6 20 5979
    06:56.7 20 6019.25
    06:56.8 20 6019.25
    06:57.0 20 6054.5
    06:57.1 20 6054.5
    06:57.2 -10.5 6054.5
    06:57.3 -10.5 5901.25
    06:57.4 -1 5901.25
    06:57.5 -1 5908.75
    06:57.6 5 5908.75
    Ok, so I did another data log, using my equipment, for a 3rd gear pull, just like the one above, which was when the car was stock. I know that it might just look like a bunch of jumbled up numbers to many, but for those that know what they're looking at, you can see what the Trifecta tune is doing, in regards to spark advance. I mentioned on the post above, that the car was pulling 4* of timing at 5220 RPM. And oddly enough, even the new tune pulls a couple degrees at the same place. I wonder if it's because IATs are rising, from the radiant heat of the cylinder head, and the ECM is pulling it. I guess I need to log IAT next time, to see. If so, then the phenolic intake spacer that I'm going to get from SC2150, should solve that problem.
    Also, unfortunately, I don't plan on adding a wideband to the car, so I don't what my AFR is. Jerry says that Trifecta tunes it a little rich for safety, and I take him at his word. There's a few hundred Camaros running this same tune, and to date, I haven't heard/read of any of them having lean issues. As part of my agreement with SC2150, I'll do a pre/post dyno after installation of the phenolic spacer, so I'll be able to see AFR, using the standard tailpipe sniffer at the dyno shop.
    Also, when you flash your car, Jerry from BNR and Vince ask you to do a data log, using their software, as soon as possible, just so they can see what's going on with the tune. I like the fact that they take a proactive approach like this, rather than wait for complaints, to look at logs. Just another reason why to choose BNR and Trifecta.
    Just to confirm, pre-tune log above, and the post-tune log below, we're with 93 octane.
    44:22.1 18 2659.75
    44:22.2 18 2974
    44:22.3 18.5 2974
    44:22.4 18.5 3010.25
    44:22.5 18.5 3010.25
    44:22.6 18.5 3041.25
    44:22.7 18.5 3041.25
    44:22.8 18.5 3077.25
    44:22.9 18.5 3077.25
    44:23.0 18.5 3105.25
    44:23.1 19.5 3105.25
    44:23.2 19.5 3146.25
    44:23.3 20 3146.25
    44:23.4 20 3174.25
    44:23.5 20 3174.25
    44:23.6 20 3204.75
    44:23.7 20 3204.75
    44:23.8 20 3250.5
    44:24.0 21 3250.5
    44:24.1 21 3302
    44:24.2 21 3302
    44:24.3 21 3351.25
    44:24.4 21 3351.25
    44:24.5 21 3393.5
    44:24.6 21.5 3393.5
    44:24.7 21.5 3442.25
    44:24.8 21.5 3442.25
    44:24.9 21.5 3490.5
    44:25.0 22.5 3490.5
    44:25.1 22.5 3550.25
    44:25.2 22.5 3550.25
    44:25.3 22.5 3591.25
    44:25.4 22.5 3591.25
    44:25.5 23 3647.25
    44:25.7 23 3647.25
    44:25.8 24 3707.25
    44:25.9 24 3707.25
    44:26.0 24 3760.75
    44:26.1 24 3760.75
    44:26.3 24.5 3823
    44:26.4 24.5 3823
    44:26.5 25.5 3875.5
    44:26.6 25.5 3875.5
    44:26.7 24 3937.25
    44:26.8 24 3937.25
    44:26.9 24 3937.25
    44:27.0 24 3990.25
    44:27.1 24 3990.25
    44:27.2 24 4053.25
    44:27.3 24 4053.25
    44:27.4 24.5 4129.5
    44:27.5 24.5 4129.5
    44:27.7 24.5 4188
    44:27.8 24.5 4188
    44:27.9 22.5 4188
    44:28.0 22.5 4249.75
    44:28.1 23 4249.75
    44:28.2 23 4314.5
    44:28.3 23 4314.5
    44:29.6 23 4377.25
    44:29.7 24 4690.5
    44:29.8 24 4749.75
    44:29.9 24 4749.75
    44:30.0 24 4749.75
    44:30.1 24 4818
    44:30.3 24 4818
    44:30.4 24 4885.25
    44:30.5 24 4885.25
    44:30.6 24 4947.5
    44:30.7 23 4947.5
    44:30.8 23 5022.5
    44:30.9 23 5022.5
    44:31.1 23 5081
    44:31.2 23 5081
    44:31.3 23 5150
    44:31.4 23 5150
    44:31.5 23 5209.75
    44:31.6 23 5209.75
    44:31.7 21.5 5272
    44:31.8 21.5 5272
    44:31.9 21.5 5272
    44:32.0 21.5 5332
    44:32.1 21.5 5332
    44:32.3 21.5 5394.75
    44:32.4 21.5 5394.75
    44:32.5 21.5 5451
    44:32.6 21.5 5451
    44:32.7 21.5 5508.25
    44:32.8 21.5 5508.25
    44:32.9 21.5 5561.5
    44:33.0 21.5 5561.5
    44:33.2 22.5 5623
    44:33.3 22.5 5623
    44:33.4 22.5 5623
    44:33.5 22.5 5672.5
    44:33.6 22.5 5672.5
    44:33.7 22.5 5726.75
    44:33.8 22.5 5726.75
    44:33.9 23 5778.75
    44:34.0 23 5778.75
    44:34.1 23 5827.5
    44:34.2 23 5827.5
    44:34.3 23 5827.5
    44:34.4 23 5875
    44:34.5 23 5875
    44:34.6 23 5923.25
    44:34.8 23 5923.25
    44:34.9 23 5971.5
    44:35.0 23 5971.5
    44:35.1 23 6013
    44:35.2 23 6013
    44:35.3 23 6013
    44:35.4 23 6060
    44:35.5 23 6060
    44:35.6 23 6099
    44:35.7 23 6099
    44:35.8 24 6145.5
    44:35.9 24 6145.5
    44:36.0 24 6190
    44:36.1 24 6190
    44:36.2 24.5 6190
    44:36.3 24.5 6232.75
    44:36.4 24.5 6232.75
    BNRacing is offline Cadillac Owners Fanatic
    Automobile(s): NONE
    260
    Thanks for all the kind words- I'm glad you like the tune!
    Anyone looking to order, here is the direct order link-
    http://badnewsracing.net/webstore/pr...roducts_id/186
    Dec 2011
    Maryland
    214
    Quote Originally Posted by BNRacing View Post
    Guys, this is the person you want to talk to, if you want the same tune I have. Since we got very detailed on the TCM calibrations, you can just ask for the same file I have on my car. Or, you can do a base file first, and adjust what you want from there. Jerry is very responsive to email, and can do just about anything you want.
    Good to have you on board, Jerry!
    Lord Cadillac is offline Cadillac Maniac
    Automobile(s): Cadillac Escalade
    Dec 2002
    Royal Palm Beach, Florida
    13,704
    Quote Originally Posted by SC2150 View Post
    Vince was releasing a updated tune today....he writes the ones for our 3.6 twin turbo and super charged builds. Very talented.
    I've spoken to Vince once before. He seems like a great guy who knows what he's doing in regards to tunes. But what's this twin turbo 3.6 you're referring to?
    Have an iPhone or Android? Then you can be connected with everything automotive in your area.
    Download the Cars Connected app for your iPhone or Android device today! Or you can check out Cadillac Magazine and Kia Stinger Forum.
    Dec 2011
    Maryland
    214
    Quote Originally Posted by Lord Cadillac View Post
    Off topic: Since you're the Admin here, can you please tell me why I can't PM?
    beanjapan's Avatar
    beanjapan is offline Cadillac Owners Fanatic
    Automobile(s): 2008 CTS
    257
    Question,
    Is the tuner locked into just one VIN? If I have two cars that can accept trifecta tunes, can I go ahead and use it in both? Or if I replace my car, can I tune my new car?
    Automobile(s): NONE
    260
    It's VIN locked
    loosend is offline Cadillac Owners Fanatic
    Automobile(s): 2008 DI RWD w/ Prem & Perf Pkgs Blk/Blk FE2
    Nov 2009
    Maryland
    132
    Cool Re: My Trifecta ECM/TCM tuning experience - 2010 CTS-4 3.6L DI Wagon
    Guys, first impression is it's worth every penny. The car feels totally different. It feels MUCH zippier and throttle tip-in is aggressive. The tranny shifts crisp in A6 mode at WOT and throttle blipping on auto downshifts is a nice touch. Driving at part throttle still gives you nice, comfy, lazy shifts, just like stock. You throw it into sport mode and not much changes at part throttle, but at WOT the car shifts like a '69 Chevelle with a hurst shift kit. Smiles.
    Did you select the hardest shift available when in sport mode? I think it is indicated by the percent of the reduction of the torque management. Some of the Camaro guys can chirp a gear but its probably not good for the tranny in our particular vehicles since there is not much tolerance for increased power capacity. My "72 Chevelle has a B&M valve body kit and a few other tricks and chirps 1 to 2 and 2 to 3 shifts at WOT which never gets old even at 46 years of age. ; P
    Dec 2011
    Maryland
    214
    Quote Originally Posted by loosend View Post
    I'm not sure if they tuned it for maximum reduction of TM, or not. I can tell you that the shift firmness is progressive, as it relates to throttle position. With very light throttle input, the car appears to still has the same shift firmness as stock. However, as throttle input increases, so does the quickness at which the cogs are swapped inside the slushbox. To the point that at WOT, the car shifts very quick, and firm. Since my car is AWD, I'm not chirping gears, nor would I want to.
    Maybe Jerry from BNR can chime in as to how firm they set it.
    Nov 2009
    Maryland
    132
    Since my car is AWD, I'm not chirping gears, nor would I want to. Maybe Jerry from BNR can chime in as to how firm they set it.
    Didn't realize you were AWD and that will make a difference in the way it shifts and the performance numbers due to weight and having another axle. I was just wondering about the percentage of TM reduction to use as a reference so maybe Jerry will chime in. Eventhough chirping tires sounds cool, I would not want to be breaking parts in the trans or the multiple universals in the driveline. Again, THANKS for giving us all something to chew on and breathing new life/excitement to this board.
    Dec 2011
    Maryland
    214
    No problem, I'm glad to share my data with the forum. Kinda the whole point of these things, right?
    I was actually very surprised to see the lack of performance modding threads in here. I thought for sure, since the car shares the same engine as the Camaro, that I'd see tons of threads, but nope. Outside of a few exhaust and CAI threads, there just wasn't much.
    Hopefully we change all that.
    Automobile(s): NONE
    260
    I'm not 100% certain what Vince set your shift firmness at, but I can tell you that we don't ever take it to the point that it could cause any harm.
    Dec 2011
    Maryland
    214
    Yeah, figured as much. I really love the fact that it's totally progressive as it relates to throttle input.
    Bad News Racing has earned my word of mouth, to anyone that will listen to me.
    BTW, check your email. Sent you and Vince some logs about IAT.
    Automobile(s): NONE
    260
    Thanks. Yeah I saw the email last night
    kingtj is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS4 Coupe, Premium edition
    Dec 2011
    Poolesville, MD
    234
    Yeah, that was my same thought when I first joined the forums. I guess I assumed (perhaps falsely) that at least the customers opting for the coupe version of a newer CTS would be more performance-minded. The ironic thing is, I think I've actually seen more performance interest out of the wagon owners than anyone else, on the whole. They like the idea of building a "sleeper" that surprises people, or simply get a kick out of having a true "sport wagon" in a category of vehicle where performance is usually just an afterthought.
    I will say one thing though. So far, it seems like the upside to this is we're generally seeing only really *good* performance upgrades offered. Vendors seem to be taking the time to release products or services that are done right, as opposed to trying to make a quick buck selling sub-standard stuff. That's what made me give up my Genesis Coupe in the end; too much money shelled out for performance parts that had fitment issues, didn't live up to their claims, and created new problems they wouldn't admit to or help buyers correct.
    I'll take quality over quantity any day -- so PLEASE keep up the informative posts sharing good info!
