Page 9 of 12 FirstFirst 123456789101112 LastLast
Results 121 to 135 of 170
Thread: Project "VANQUISH" Widebody kit for CTS-V
  1. #121
    yooper's Avatar
    yooper is offline Cadillac Owners Enthusiast
    Automobile(s): Escalade ESV and Caddy powered Chevy
    Michigan
    576
    Re: Project "VANQUISH" Widebody kit for CTS-V
    Quote Originally Posted by atdeneve View Post
    Any idea as to when we'll get to see the end result?
    Also, would you be able to integrate vents (seamlessly) on the rear side of the flares that would aid in evacuation of built up air from within the wheel wells?
    IMO a properly designed undertray should eliminate air cavitation in the front wheel wells.
    Quote Originally Posted by zzilla View Post
    The rear diffuser is something we have looked at, but we are going to wait untill we see what it does on the track. We did have one version of the rear bumper lower than it is now but it made the car look like a spaceship.
    zzilla, I would like to volunteer as the chase car with camera mounts. This project is sweeeeet!
  2. #122
    soflarick's Avatar
    soflarick is offline Cadillac Owners Enthusiast
    Automobile(s): none
    Florida
    626
    I built a DIY front undertray for a Miata I used to own. It incorporated a 1"-1.5" splitter as well, as the nose of the car easily allowed for the addition. I extended it rearward to the cross beam of the engine cradle, as wide as possible from wheel well to wheel well without the tires touching at full lock, and as close to the control arms but with room for them to move without interference. Driving without it and with it demonstrated it had an enormous improvement on front stability at highway speeds. Can't say I noticed an improvement in engine cooling, but one must be cognizant of not making the tray so long that it blocks airflow through the engine bay. A heat extractor hood was eventually added, and the front stability and coolant temps were again significantly improved. So much so that I had to add a rear spoiler to compensate. I used 1/8" black ABS plastic, and it held up quite well, even in parking lot dings. If I had gone more than an inch or two longer on the splitter, I would have added supports, but I think less than 2" of splitter won't require additional supports. I think the V would require 2 pieces; one behind the front air dam and a second piece in front for the splitter. I think if tabs were left on the ABS, they could slide into the existing slots for the air dam, and once secured with fasteners, provide additional front aero. Again, I wouldn't go overboard on the splitter length, or supports would have to be added.
    If one built a tray behind the front air dam, either the existing factory tray would have to remain intact, or the DIY tray would have to be secured to the existing panels so that at least the current level of sealing in front of the radiator were maintained. Airflow leakage around the front of the radiator is a significant factor to consider.
    One good thing about 1/8" ABS is that a heat gun on a low setting is good enough to mold it to tighter shapes without much effort. Too much heat will bow or melt it, and weaken it.
  3. #123
    zzilla is offline Cadillac Owners Fanatic
    Automobile(s): cts v-xlr v
    Jan 2009
    158
    Hi All, UPDATE.......
    I have been swamped but we are finally making the production hood this week. The rest of the panels are done, after the hood is finished everything gets block sanded then it is off for the motor and all the other goodies (In boxes) that have been taking up my garage space for way too long.
  4. #124
    shadybx7's Avatar
    shadybx7 is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Platinum CTS V-Headers+3in pipes
    Apr 2008
    3,014
    any new pics?
  5. #125
    Faber is offline Cadillac Owners Fanatic
    Automobile(s): None :(
    Cincinnati, OH
    407
    So...any updates?
  6. #126
    lilgCTS-V is offline Cadillac Owners Enthusiast
    Automobile(s): 06CTS-V BOLT-ON,06JEEP TJ BUILT, 91 350SDL turbo(daily)
    Nov 2008
    967
    yea that ^
  7. #127
    Jan 2009
    158
    Quote Originally Posted by Faber View Post
    So...any updates?
    Still Block Sanding Photos will be avail when it is completed
  8. #128
    I hate my AMG is offline Cadillac Owners Fanatic
    Automobile(s): 04 Black LS6 CTS-V
    Oct 2011
    Northern Jersey !
    25
    153
    Bump! !! Post new pics!!
  9. #129
    Mr.Tickles's Avatar
    Mr.Tickles is offline Cadillac Owners Member
    Automobile(s): 04 CTS-V, 66 Hearse, 78 Hearse
    Aug 2008
    Carriere, MS n New Orleans, La
    Pics?
  10. #130
    yooper's Avatar
    Michigan
    576
    UPDATE...........
    Rear bumper, side rocker panels, right fender are done. Glassing left fender today. Front bumper next week, then the hood.
    Production panels are very light (have not weighed yet for true numbers)The Fiberglass that we have used is for aircraft so it has an amazing amount of flexibility for fiberglass. Things are moving along.
    Anymore photos will not be released untill the car is finished that way you will be able to get the whole picture instead of production bits.
    How's the drivetrain coming?
  11. #131
    Skidmarcx's Avatar
    Skidmarcx is offline Cadillac Owners Fanatic
    Automobile(s): NONE!
    May 2011
    Phoenix, AZ
    39
    356
    I've browsed over the thread... And wow nice work!... Doesn't seem like a bad price at all considering the work involved. I like it
  12. #132
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    51,885
    This thread died...
  13. #133
    Junior1's Avatar
    About to pass you...
    1,248
    zz, Angelo says hello...
    Few questions: looking to do some aero, where are you at with the rear wing? and regarding the hood, any status on carbon fiber? otherwise whats the weight on the glass one?
    PM me if you want...
  14. #134
    yooper's Avatar
    Michigan
    576
    Quote Originally Posted by thebigjimsho View Post
    This thread died...
    Nope, this is going to be another badazz V
  15. #135
    Rakenjevnk's Avatar
    Rakenjevnk is offline Cadillac Owners Fanatic
    Automobile(s): CTS-V
    May 2011
    Calgary, AB
    350
    can't wait for pics, this thread is on the lottery list :P
