Results 31 to 45 of 45
Thread: Turning off traction control, stability control completely, totally not what u think
    stl_ls1gto is offline Cadillac Owners Fanatic
    Automobile(s): 2013 CTS-V wagon M6, 2011 GMC Sierra CCSB 6.2L, 2004 GTO
    Nov 2005
    St. Charles, MO
    371
    Re: Turning off traction control, stability control completely, totally not what u th
    There is something to this....my 2011 6.2l sierra does this as well, I hold down the traction control button, and first the dic says traction off, then a couple seconds later it says stabilitrack off. Now, at this point, if stopped, you can burn out or powerslide
    doughnuts till your hearts content. But if you go above a certain speed, it seems the stabilitrack reactivates without flashing anything on the dic. Dont know what speed, but I am sure it cuts in as the track light flashes when the back ends slides around pretty good and the slide is stopped the power is cut and certain wheels are braked.
    CavemanB52's Avatar
    CavemanB52 is offline Cadillac Owners Connoisseur
    Automobile(s): 2012 CTSV coupe
    1,583
    To the OP... I have a manual coupe that was doing he same thing and I could not figure it out so I thought there was something wrong with the switch. And started toggling the switch the other way to make sure there wasn't some re-contact turniing the Nannies back on. Turns out that is what that button with circle and "x" over top of it is for. After you turn the nannies for what ever mode you want press the circle with the x over it and it deactivates all of those buttons on the left of the wheel it will even turn off cruise control. I thought it was a place hoder of somesort of feature I didn't get. But if you press it after holding down the traction button for 6 to 9 seconds your nannies will not come back on. I'm not sure what the rest of the thread started talking about sounds complicated. Try this man. And let me know if it worked for you.
    2012 CTS-V is offline Cadillac Owners Fanatic
    Automobile(s): 2012 Cadillac CTS-V
    105
    I press my traction control button twice and it shows that the traction control and stabilitrak are turned off and then it says competitive mode. Competetive mode means that there are no nannies on right? BTW when my traction control is totally turned on the car doesnt run the same compared with when I have it fully off. With it fully off the car moves alot better and Im talking about from a roll on... Car has tune intake and upper pulley
    CavemanB52's Avatar
    1,583
    No. Just pressing it twice does not turn every thing off. You have to hold it down and wait for 6to9 seconds or so. Competitive Mode will still activate nannies. it just lets you get slightly out of shape before turning on.
    105
    I have a 2012 and when I hold it down for 10 seconds it disable Tc and stabilitrak but doesn't say competetive mode but when I press the button twice it disables both and says competitive mode
    CavemanB52's Avatar
    1,583
    Correct.
    V locity's Avatar
    V locity is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 CTS-V A6, 752 RWHP Stock airbox & stock exst
    Jan 2012
    Katy, TX
    1,110
    I don't have any issues on mine with it coming back on in "off" mode. However, I got tired of hitting the button every friggin time I got in the car. So, I modified it in the tune. They no longer NAG me
    SecretWeapon is offline Cadillac Owners Fanatic
    Automobile(s): 2009 Sedan, M6, Silver/Ebony
    Spring, Texas
    457
    Quote Originally Posted by V locity View Post
    My wife nags me. Can you figure out how to re-program her?
    V locity's Avatar
    Jan 2012
    Katy, TX
    1,110
    Quote Originally Posted by SecretWeapon View Post
    Sounds like a little too much spark?
    CavemanB52's Avatar
    1,583
    Turn down her volume on your intake...
    Jan 2006
    22
    I was wondering what this "X" button did as well. I found nothing in the owners manual either. I realize that they (GM/Cadillac) has to protect themselves, but unless I read on this forum about holding the TC for 5+ seconds, I would never know it shut off Traction & Stability completely instead of just hit twice for competitive mode. I would assume the X button resets after restart, correct ? Thanks for figuring this out.
    Quote Originally Posted by CavemanB52 View Post
    baabootoo's Avatar
    baabootoo is offline Cadillac Owners Connoisseur
    Automobile(s): Red/Blk 2016
    May 2010
    Racine, WI
    3,786
    Quote Originally Posted by Luna. View Post
    Yeah, but what I want to know is HOW IS IT POSSIBLE FOR THE SYSTEM TO AUTOMATICALLY TURN STABILITRAC BACK ON WHEN IT'S TOTALLY BEEN SHUT OFF?
    Yes, that happens, apparently in some high hp, manual, Vs, like mine.
    Sh*t, I'll seriously PAY someone for the answer to this mystery...
    What makes you think it gets turned back on anyway?
    V Wagon is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS-V Wagon-Raven Black, manual, satin graphite wheels
    Jun 2011
    Clawson, MI
    374
    I was at an auto cross that had some fun runs at the end and just drifted through them, no issue with stabilitrack coming in and I was really hanging it out.
    However, I was recently at Memphis international raceway during power tour. Stabilitrack completely off, not just T/C. Power shifted third, got quite a bit of wheel spin, hit 4th and the car fell on its face. After the third gear shift stabilitrack had actually tuned itself back on.
    susanmarc is offline Cadillac Owners Member
    Automobile(s): CTS-V (manual)
    I attempted to reply privately (you have exceeded your storage space) and by email and by phone first-
    Jesse,
    I bought the handheld programmer from you when I first bought my 2009, which was when they first went on sale (I think mine was one of the first manuals in the midwest). When I purchased it you stated that you may have updates from time to time which may be available online, and to date I have not had any. I have even called and emailed you about this, to no avail. Please let me know if there is an update available, since mine was one of the newer ones you probably tuned.
    wait4me's Avatar
    wait4me is offline Cadillac Owners Connoisseur
    Automobile(s): 11v,2 09 v's,2 05 v's,5 GTM supercars,viper,volt,2012 karma
    Jan 2009
    warsaw indiana
    2,997
    Hi, I am always available by phone or by email. I did a search and nothing with your name showed up??? jessebubb@ya hoo.com with no spaces. Ill check what your revision was, and tell you if you need another email data set sent to you. Tunes haven't changed much for the manuals though, they where all dyno setup for every mod combo, only changes made where for the auto cars, where I was doing the staging of gear fluid storage events.
