Page 13 of 77 FirstFirst ... 3456789101112131415161718192021222363 ... LastLast
Results 181 to 195 of 1146
Thread: CadillacPimpinNOLA's 95 Fleetwood buildup 56K your computer will blow up
  1. #181
    Quote Originally Posted by CadillacPimpinNOLA
    order the switch extensions, paint them to match the body color
    I was thinking that (hoping you weren't going to leave them as is lol) It'll set them off and tie them into the rest of the painted interior parts.
    It's coming along nicely. Details MAKE the car IMHO, and you get them right.
  2. #182
    CadillacPimpinNOLA is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 Fleetwood 1968 coupe DeVille
    Jul 2009
    Metairie/New Orleans,LA
    1,152
    Re: CadillacPimpinNOLA's 95 Fleetwood buildup 56K your computer will blow up
    thanks and yea definitely painting the extensions, they only come in 4 colors, red s one of them but its clear with sparkles in it
  3. #183
    beatz02's Avatar
    beatz02 is offline Cadillac Owners Fanatic
    Automobile(s): '94 FWB; '94 STS
    Gardena, CA
    136
    Curious to see this 2 18 box. Come on with it! lol..
    I'm thinking about 2 15" AA SMDs, but I don't know if I have the space. They have that double magnet, and they need a lot of airspace.
  4. #184
    Jul 2009
    1,152
    im taking donations, I need to get to home depot and pic another piece of MDF up so i can have enough wood to finish the box...I wont lie im running on fumes with this slow work stuff. ill prolly go spend $30 today on the wood. the side panels of the box are going to be the hardest. once its done i can build it, modify it to get it in and out if need be and then i can check for proper airspace...im in your boat i dont know if i can get all i need but im going to try.
    then I need 2 gallons of resin and some fiberglass mat. instead of using 3/4 MDF and loosing valuable airspace where the spare tire and jack goes, im going to glass the floor to get all the space i can..b/c of the metal floor it doesnt have to be thick, just seal the box
    again, taking donations.
    im also kinda stuck. i need the box done but i need the airbags for the weight. if i do the bags now i have to rip the lines out the valves and remove the tank to get the box in...soon, soon
    if i feel strong later i may post pics of the subs
  5. #185
    Jul 2009
    1,152
    ok, its nice out today, got a lil work done, taking a break and about to eat something, may go do some more work later
    when i did the switch box to cigar tray, i didnt want to remove the rear seat, pull the sill plates up ect so i just snipped the harness, now i gotta get it crimped back together under the carpet
    and its gone
    from there I used the wire i bought the other day to extend the switch box harness into the trunk so i can wire the valves up, not pictured, i didnt have big enough heqatshrink so it got taped up.
    thats 1 18", for refereance
    go a tiny bit done with the box. of course it cant fall into place, had to modify the back board top and bottom
    fits now
    wires will need to be moved and pinned up later
  6. #186
    The Marshmallow is offline Cadillac Owners Fanatic
    Automobile(s): Has: 1997 Deville, 2008 VW GTI Stage 2+, now with K04 turbo
    Nov 2011
    135
    Very impressive work. Sub'd for more updates.
  7. #187
    Stingroo's Avatar
    Stingroo is offline Cadillac Owners 10000+ Posts
    Automobile(s): '92 Caprice Wagon LS1/T56 | '01 Buick Century | '95 Lexus LS400
    Vero Beach, FL
    18,417
    Oh god. I want that thing so bad.
    If only I could afford that kind of cargo space....
  8. #188
    beatz02's Avatar
    Gardena, CA
    136
    How many cubes does Fi recommend for that sub?
    And have you ever tried 13 layer birch for a box? Hear it's stronger and lighter than MDF.
  9. #189
    Jul 2009
    1,152
    birch is stronger, lighter and almost twice the price, never worked with it just for that reason. id have almost $200 in birch if i went that route.
    Fi recommends 5-10 cubic foot per sub. ported only and rated for 1000rms. the owner says that just to be safe, if you have clean power then 2000rms all day long. ill be giving each sub right around 1,750rms...i figure 2 subs, bare minimum 5 cubicfeet for each sub...im gambling being close after sub displacement and port. worse comes to worse ill but a new baffle and have a large box for 1 sub and and be able to upgrade to beefier sub since i would have an extra sundown 1500 amp.
    the sub is an 18" BL with cooling, p chamfer, dual 1ohm, flatwind voice coil and for daily use, thats the options i got for them.
    after taking a break today and watching the packers get whipped I went and done a lil more work.
    I cut a few more boards for the box, ima try to get some resin soon. I still dont even want to mess with the side panels. ima get it in though, so that for the most part is done
    had to reconfigure the air valves since the new pressure sensors hit and i couldnt run them how i had them. came up with a better way, i really like it more and it also makes it easier when it comes time to adjust the valve mufflers (quiets the air noise but also adjust lowering speed)
    the vertical valve has the electrical hookup turned down now so it will look real clean, now i need to get a "T" so i can use my tank pressure and pressure switch in one hole, have to get a drain petcock for the bottom and 2 water traps and I can paint the tank and have it almost done.
    left is new, right old
  10. #190
    Jul 2009
    1,152
    with any progress comes setbacks. went to home depot looking for a 1/8" "T" fitting so i could install the tank pressure and pressure switch...went against what i would usually do if it would work. they didnt have a 1 peice fitting but a 3 female "T" i figure use a threaded nipple and ill be good...yea that worked untill i decided to install the tank pressure sensor. anyway ill order one soon, glad i got the peices out of my adapter fitting. also they did not have a drain cock or water separators.
  11. #191
    dennis93coupe's Avatar
    dennis93coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 1993 Coupe Deville, 2009 XLR-V 1 of 6 Crystal Red
    Orange County, CA
    62
    2,479
    That's what I hate about low budget brass. Don't know how much you are willing to pay for fittings, but you might want to consider Machined Steel High Pressure Threaded Pipe Fittings. I have an old book but you can check online www.mcmaster.com They have about anything you could ask for. I used to chase all over town sometimes until a friend led me onto them decades ago. You could also save some time with the air lines by using push lock type fittings. They have a sleeve you push the hose in and hold the sleeve in and pull the hose back out if you need to disconnect for some reason. They eliminat compression fittings that always either mess up threads on the fitting or leave the hose a one time use.
  12. #192
    Jul 2009
    1,152
    the hose fittings are like your describing but they hold the hose tight so you really need to pull on it to get it out...im about to go to sears to exchange a ratchet and hopefully pick up a draincock and two water separators and see if they have an 1/8" brass nipple with a HEX so i can hold a damn wrench on it.
  13. #193
    Jul 2009
    1,152
    ok, take 2 and 3, went to sears for lunch and no water separators or draincocks, got my ratchet replaced though.
    so I just went to harbor freight, picked up 2 separators, 2 1/4 nipples, then back to home depot for another "T" and grabbed 2 1/8 nipples just in case and yes i messed the threads up on one so I saved myself headaches and a 3rd trip.
    a lil blurry but you get the idea
    noticed some messed up threads so thanks to some expensive snap-on tools i tapped the whole, ill pressurize the tank and blow and shaving out.
    pressure switch for the compressors (left) and tank pressure for the gauge (right)
    just need a drain instead of a plug cuz i dont need a rusty tank and it will be ready for paint, Im one step closer
  14. #194
    That tank looks sexy with the fitting on there.
  15. #195
    Jul 2009
    1,152
    between no work, rain, ect I tried to get in the trunk at midnight last night and get some panels fitted, didnt go so well with no light. found a use for the jack as a 3rd and 4th hand, box sides still need to be cut on the bottoms. got a lot left to do
    pics kinda suck but it was late
    notched around the tension lift rods
    i really hope i got this right b/c i guessed at it, ill find out later
    cut a side, not finished but on for now
    some areas still need to be cut
    other side on
    1st baffle front view
    two 3/4" boards "Double Baffle"
    the way i had to trim the rear board to fit, im going to have to make a piece on each side to fill these gaps
    SEX, two 18" Fi audio BL's...its going to be tight and heavy
    hope I have enough room to fit a port in there at the top of the box between the subs
    im wore out just from carrying the subs, need some fiberglass resin and mat to do the floor o the box, a lot more time, money and wood working.
    it is getting there
