Page 12 of 77 FirstFirst ... 234567891011121314151617181920212262 ... LastLast
Results 166 to 180 of 1146
Thread: CadillacPimpinNOLA's 95 Fleetwood buildup 56K your computer will blow up
  1. #166
    CadillacPimpinNOLA is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 Fleetwood 1968 coupe DeVille
    Jul 2009
    Metairie/New Orleans,LA
    1,152
    Re: CadillacPimpinNOLA's 95 Fleetwood buildup 56K your computer will blow up
    got in this morning and sanded a lil bit, have a lot more to do and definatly have to reprime but somethings getting done.
    quick pass with the sander shows the low spots
    went through the primer to get it flat but was expecting that
    few more passes, its getting smoother, my hand is vibrating from the sander so ill give it a rest for a lil while
  2. #167
    cadillacmike68's Avatar
    cadillacmike68 is offline Cadillac Owners Connoisseur
    Automobile(s): 68 DVC, 96 FLTWD Brg, 09 STS N* Platinum, 11 CTS Premium
    Left the desert - Back in FL
    56
    1,303
    That was a great buy. I paid almost 6K for my 1996, with 70,000 miles, but i was able to drive mine home from SC to FL that same day, and mine has no body damage. Heck, it looks new inside and out.
    Yeah, and i have no pics to load at present, but it will soon...
  3. #168
    Jul 2009
    1,152
    my friend was mad for a while when i got mine b/c he spent $8,500 on his 95 with around 40k miles, in about 70 more miles im going to hit the 34k mark
  4. #169
    Jul 2009
    1,152
    been spending money like crazy, gotta slow down. anyway bit the bullet and ordered the dakota digital air gauge, came in today, now have to mount it and get some wire to wire it back to the pressure sensors on the tank and valves
    displays readings of 4 airbags and tank pressure from 0-150psi
  5. #170
    Jul 2009
    1,152
    havent messed with the dash since we had a lil bit of work, still tons of sanding left though...my gauge came in and its warm today so i got a lil work done. no tape measure nothing i just eyed it up and layed some tape down for a guide, impressed myself with the cut...anyway got it mounted in the panel, had to trim the front mounting bracket on the panel. so im sure ill prolly have to fab something up to hold the front, i wont know till i trim the mounting bracket under the headliner. ill do that monday when i can use the dremel tool and the shop vac so i dont have a mess of black plastic all in the car.
  6. #171
    Jul 2009
    1,152
    no work so i got a lil bit of work in before it started raining...stopped at the stereo shop and grabbed a bunch of wire for several projects, some for the air gauge is just bought...i manage to make a mess with fine plastic after cutting the plastic bracket in the roof. it doesnt look great but its relieved and hidden. wire it up and pulled wires through the headliner...looks great, bright to. hook it up just to see the display...then it started to rain so this is all i got today
    crude cut and wires waiting
    dont need the dimmer feature or low pressure warning
    view from head position, off
    closeup off
    closeup on
    head view on, i can see it perfect and bright
    im thinking about buying 10 red rocker switch extensions and removing all 10 switches from the cheap red lexan switch box and installing in the dash where the cigar tray is. i dont smoke and think it will look good
  7. #172
    I would recommend building a high quality switch box if you can. I just went through an episode with a 66 Lincoln on airbags that had a bad switch box and no schrader valves. The connection would come out of the box and not go in without major problems. Moral of the story...install schrader valves!!!! Will save you 4 days of trying to trouble shoot a bad air ride system.
    That is a nice cut on that panel, too
  8. #173
    Jul 2009
    1,152
    the switches are good its just a bulky lexan box, id rather have them mounted on the dash...i dont know what id need schrader valves for, everything in this system is electric
  9. #174
    Lets say, like my case, the air ride stops working and the car is slammed. Now you cant drive it and have no way of getting air to the shocks/bags. You can put schrader valves(valves used at the tire to fill up with air) inline with the plumbing to each shock/bag. This way, if the controls go out for the air ride, you can manually fill each shock/bag with as much air as you want.
  10. #175
    Jul 2009
    1,152
    im not going through that extra trouble. if that happens ill have it towed. maybe in the future but right now i just want to get it installed
    no work again, im low on cash to, this sucks but ill get through it as always.
    pulled the cigar try and cut the switch box out
    expose the guts, id hate to have to wire these up all day, about 8 wires were not tight on the switch so i tightened them up
    all marked and removed
    some tape and used the holes in the switchbox for spacing
    drilled holes and cut some bracing out, will need to glue it tomorrow hopefully
    trying to capture the screwup but the flash is hiding it, on 4 holes the drill bit in and jerked and cracked a few peices of the plastic surface, thankfully i cleaned it up and with washer for the switches, it hides everything
    switches in and tight
    cigar tray out
    still need to get and paint some switch extensions, the gap is from me cutting the internal bracing, when i glue it tommorow it should pull up and close the gap
    dont have to reach far to hit the switches now. once i glue it together i can run the wire under the carpet and patch the harness back together.
  11. #176
    Jul 2009
    1,152
    a lil glue this morning, im going to let it dry a day before putting it back in, sure hope i glued it in the right spots
  12. #177
    Buxton, Maine, United
    4,192
    looks good man. that's a great looking installation.
  13. #178
    Jul 2009
    1,152
    pulled up perfect, stuck it in a lil while ago
  14. #179
    Much better.
  15. #180
    Jul 2009
    1,152
    yes it sure is, before i glued it, it was bouncing around a lil bit...when i get some money again ill order the switch extensions, paint them to match the body color and put them on...few more things to do then i have to find some downtime to get this stuff installed.
