Results 46 to 60 of 94
Thread: Cadillac Owners Manuals - Download
    FitzerCaddy's Avatar
    FitzerCaddy is offline Cadillac Owners Member
    Automobile(s): Cadillac Eldorado
    Nov 2006
    Ohio
    Re: Cadillac Owners Manuals - Download
    Thanks for the help guys. We just bought a 97 Eldorado and the dealer just happened to lose the owners manual. I found one with your help. I will come back here with any questions we have.
    Thanks again.
    dennii825's Avatar
    dennii825 is offline Cadillac Owners Member
    Automobile(s): 1997 Eldorado~1999 Escalade
    May 2006
    Reading Pa.
    78
    thanks for the link guys
    perpitrator is offline Cadillac Owners Member
    Mar 2008
    Hey there I tried the link you had below but it took me to a gm website i entered all this info about my car and no luck anybody else have that happen i would like to get my hand on a manual for a sts 1994 ......
    Projects is offline Cadillac Owners Member
    Sep 2008
    they changed their website. go
    gm.com/gmownercenter/
    u'll need a yahoo ID, then add a car on profile, then, u can download user manual under 'MY Dashboard'
    corribm is offline Cadillac Owners Member
    Do you have an address for this site as the link you posted only gets me "Not Found
    The requested URL /pdf/go2content/manual/US/en/cadillac/ was not found on this server."
    Soutigo is offline Cadillac Owners Member
    Automobile(s): Cadillac Seville SLS 1996
    Berne, Switzerland
    39
    41
    Another site for manuals:
    safemanuals.com/brand-user-guide-instructions-owner-manual/CADILLAC
    no subscription needed, although only models from 93-2005 covered
    82,262
    coinshooter is offline Cadillac Owners Member
    Automobile(s): 2005 sts
    13
    Here is a link to some manuals and other reading for the 2005 STS all are PDF files
    http://www.c5dreamer.com/sts/05/manuals
    gordymac's Avatar
    gordymac is offline Cadillac Owners Member
    Automobile(s): SRX
    Apr 2005
    Atlanta, GA
    From the 02 STS manual:
    Use regular unleaded gasoline with a posted octane of
    87 or higher. However, for best performance and for
    trailer towing, you may wish to use middle grade or
    premium unleaded gasoline. If the octane is less than 87,
    you may get a heavy knocking noise when you drive.
    If it is bad enough, it can damage your engine.
    From the 08 SRX manual:
    If your vehicle has the 3.6L V6 engine (VIN Code 7),
    use regular unleaded gasoline with a posted octane
    rating of 87 or higher. For best performance or trailer
    towing, you could choose to use middle grade 89 octane
    unleaded gasoline. If the octane rating is less than 87,
    you might notice an audible knocking noise when you
    drive, commonly referred to as spark knock. If this occurs,
    use a gasoline rated at 87 octane or higher as soon as
    possible. If you are using gasoline rated at 87 octane
    or higher and you hear heavy knocking, the engine
    needs service.
    If your vehicle has the 4.6L V8 engine (VIN Code A),
    use premium unleaded gasoline with a posted octane
    rating of 91 or higher. You can also use regular
    unleaded gasoline rated at 87 octane or higher, but
    your vehicle’s acceleration could be slightly reduced,
    and you might notice a slight audible knocking
    noise, commonly referred to as spark knock. If the
    octane is less than 87, you might notice a heavy
    knocking noise when you drive. If this occurs, use a
    possible. Otherwise, you could damage the engine.
    If you are using gasoline rated at 87 octane or higher
    and you hear heavy knocking, the engine needs service.
    Edniceville's Avatar
    Edniceville is offline Cadillac Owners Member
    Automobile(s): 2000 Seville SLS
    25
    Question Re: Cadillac Owners Manuals - Download
    George, I just tried doing this and there must be something wrong with the site. I get to the add a vehicle step, and I get an error on page message and it won't go any further. I tried it with two different browsers, and got nothin'. If you know any "magic words", I am listenin'!
    Ed
    HUF's Avatar
    HUF is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 FWB 118,*** miles
    Dec 2005
    MA
    2,125
    I have found this link. Have not tried though.
    http://www.tradebit.com/filedetail.p...manual-instant
    pablocadi is offline Cadillac Owners Member
    Automobile(s): ElDorado 73
    Oct 2009
    54
    Hello from Spain....any manuals for 73eldorado?
    brgds
    cheapocadillac is offline Cadillac Owners Member
    Automobile(s): 1995 deville,1994 seville sls
    Jan 2010
    hello,
    I just bought a 1994 Seville( because the price was cheap)...seller says it needs solenoids in transmission.
    the car stays in second gear. I have worked on cars that were much older and simpler. I do not posess complex transmission "special"tools.
    ..Is this a job I can attempt?..Is this a common problem with these cars? The northstar engine sounds good and doesent seem to have any compressoion/head gasket issues....what do you think? ...Thank You
    I am adding some info to clarify
    Last edited by cheapocadillac; 01-14-10 at 12:41 AM. Reason: I just joined this site and I am trying to figgure out all the posting procedures
    56,808
    Wrong place to post this - post in the main forums, not sticky threads - these are for permanent access to information, not repairs.
    Also look down in Cadillac Technical Discussion, Northstar Performance.
    dragnflyblu is offline Cadillac Owners Member
    Automobile(s): Cadillac Fleetwood Brougham D'Elegance
    May 2009
    Washington
    Well i just left the above site in disapoinment! I tried to register and the site wont let me because for one my 1967 Cadillac Sedan DeVille is not registered, it is sitting in my garage for the restoration. does anyone here have an owners manual here for a 1967 Cadillac Sedan DeVille that they have in PDF form or, can you scan it on to your pc and e-mail i to me?
    I would be very greatfull!
