Page 10 of 11 FirstFirst 1234567891011 LastLast
Results 136 to 150 of 160
Thread: Wheel Picture Thread
  1. #136
    Manofmetal01's Avatar
    Manofmetal01 is offline Cadillac Owners Fanatic
    Automobile(s): 06 CTS-V Kooks 1 7/8, Corsa, KW Var 3, Hotchkis sways
    Apr 2012
    Alberta, Canada
    183
    Fap fap fap
  2. #137
    Apr 2012
    Alberta, Canada
    183
  3. #138
    V-twin is offline Cadillac Owners Fanatic
    Automobile(s): 06 CTS-V w/ Katech headers, Magnaflow, short shifter
    Sep 2013
    Chandler, AZ
    119
    Re: Wheel Picture Thread
    Quote Originally Posted by Mn800r View Post
    Forgestar 19x9 & 19x10
    Quote Originally Posted by Manofmetal01 View Post
    I love the red CTS V with the gunmetal Forgestars. I'm thinking about buying some for mine (don't worry, I'm in AZ so I doubt we'll ever park next to each other).
    Do you have any rubbing or fitment issues? My V is still at stock height, but I'd like to bring it down some (maybe .5 to 1.5 inches lower) in the near future, so I don't want to buy wheels that will have problems with lowering. Are you both running H&R springs with MM spacers? Any other mods required (trailing arms/control arms?, etc.)? Did you roll your fenders? Would you recommend these wheels?
  4. #139
    Apr 2012
    Alberta, Canada
    183
    Rubbing will be an issue if you don't deal with it. I'm sitting on KWs and had them at their lowest setting, both rears rubbed on the inside fender. Had to raise the rear. That being said I've got stiffer springs as per fuzzys recommendation that I will be installing tomorrow.
    I should note that, even though I raised the rear, the springs are still soft enough that some bumps cause rub. And some spirited driving did cause one of my tires to grab a fender, pulled it a lil bit and sliced the tire all the way around. Luckily it didn't blow but it cost me a new tire. So new tire, stiffer springs and inside fender fix tomorrow. I'm hoping I can lower it back down a 1/4" or so in the rear.
    Other than all that, effing love the wheels and having 10" in the back. I do notice the difference vs stock.
  5. #140
    Sep 2013
    Chandler, AZ
    119
    Thanks for the reply. Do you have any rubbing in front? It looks like you're pretty low... do you have any idea how much lower than stock you are?
    I'll pose the question to everyone else with the Forgestar F14 wheels, too. Any rubbing at stock height or slightly (1" or so) lowered?
  6. #141
    Mn800r's Avatar
    Mn800r is offline Cadillac Owners Fanatic
    Automobile(s): 11 V Coupe, 05 V Mod'd, 91 Fatboy,98 Ultra classic, 07 Tahoe
    Jul 2012
    Scandia MN
    383
    I'm not going to go into any long speach on how f***ed these rims were spec'd out. Bottom line is if you want to look cool and putt around like you got a 4cycl. Buy them. If you want to drive the way the car was designed then don't. I'm contiplating selling and going back to stock so I can drive the car prior. Yes I've done spacers and adjustments,still rubs(scratched up side walls look like chit) in hard corners, $250 a hoop and it gets old real fast.
  7. #142
    Sep 2013
    Chandler, AZ
    119
    Thanks for the bottom line answer. That's what I was looking for. I've done that on other cars, cut up wheel wells and rolled fenders, trying to fit wheels/tires that were too big. I don't want the hassle with this one. Your car looks awesome, but I'd rather be able to drive it without worrying about rubbing or blowing out a tire.
    Can you recommend a width/backspacing that works (other than stock)?
  8. #143
    citationtech is offline Cadillac Owners Member
    Automobile(s): 2005 CTS-V
    Team Dynamics 18x9 in flat black, no center caps. Tires are Toyo Proxes in 275/35. Roads are salty so driveway pictures are all I have for now.
  9. #144
    AAIIIC's Avatar
    Automobile(s): '05 CTS-V
    Where the Navy takes me...
    6,447
    For the sake of others reading this thread in the future, I think it's worth nothing that there are a number of other folks running the Forgestars who don't have all of these fitment issues. I'm not sure what the issue is - alignment and ride height, perhaps?
    Linea Corse Venetos, "hyper silver", 19x8.5"/10", 245/40-19s up front, 275/35-19s in the rear. Car is lowered ~1-1.5" on KW coilovers.
    Mille Miglia wheels, long discontinued. 18x8" +38mm (as I recall), stock suspension, stock tire size. These were on the car, with snow tires mounted , when I bought it used in the summer of 2007.
    GM Accessory wheels, same specs as stock (18x8.5" +42mm), stock suspension, stock tire size:
    Rota Torques, "hyper black", same specs as stock (18x8.5" +42mm) with stock tire size, stock suspension:
    Same wheels, lowered on the KW coilovers. Car was filthy after a track event (note the front wheels aren't as blingy as the rears due to all the brake dust):
  10. #145
    2,045
    It's probably better if you sell them. We all tried, but apparently your bullheadedness can't be fixed. More info:
    http://www.cadillacforums.com/forums...l#post10500353
  11. #146
    AAIIIC's Avatar
    6,447
    Linea Corse LC855s, 19x8.5/10", not sure on suspension mods and tire sizes since this isn't my car:
    Another car, same style of wheels:
    And another:
  12. #147
    2,045
    IMHO, Rand49er has the sexiest V with LC855s.
  13. #148
    JD03Cobra's Avatar
    JD03Cobra is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 Thunder Gray 6MT
    Mar 2008
    Michigan
    2,122
    Agreed and they look way better in person!!!!
    And Lollygagger8 Forgestar wheels. Love em.
  14. #149
    BassHead1237 is offline Cadillac Owners Member
    Automobile(s): 2005 CTS-V, headers, Corsa exhaust, UUC short shifter
    Jan 2014
    North Carolina
    Just got my V a week ago and love it. Previous owner put MHT Monotec T03 20" rims and I really dig them. Hope I don't dent em cuz I do not want to pay for a replacement!badillac 04-26-10.jpg
  15. #150
    2,045
    Have any more pictures? I'd love to see more of that Extreme Composites hood.
