From another forum, posted by a track junkie buddy... there are some improvements made to Summit Point.
I was at Summit Point on Saturday with ___ instructing for SCCA's PDX. I'm happy to report that Summit has made some marked improvements in the name of safety.
First off, the pavement is still holding up. There's a change in grip at the large asphalt patch at T1, not a big change in grip, but it's noticeable. But everywhere else around the track, the pavement is still good and holding up. The dip and bumps at T9 give that turn character IMO.
T3 received a significant improvement. First off, all the gravel has been graded and smoothed out and it's not strewn all about. Second, they cleared a good 150' of trees from behind the gravel so that if you run off and need more runoff room than the gravel can provide, there is now a huge, flat field that you can use. At the end of the field is a small berm that should provide the final barrier to get you stopped (albeit while damaging the car), should you run THAT far off track, which is unlikely.
T10 coming on the front straight, the berm that is on the outer edge, track left, has been flattened. This is Bobster's berm, right? Now, if you run off the track outside of or after the rumble strips, there is a long, flat area for you to safely get the car slowed down and to smoothly pull it back on to the front straight. With all the rains, it's a huge mud pile right now as they're not totally done grading the land yet. However, if you wanted, you could drive down the entire front straight in the grass now, whereas before, that berm came up pretty quickly. It seems that people would try to avoid that berm, yank the wheel and would end up in the tire wall on the inside of the track. Now, you no longer need to do that.
Finally, all the flag stations now have new and, in my opinion, more visible gazebos. I think they may even sit a bit higher than they did before, which is a good thing.
So, I'm happy to report that Summit Point is improving. Rumour has it that they main bathrooms in the paddock are shut down for renovation, but that's all hearsay at this point.
