Page 3 of 1117 FirstFirst 12345678910111213531035031003 ... LastLast
Results 31 to 45 of 16749
Thread: What did you do to your car today?
    slk230mb's Avatar
    slk230mb is online now Moderator
    Automobile(s): Now: 2008 STS-V, 1960 Eldorado Brougham Then: 2002 Escalade
    Bayside, NYC
    5,826
    Re: What did you do to your car today?
    Quote Originally Posted by slk230mb View Post
    Dropped the STS-V off at the dealership for a check engine light. None of the gauges were reporting anything out of the ordinary, waiting for the diagnosis now. First mechanic visit since I got it last August.
    Bad PCM, thank you warranty!
    ~Steve
    OffThaHorseCEO is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 ATS Premium 3.6, 1989 Allanté
    Jul 2005
    Fayetteville NC
    4,513
    dropped it off for an alignment.
    Stingroo's Avatar
    Stingroo is offline Cadillac Owners 10000+ Posts
    Automobile(s): '92 Caprice Wagon LS1/T56 | '01 Buick Century | '95 Lexus LS400
    Vero Beach, FL
    18,421
    The front end of those is very appealing, but I never did like the rear styling. Not bad though.
    Back to the thread:
    After classes today, running by Advance Auto to get my battery tested. I think its on its way out. Took about 5 seconds of cranking to get the wagon to start yesterday, plus this battery has been killed 4 times in the last 3 months from stupid crap from my friends. No biggie, I got it for free from a nice guy at my dad's job.
    gdwriter's Avatar
    gdwriter is offline Cadillac Owners 10000+ Posts
    Automobile(s): 2010 CTS (Elvis) 1964 Impala (Betty) 1991 Miata (Dolly)
    Aug 2005
    Independence, OR
    14,317
    Quote Originally Posted by submariner409 View Post
    Gary, open the hood and reach your fingers around behind and under the plastic radiator sight shield (cover) - there's a molded-in channel that the top radiator hose clips into for just that ^^^ purpose.
    I looked when I picked the car up, and the hose is behind that clip.
    Which made me just realize, this is likely my own damn fault. I changed out the headlights a couple of months ago, and you have to remove that cover to get to the headlight assemblies. So when I put it back on, I must not have put the hose behind the clip.
    Yet another reason why I shouldn't work on my cars myself. It always comes back to bite me in the ass.
    You need to buy a Service Manual for Hoover - he'll keep you out of trouble.
    Sevillian273's Avatar
    Sevillian273 is offline Cadillac Owners Connoisseur
    Automobile(s): 69 Thunderbird | 90 Seville | 89 Marquis | 72 Torino
    Oct 2008
    Palm Bay, FL
    2,024
    The MPG makeover:
    Switched from 19lb to 16lb injectors
    180deg back to 195 thermostat
    Tires: 225/60s (4% too small), back to 215/70s
    MMO piston soak (google it): Removed carbon build up caused by the large injectors = No more spark knock!
    Dremel wheel to the distributor contacts. The MSD 6A totally rapes distributor caps. But it s good for 1mpg calculated
    Dash mounted vacuum gauge (helps to lighten my lead foot...)
    Re-enabled the viscous converter clutch. Might be good for 1mpg? Certainly is annoying though...
    Previuosly 15mpg, hoping to get 18 again at least!
    The car is absolutely no fun to drive anymore....
    Oct 2008
    Palm Bay, FL
    2,024
    Quote Originally Posted by Stingroo View Post
    Battery is fine if you can crank for 5 seconds. Fuel or spark issue.
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    51,885
    Put it up for sale on Autotrader...
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,607
    Quote Originally Posted by Sevillian273 View Post
    The MPG makeover:
    Oh? I never knew you disabled it. It should be nearly undetectable if everything is working properly. As far as mpg's, it's worth quite a bit if you consistently cruise 40mph or above - more than 1mpg in my experiences.
    What are those 16 #'ers out of?
    Oct 2008
    Palm Bay, FL
    2,024
    I dont like the feeling when it engages. It's very subtle but Im sensitive. It feels like Im suddenly towing something out of nowhere. I put a switch in between it and the ECM.
    The feeling is similar to the way a Ford AOD takes forever to downshift... Hard to explain..
    The injectors are out of early 90's BMW M series. 16.7 lb/hr
    Oct 2004
    Oak Creek, WI
    5,607
    Yeah, I know that feeling very well (I hate the AOD). I think I know what you mean. Doesn't sound like typical behavior for these cars though.
    ThumperPup's Avatar
    ThumperPup is offline Cadillac Owners Master
    Automobile(s): not anymore 2007 Lexus ES350
    Murray/ Snowbird Utah
    7,688
    Took the Caddy For a Car Wash then went threw the drive up ATM
    then back home
    Oct 2008
    Palm Bay, FL
    2,024
    Its not nearly as pronounced as the AOD. Lol, not even close!
    Stingroo's Avatar
    Vero Beach, FL
    18,421
    Yeah. I'm leaning toward spark. Battery tested good at 786 CCA. Bought a cap and rotor today, and new wiper blades (it's so nice to be able to SEE in the rain!). Dad bought me plugs and wires over Christmas, but we never got around to installing them, so he's mailing them to me so I can do the whole shebang. Should be good for my gas mileage too.
    Also, @Sevillian: Poor you. I get better gas mileage in my mondo-wagon. lol Hope your tune up is as successful as you hope.
    Automobile(s): ZIP
    51,885
    Quote Originally Posted by ThumperPup View Post
    then back home
    through!
