Results 16 to 30 of 38
Thread: *** FAQ - DIY - Guides - How-To - Manuals ***
    CTSUK's Avatar
    CTSUK is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 Cadillac CTS 3.6 Sport Luxury
    May 2012
    United Kingdom
    717
    Re: *** FAQ - DIY - Guides - How-To - Manuals ***
    Trying something currently see how this goes will update once more have uploaded and see how long this lasts, let me know how the links work out for you some of them allow online reading and some may have to be downloaded (guess its the mass amount of pages!):
    Service Repair PDFs
    Generic Trouble Codes
    GM Trouble Codes
    2.8L Engines
    2005:
    Engine: 1 2 3 4 5
    2006:
    Introduction
    Troubleshooting
    Engine: 1 2 3 4 5
    3.2L Engines:
    Engine
    Drive Belt
    Oil Pan
    Timing Belt
    Timing Belt Replacement
    Engine Exhaust
    Engine Cooling
    3.6L Engines:
    2005:
    Engine: 1 2 3 4 5
    2006:
    Introduction
    Engine: 1 2 3 4 5
    Engine cooling
    Engine electrical
    2003 related PDF's:
    Drive belt routing
    Computer relearn
    Owners Manual
    Cooling fans
    Starter
    Wiring diagrams
    2004 related PDF's:
    Hydraulic brakes
    Sunroof
    Steering column
    Power steering
    Wiring diagrams
    2005 related PDF's:
    Maintenance
    Cabin air filter
    Keyless entry
    Variable effort steering
    Horns
    Drive axle limited slip
    HVAC 1 2
    Automatic transmission: overhaul | troubleshooting
    Wheel drive shafts
    Universal joint
    Front suspension
    Navigation system
    Electric components
    Frame underbody
    Cruise control
    Defogger
    Interior trim
    Parking brake
    Rear suspension
    Clutch
    Wiring diagrams
    Manual transmission ay6
    Entertainment
    Wiper washer
    Disc brakes
    Exterior lighting
    Manual transmission tremec 6 speed
    Antilock brakes
    Seats
    Instrument panel
    Engine electrical
    Airbags
    Doors
    2006 related PDF's:
    Wheel driveshafts
    Windows
    Wiper washer
    Wiring diagrams
    Seats
    Sunroof
    Suspension general diagnosis
    Steering column
    Rear suspension
    Rear drive axle
    Programming and setup
    Power steering
    Tyre pressure monitor
    Maintenance and lube
    Navigation
    Parking brakes
    Manual trans ay6
    Manual trans tremec 6 speed
    Maintenance light reset
    Limited slip diff
    Interior trim
    Horns
    Hydraulic brakes
    Instrument panel
    HVAC 1 2
    Front suspension
    Exterior trim
    Lighting systems troubleshooting
    Entertainment
    Exhaust
    Electrical component locations
    Driveshaft
    Disc brakes
    Doors
    Cruise Control
    Clutch
    Cabin air filter
    Bumpers
    Body front end
    Antilock brakes
    Owners manual
    Computer integrating system
    Auto trans troubleshooting
    If anyone has the 2007's to add let me know ive all of 2003-2006 mostly
    Here is the owners manual though:
    2007 CTS owners manual
    CTSUK's Avatar
    May 2012
    United Kingdom
    717
    Once the 2003 PDF's have uploaded that will be me for the day uploading wise lol, I would strongly suggest you grab them while you can though if you haven't a copy!
    2004 PDF's added today!
    2006 added, 2005 could take a little longer as some are quite big pdf files!
    CTSUK's Avatar
    May 2012
    United Kingdom
    717
    Will upload the rest of 2005 later as most of the files are over 30-50mb pdf's
    Hope you guys are managing to view them all ok?
    CadillacAsAlways's Avatar
    CadillacAsAlways is offline Cadillac Owners Enthusiast
    Automobile(s): 2003 CTS 3.2L, Luxury Sport, Diamond White
    Pittsburgh, PA
    659
    I didn't look at all 7 pages to see if someone had listed a DIY for this, but it wasn't in the first page.
    Is there any way we could get a DIY for removing the rear trunk bezel?
    I'm thinking of taking mine off to clean the inside of it, as it looks very water spotted and dirty on the inside. (I have an 03 CTS with the greyish clear plastic bezel).
    Not only would this DIY help people with my type of bezel to clean it, it would also assist someone of you wished to replace the old style bezel with the new one.
    Like say you had this...
    And wanted this....
    CTSUK's Avatar
    May 2012
    United Kingdom
    717
    Rear bezel removal is relatively simple.
    Remove your trunk lid carpet liner, most of it will pull off and the panel clips will come with it if not use needle nose pliers or a panel pin removal tool.
    once you have that off there will be some 10mm nuts to remove (you will see the thread for the bolt sticking out of the holes with like a star type head to it) that are sunk into holes you will need a deep 10mm socket for these, remove all of them and the panel will then come loose, after that you need to disconnect the wiring harness and then you have a panel free from the body.
    Could have done a guide last week lol as I was fitting a reverse camera to my CTS and had to remove that panel.
    Pittsburgh, PA
    659
    Thank you! That's helpful. You probably have the metal bezel, so I guess I'd have to figure out a way to get inside the plastic housing to clean the clearish grey plastic.
    And I have to ask, do have the nav system and were you able to hook it up to that monitor or did you install another monitor?
    CTSUK's Avatar
    May 2012
    United Kingdom
    717
    My filler panel is plastic not metal, only the bootlid part is metal, as for getting within the inside it might require a little heat to separate them possibly but without seeing one in the flesh i wouldn't like to say all the euro ones come without that as standard, never know there might be some more things to unscrew inside as most of the lights are held in by hex screws.
    must separate though as they sell them on ebay! http://www.ebay.com/itm/2003-up-Cadi...a7be88&vxp=mtr
    Pittsburgh, PA
    659
    I would agree they must separate somehow...seeing as water gets inside it anytime I wash my car or it rains. It slowly drains out but that is what primarily leaves the ugly, grimy, water spotted look. It's not noticeable from more than 3 feet, but it IS the trunk and you DO notice it when you are lifting the trunk open.
    I would assume a seal is broken but can't see it from simply looking at it. I would also assume this issue is one of the reasons Cadillac switched to the metal bezels. Looks cleaner, more high quality.
    Personally I like the look of the darker bezel though...it nicely contrasts my white diamond paint. I wish the plastic was a blackish color rather than brownish clearish grey, actually.
    CTSUK's Avatar
    May 2012
    United Kingdom
    717
    If you manage to separate it you could use a tinting spray then seal it up with some decent adhesive water resistant sealer
    this is the best online parts catalog that i've found so far (at least for the illustrations and part numbers)
    it's basically GM's official parts catalog for dealers to set up and use as an online store
    the relevant page you're looking for is: http://parts.nalleygmc.com/showAssembly.aspx?ukey_assembly=376168&ukey_make=1 023&ukey_model=14463&modelYear=2006&ukey_category= 19512
    looks like they don't sell the mufflers separately from the whole exhaust assembly (which is pretty expensive!)
    the three differences look to be with or without NDB and with V92
    i'd guess that you have NDB since it is a dual exhaust RPO code and it's more expensive (as you would expect the dual to be more expensive than the single)
    GR-CTS is offline Cadillac Owners Member
    Automobile(s): 2010 Cadillac CTS
    May 2008
    21
    I'm looking for steps to replace oil cooler on 3.2L engine, and specifically how to get the oil cooler lines out of the way to pull the oil cooler out. Thanks, Ken.
    CTSUK's Avatar
    May 2012
    United Kingdom
    717
    Please add this to the first post for newbies, I would not be surprised if there are a few people doing the same thing lol!
    Coil pack numbers:
    Stu
    Kingoftypos is online now Cadillac Owners Master
    Automobile(s): 06 CTS Sport/Luxury package
    Apr 2009
    Ledyard, CT
    9,277
    Spook is offline Cadillac Owners Member
    Automobile(s): 2006 cts 1985 eldo 1956 coupe
    Oct 2013
    12
    Was wondering how to "trim" the metal divider for the clear fog light mod, looks to flimsy for my disc sander.
    Also .. mine has missing "chrome" .. has anyone found a "chrome paint" thanx
    Apr 2009
    Ledyard, CT
    9,277
    How to replace an alternator on a 2.8L, should be the same with a 3.6L.
    http://www.cadillacforums.com/forums...cts-2-8-a.html
    KOT
