Results 46 to 60 of 101
Thread: Must Read All New CTS-V Owners !!
    gonfishin is offline Cadillac Owners Connoisseur
    4,150
    Re: Must Read All New CTS-V Owners !!
    Quote Originally Posted by snzuloz View Post
    Is this including the torque converter? Doesn't sound right to me.
    Page 5-133 and 5-134 of your 2009 manual lists the fluid capacities.
    Transmission
    six speed auto is 6.7 quarts
    six speed manual is 4.0 quarts
    Bushidopupil is offline Cadillac Owners Enthusiast
    Automobile(s): (V)icious Coupe
    FL Panhandle
    709
    I have an appt. to have the Oil,trans,rear diff, and coolant changed on Monday. We will see what is up with the levels.
    4,150
    Check for any oil leak associated with TSB 05-06-01-034J
    FL Panhandle
    709
    Quote Originally Posted by cbloveday View Post
    Roger, thanks! Will report back.
    Lady3bglover's Avatar
    Lady3bglover is offline Cadillac Owners Fanatic
    Automobile(s): NONE
    Alvin, Texas
    51
    103
    Quote Originally Posted by CTS-V-TWIN View Post
    I agree to check all fluids, but I wouldn't change out the factory trans fluid. The Dexron 6 is a very good synthetic fluid and doesn't have to be changed out for a long time.
    I would change the engine oil and rear diff fluid and check all other fluid levels.
    Does a deep tran pan come on the V?
    FL Panhandle
    709
    So I went to the dealer today to get my fluids checked. They looked at the referenced TSB and found no leaks. They also checked the rear diff. and the fluid level was perfect.
    I decided to skip the coolant, and trans check. The Oil I will change on my own. They did not even charge me a dime! I thought I would have at least gotten charged for a half hour labor but nothing... The tech did want to know why I thought it might be leaking/low. I told him that I just spent allot of money on the car and I had heard stories and wanted to be proactive rather find something after damage was done and have to get something replaced.
    C66 Racing's Avatar
    C66 Racing is offline Cadillac Owners Enthusiast
    Automobile(s): 06 CTS-V (sold)
    Oct 2006
    King George, VA
    680
    Adding to the discussion on the OLM, I had four oil samples drawn on my 06 CTS-V which was my daily driver from 06-09. My commute was very short (about 5 miles) and the OLM counted down very quickly due to the startup temp and operating temp degredations mentioned above. Despite using a good oil, I chose to change my oil out at 25% remaining on the OLM. Based on these four samples (oldest Mobil 1 5w30 and most recent three AMSOIL 0w30) that was a slightly over-conservative point to change the oil, but the OLM overall proved to be a good tool to use to change the oil:
    Cadillac CTS-V Used Oil Analysis
    And although GM has replaced Dexron III with Dexron VI, I'm still a little skeptical of factory fluids. In my tranny (Dexron III) the fluid had sheared low out of grade in just over 10k miles. Dexron VI will almost certainly perform better, but I'm still in the camp that recommends replacing the factory fluids sometime very early in a car's life.
    2006 Cadillac CTS-V Used Oil Analysis ATF Transmission Fluid
    chicaboom's Avatar
    chicaboom is offline Cadillac Owners Member
    Automobile(s): NONE
    San Francisco
    67
    On the transmission why don't you switch over to the Amsoil synthetic fluid?
    09cts-v is offline Cadillac Owners Member
    Automobile(s): V
    Quote Originally Posted by newcadman View Post
    Excellent advice.
    Always good to think in terms of,"an ounce of prevention is worth a pound of cure"!
    very true
    Domsz06 is offline Cadillac Owner
    Automobile(s): 2009 CTS-V, 2007 Z06
    Houston Area
    2,843
    so where is the change procedure for the auto tranny fluid? or where to tell if your low or not? My car is going on my lift tonight to change the oil, and I wanna check the tranny fluid level since I think it's slipping...
    ideas?
    I know we have it posted somewhere here, but search and google are drawing a blank.
    GMRetiree Guest
    Sorry, I don't believe this post. I've heard these myths a thousand times.
    Quote Originally Posted by Stephen P. View Post
    In 1970 I worked at a Cadillac Dealership in the new car service garage.
    Insufficient power - running rough = one entire piston and associated connecting rod, etc. not installed.
    Banging, rattling in fender = pop bottle wired/suspended inside right fender just ahead of right front door.
    Dash emblem in Sedan Deville read: Eldorado/ door insignia = Seville/ Trunk ID = Coupe DeVille
    Wierd interior sounds, = right internal sail panel trim missing.
    Transport driver while unloading car - this car has a custom (????) exhaust = no exhaust at all.
    I should have kept a diary.
    My CTS V Coupe arrived August 12. At just over 700 miles, we had Rear Differential, Transmission, and Engine Fluids changed. Coincidentally this flushed all the manufacturing debris and likely improved longevity of the car.
    I asked the mechanic to show me how it was done (therefore verifying correct fluid levels).
    SLIM6.2 is offline Banned
    Automobile(s): cts-v
    Feb 2011
    11
    i just bought a used cts-v 2009 sedan and in the morning when i leave for work the rear-end wines when u turn to the left or the right but the sound clears up when u straigten it out...... this is helpfull info....thankx guys
    Feb 2011
    11
    and my boy has an 06 or 07 stock z06 he blew the engine running a lambo they tested the oil to make shur he was runnin mobil1 synthetic...he said they told him if he wasent it was not covered under warranty......not shur if thats going to be the same deal with the cadillac but just sumthin to think about
    sushanthsuresh is offline Cadillac Owners Member
    Automobile(s): None
    Feb 2011
    Try checking the viscosity of the oil by rubbing it in your finger tips. Once you get the hang of it, its really helpful.
    The reason to change it in the first 500mi is
    --> During the initial stage "run in" machining takes places between the piston and cylinder in small amounts. The machined metal(Scrap) flows through the oil. So it is advisable to change it within the first 700 miles.
    A way to check it. Some engines have a metallic drain plug. So the metal parts get attracted to this drain plug. When you check the drain plug between the first and second service you can notice that the first once has more(relatively) metal powder compared to the second one.
    Xtreme70SS is offline Cadillac Owners Fanatic
    Automobile(s): SRX, STS-V
    Apr 2011
    131
    This is great information for us new owners. Thanks!
