Results 46 to 60 of 96
Thread: The definitive h&r / mm spacer lowering thread
    EdmundGTP is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 CTS-V
    Tempe AZ
    612
    Re: The definitive h&r / mm spacer lowering thread
    Yeah.. There's nothing inherently "wrong" with the MM/H&R combo by itself. Like Wes said, the spacer is only a means to adjust the height of the rear of the car. The MM/H&R combo by itself lowered the rear of my car about a half inch more than I wanted it to, so this spacer raised it back up to where I wanted it. I only showed pics of the front in my most recent picture post, to illustrate that when you raise the back of the car up by a half inch from the MM/H&R only combo, that the wheel gap becomes the same at both the front and rear wheels. I much prefer the look of a uniform wheel gap at all four corners, rather than some gap at the front wheels, and a slight tuck at the rear wheels. I did nothing at all to the front suspension because I liked, and still like, the height that the H&R springs left it at.
    WesH8398's Avatar
    WesH8398 is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 CTS-V
    Sarnia, Ontario, Canada
    897
    Hey Edmund... Have you noticed any 'settling' at all (spring sinking into rubber)? My 2 sheets came in today, so I'm looking forward to tossing these cut OEM's and getting my h&r's back in there.
    By the way, what'd you cut this stuff with? Utility knife do it?
    Tempe AZ
    612
    Havent noticed any extra settling. When I first let the car down from up on jack stands the rear fenders were at 26.25 and after driving for a couple miles they dropped to 26.0 even. They're still at the same height after about 80 miles of driving. I don't really suspect they'll go down more but I'll keep an eye on them. Cutting the sheets is a bit of a trick. I used a really beefy pair of kitchen shears to cut the OD of mine and used a utility knife to cut out the centers. Cutting the centers will probably take a little trial and error to get just right, but you'll want to make the ID big enough so that it sits totally flat in the suspension arm, but fits snugly around that inner lip that sticks up. Basically cut it so it fits in the suspension arm like the picture I took shows. The nice thing about these pieces is that they don't have to be "pretty" by any stretch, and they'll work just as well with a ragged edge as a smooth one.
    PrelateBishop is offline Cadillac Owners Fanatic
    Automobile(s): 2005 CTS-V
    Mile High
    129
    This is excellent news. EdmundGTP, you are to be commended for your ingenuity and follow-thru. Having read many a lengthy post on this issue, this clever workaround gives me just about all the confidence I need to move forward with this mod.
    Thanks!!
    Mile High
    129
    Thanks!!
    Tempe AZ
    612
    Just glad I can throw some useful experience and knowledge out there once in a while.
    WesH8398's Avatar
    897
    Agreed, thanks Edmund. I think I'm going to get these spacers in when I put my new trailing arms on. Hopefully that's sooner rather than later!
    Tempe AZ
    612
    Yah, I'd like to hear how it works out for you when you get to it.
    Tempe AZ
    612
    Couple more pics of the resulting "stance". Just because..
    Mile High
    129
    Quote Originally Posted by EdmundGTP View Post
    Will you STOP making me want to spend money?!!
    All joking aside, your car seriously looks sick. Mine is going to look nearly identical when I get the rear tail/reverse lights painted and the suspension work done.
    By the way, you running the stock tire size?
    Mile High
    129
    For my own edification, reposting some of your pics.
    BEFORE
    AFTER
    Tempe AZ
    612
    Tires are 255-40-18. Could easily fit 255-50-18.
    WesH8398's Avatar
    897
    THE 'EDMOD' IS OFFICIAL!!
    I followed your lead today Edmund, and the results were PERFECT. I used the same 3/8" stuff that you linked above and it gave me that 1/2 inch extra height with the H&R springs. No more "reverse rake", no more tires biting fenders (still gonna roll 'em tho, just to be safe), and no more unstable rear end from the cut OEM springs. Oh, and the mighty mouse spacers are still doing their job spot on too. I put 250 lbs of sand bags in the trunk, drove around for 10 minutes, then stopped and hopped out to see real quick. The shocks were "pumped up" right to where they are with no weight in the trunk.
    While I was at it I got my MAP trailing arms installed too. I'm no longer 'driving on eggshells' as I have been for the last 3 weeks, and it feels GREAT!
    Thanks for the idea Edmund. I think s separate thread needs to be started for this mod, so it's easier for people to find. I'd be happy to supplement it with my own pics/info if you'd like too!
    Tempe AZ
    612
    Glad it worked out for ya!
    z28firefighteri1 is offline Cadillac Owners Member
    Jun 2011
    Fort Lauderdale
    14
    I just got a 06 CTS-V last week and it has the Eibach springs in it, the front is to low for me and I haven't taken the front wheels off to look at the way the fronts put together. Do you think the same rubber washer idea would work for the front springs?
