Results 16 to 30 of 69
Thread: So maybe I'll just make a DIY Heat Extractor hood
    AAIIIC's Avatar
    Automobile(s): '05 CTS-V
    Where the Navy takes me...
    6,463
    Re: So maybe I'll just make a DIY Heat Extractor hood
    Quote Originally Posted by bneal1022 View Post
    I do not believe placement matters as much as the size. Given fluid dynamics.....would these not simply work like venturis? The rushing air across the top will cause a low pressure and draw air up through the vents while in motion?
    You can't have it both ways. As you said, size is important - you want the things to be big enough to move enough air that they actually make a difference. But, the bigger they are, the less that venturi effect is going to work - you have some pressure difference between the relatively stagnant air underhood and the fast moving airstream on top of the hood, and the larger the area of the vent is, the smaller the differential pressure. You'll see on a lot of race cars that there's some sort of wicker on the leading edge of the hood vents to help generate a greater D/P.
    And, just to clarify, placement does matter as far as where the radiator is. Going back to the Volvo S80 diagram I posted before, you can see that the light blue (lowest pressure on top of the hood) is towards the front. To maximize the D/P and make the vent more effective, I would want to put it in that light blue zone. But if I do that the vent is probably in front of or maybe right on top of the radiator, which means it's not doing much to help air flow. That's the mistake I made on my Mustang's hood - the hood vents I had added are too far forward, so I don't think they're as effective as they could've been a couple inches farther back.
    MIAdragon is offline Cadillac Owners Fanatic
    Automobile(s): none (yet)
    Jan 2010
    Miami
    112
    Im already looking for a hood to try this out on, hope to find one this week!
    MO POWA! is offline Cadillac Owners Fanatic
    Automobile(s): CTS V
    May 2009
    140
    Any updates on this? im looking forward to your results im sure i'm not the only one. I really like the z34 vents. I need some vents on the hood to dissipate some heat.
    kirchbed's Avatar
    kirchbed is offline Cadillac Owners Fanatic
    Automobile(s): 2004 CTS-V
    Sep 2008
    Washington, DC
    337
    You can't have it both ways. As you said, size is important...
    So, any updates w/ the z34s?
    Off topic question: any track days coming up w/in a 5 hour drive? I'm jones'n for a track day and since Luke had to cancel for November I can't wait until 2011. Also, how to you transport your track wheels/tires in the V?
    AAIIIC's Avatar
    6,463
    Quote Originally Posted by MO POWA! View Post
    Quote Originally Posted by kirchbed View Post
    I'm not sure when I'll actually get around to trying this. It's honestly not near the top of my list of vehicular projects, but I might get to it at some point this fall/winter.
    I'm running Summit Point Main with the NCC BMWCCA on 10/16-17. Not sure if they still have any openings left (and no, I'm not a BMWCCA member). After that will be VIR Full in mid-November with the PCC Audi Owners Club - still need to actually register for that one (yes, I am an Audi Owners Club member, but Audi ownership is not required to become one). That may turn into a 3 or 4 day event, as Trackdaze is running the Mon/Tue after Audi's weekend event. Hmmmm...
    crankedupforit's Avatar
    Cheese land
    1,596
    Pat has it right with the Z34 vents. I picked up a complete set. Only problem is the drip pans are a no go. If you squint you can see them in my not so good dark garage picture. You'd need to be a bit creative to modify them.
    The side mount vents just are not sexy enough.
    Here's the best spot and I'm sure Pat agrees. My body guy can mount and paint for $500.00. A good value for an extractor hood that should really work.
    Cheese land
    1,596
    Double post. Ooops.
    AAIIIC's Avatar
    6,463
    I still have my set of vents, just haven't had a chance to do anything with them. I'd like to be able to find a used hood to butcher. And I'd need to find someone I trust to do the work, as this isn't something I'd want to give to any old body shop.
    Cheese land
    1,596
    I got lucky and found a guy that's done quite a few. This is a popular mod with the off road guys and he's been doing Land Rovers and Jeeps. He's even done one on an STS.
    Faber is offline Cadillac Owners Fanatic
    Automobile(s): None :(
    Cincinnati, OH
    407
    will be interested to see the finished product.
    catch2otwo is offline Cadillac Owners Fanatic
    Automobile(s): CTS_V
    SF Bay
    144
    please keep updating!
    Dec 2008
    377
    yea please keep us updated id love to see the results
    Cheese land
    1,596
    Bringing it to the shop tomorrow for the Z34 extractor vents. I'll report back in about a week.
    AAIIIC's Avatar
    6,463
    Cool! Obviously, lots of pics are appreciated (including work-in-progress pics, if possible).
    Junior1's Avatar
    About to pass you...
    1,248
    Its been done quite a few times in the Sy/Ty community with success. I think it would work...
