Page 4 of 16 FirstFirst 1234567891011121314 ... LastLast
Results 46 to 60 of 230
Thread: Ebay - CLEAR FOGS
    agp's Avatar
    agp is offline Cadillac Owners Connoisseur
    Automobile(s): Ex-CTS owner
    SE Michigan
    1,229
    Re: Ebay - CLEAR FOGS
    Anywhere to buy just the lens?
    Noisycow's Avatar
    Noisycow is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Platinum CTS-V
    Portland OR
    103
    I prefer to use HOEN H11 55w for the fogs, amber V-Leds for the above/DRL part, and 194 LEDs for the sidemarkers vs standard bulbs.
    Order the $299 fogs/sides package today.
    V-Leds for the front turns - http://www.v-leds.com/Exterior-LED/P...70676-1-2.html + 3/6 load resistors
    I'll be disabling my DRLs. Apparently the dual white/amber type don't work well with our cars so I won't go the route.
    Latest Ebay Link:
    http://cgi.ebay.com/ebaymotors/03-07...Q5fAccessories
    TroyFleming is offline Cadillac Owners Fanatic
    Automobile(s): CTS-V
    206
    If anybody has purchased these Clears and has a set of original CTS-V amber fogs/with brackets they want to sell let me know need them for a carbon fiber project.
    Noisycow's Avatar
    Portland OR
    103
    I bought Hoen H11 55w bulbs for my new Ebay clear fogs, but the connector/lamp assembly is different vs OEM. Bulb that comes with the clear fogs is GE H10 9145U 42W where the connector pins are spread farther apart .
    Off to look for brighter lamps that will fit.
    Noisycow's Avatar
    Portland OR
    103
    Going to give these a try: Nokya Arctic White 9145 Headlight Fog light bulb Stage 2
    They are very bright apparently; will adjust the fogs downward so as not to blind other drivers.
    AAIIIC's Avatar
    Automobile(s): '05 CTS-V
    Where the Navy takes me...
    6,463
    Quote Originally Posted by Noisycow View Post
    Probably because it's the wrong bulb. H11 and 9145 are not the same, as you've now discovered. What led you to buy the H11 bulbs? I think it's H10 that shares the same connector as 9145, but I'd have to verify that before I actually bought H10s.
    Regardless of what brand of bulbs you buy, this page on Sylvania's website is very handy for figuring out what you need.
    Noisycow's Avatar
    Portland OR
    103
    I bought the Hoens when I was going to simple replace the bulbs in the stock fog housings which are different than the Ebay clear fog connectors. Now I am confused ... oh well. When they get here I'll know, the hard way.
    V-Guy is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 CTS-V, Raven/Ebony; Harley Fatboy; Harley Ultra-Classic
    Indy
    509
    I like the idea of clear fogs and turn signals with amber bulbs - but I don't really care for the 70s-style lenses. I think I'd like lenses that are truly clear.
    crankedupforit's Avatar
    Cheese land
    1,596
    Quote Originally Posted by V-Guy View Post
    The diffused lens does look a bit dated however the fog lights are pretty useless without that lens due to the way they are designed. With a clear lens you just get a scattered non directed light that distracts other drivers coming towards you.
    Indy
    509
    Quote Originally Posted by crankedupforit View Post
    I didn't know that - but it makes perfect sense. Thanks!
    cmiller is offline Cadillac Owners Member
    Automobile(s): 07 CTS-V Raven
    Madison, WI
    41
    Just ordered a set with the clear side signals. Can anyone offer any suggestions on how to remove the side marker cover to replace it? I am trying to figure out what type of amber LED light to put in there and don't want to force the cover off.
    bneal1022's Avatar
    bneal1022 is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 CTS-V, K&N, Borla, short throw w/ Holden knob, hotchkis
    May 2009
    906
    you have to remove the inner wheel wells and they unclip from inside the car nose. lots of simple work to get to. any 194 style led will work but go as low profile as possible so it fits through the side marker hole but behind the housing. do not force you must release from inside
    Madison, WI
    41
    Thanks for the info. I was looking at these lights http://www.v-leds.com/Exterior-LED/C...00672-1-2.html. Would they work or do I need something that projects light 360 degrees like these http://www.v-leds.com/Exterior-LED/C...1014-1-2.html?
    bneal1022's Avatar
    May 2009
    906
    actually side firing in your front markers is pointless. try these instead. front (top) is more suited given the bulb orientation in the marker light housing
    http://www.v-leds.com/Exterior-LED/C...81007-1-2.html
    Madison, WI
    41
    ok, I was assuming that the bulb was mounted differently than it is I guess, is the inside of the housing a reflector?
