Results 16 to 30 of 57
Thread: 05 Escalade 6.0 manifold bolts broken?
    Nrubkcalb is offline Cadillac Owners Member
    Automobile(s): 2005 Escalade AWD 6.0l.
    Jun 2010
    19
    Re: 05 Escalade 6.0 manifold bolts broken?
    Hey d3apool,
    Sorry to here that. This is not an easy job. You'll probably have to pull the manifolds to replace them so you might as well replace them all. Good luck!
    Bill
    d3adpool is offline Cadillac Owners Member
    Automobile(s): 2003 Escalade
    North Louisiana
    82
    Quote Originally Posted by Nrubkcalb View Post
    Hey d3apool,
    Bill
    thanks, i just filled out a complaint, even tho i'm not sure i lost my bolts or they just weren't put in when the motor was replaced. What else was going on with your engine besides the ticking sound?
    North Louisiana
    82
    been doing some research on other forums and i guess it is pretty common http://www.fullsizechevy.com/showthr...=manifold+bolt
    http://www.fullsizechevy.com/showthr...vers-side-rear
    Jun 2010
    19
    d3, The ticking sound actually starts to sound like an exhaust leak, after a while, especially when you first start up. I checked the links you posted and will probably join so I can post what we Cadillac owners have experienced.
    Regards.
    gmercedesbenz's Avatar
    gmercedesbenz is offline Cadillac Owners Fanatic
    Automobile(s): 2002 Escalade
    Jun 2010
    Washington D.C.
    169
    Just ran into the same issue on my '02 at 125,650. Those of you who know me, know my truck is impeccably maintained. Shop needs to replace the driver side manifold entirely, quoted around $900. Unreal.
    Based upon numerous responses on a number of forums and the video shown at the link below, I have filed a formal complaint with the NHTSA. (ODI: 10494361) I'm sure many of you have done the same thing, I can only hope that they will even read it.
    Will GM Recall Broken Exhaust Bolts on Its V8's?
    wesyder's Avatar
    wesyder is offline Cadillac Owners Connoisseur
    Automobile(s): 08 Escalade ESV awd, 05 Yukon Xl Denali awd, 06 SRX sold
    Eastvale Calif
    1,812
    Quote Originally Posted by gmercedesbenz
    Good luck with that one
    the cadillac man's Avatar
    the cadillac man is offline Cadillac Owners 10000+ Posts
    Automobile(s): 03 cadillac escalade
    speedwell tn,
    11,884
    Wow I just watched the video and I will be replacing my spark plugs so I will inspect the bolts also while I am at it
    Edit I checked them today and two bolts have broke heads wtf
    sbowers115 is offline Cadillac Owners Member
    Automobile(s): 2005 Escalade ESV Platinum
    ok..need some help guys.. I have an 05 escalade esv that has a ticking noise, almost like a lifter noise under acceleration. Doesn't do it while at idle. Increases with the rpm.. I have pulled the valve cover, everything looks fine, have shut the engine down cylinder by cylinder, noise is still there...unhooked torque converter, noise still there. Flywheel does not appear to be cracked. HELP ME PLEASE !
    speedwell tn,
    11,884
    Quote Originally Posted by sbowers115
    Are the manifold bolts intact or is a few of them with broken heads? If broken it can cause the ticking
    wake's Avatar
    wake is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 STS-V, 2007 Escalade, 2003 Escalade EXT
    Stafford, VA
    812
    None missing the heads on mine but they do look fragile, covered in thick rust. I'm used to seeing rusted manifold bolts but not like I have under the hood right now.
    Looks like a wrench to them would not be a good idea.
    djais1801's Avatar
    djais1801 is offline Cadillac Owners Fanatic
    Automobile(s): 2004 EXT Sable Black
    Feb 2011
    NJ
    246
    well...thankful i read this thread last night...had my rig in the shop this morning and i have 3 bolts broken. My tech said they're not broken flush with the head, so it's easy to back out, if they were flush, you'd have to remove the head to get them out...dodged that bullet!
    speedwell tn,
    11,884
    Quote Originally Posted by djais1801
    Lucky dog I haven't thought of messing with those bolts even though mine has a few broke heads
    jjtwomey's Avatar
    jjtwomey is offline Cadillac Owners Member
    Automobile(s): 2002 Escalade 500XS
    Nov 2012
    Massachusetts
    Quote Originally Posted by djais1801 View Post
    Lucky is right, this happened to my 2000 Silverado, and it can be really expensive if they aren't broken off like that.. It's all aluminum so if it cracks I'm out a couple grand
    speedwell tn,
    11,884
    Quote Originally Posted by jjtwomey
    Lucky me there isn't any cracks just broken bolt heads
    djais1801's Avatar
    Feb 2011
    NJ
    246
    Quote Originally Posted by the cadillac man View Post
    my buddy said theyre seeing a ton of these on the 6.2's also
