Results 16 to 26 of 26
Thread: oil filter cap overtightened
    Stillrollin is offline Cadillac Owners Fanatic
    Automobile(s): 2008 SRX AWD V-6
    N. Ridgeville, Ohio
    75
    177
    Re: oil filter cap overtightened
    never mind
    I've been letting the dealer change the oil in my '08.
    allbee1 is offline Cadillac Owners Member
    Automobile(s): 2008 cts sport
    Sep 2013
    14
    same deal here first oil change on 2008 cts oil filter housing cap it tight as hell. Already broke 2 3/8 extension trying to break it loose. At this point i am afraid of breaking the the nut of the canister any ideas? Also whould it be a bad idea to used impack wrench?
    repnatl is offline Cadillac Owners Enthusiast
    Oct 2012
    975
    24mm 1/2 in with 6 in extension and breaker bar never had an issue
    AirborneMechanic is offline Cadillac Owners Member
    Automobile(s): 08 CTS AWD
    Jul 2011
    12
    Quote Originally Posted by repnatl View Post
    Waking up a dead thread....
    So what happens when you use a 24mm socket w/ said extension and the f'n nut on the housing fn snaps off??
    Oct 2012
    975
    Quote Originally Posted by AirborneMechanic View Post
    Haha yeah I was in a search for the bypass valve and this popped up. If that happens if it can't be removed or cut off replace the entire adapter housing.
    08SRX's Avatar
    08SRX is offline Cadillac Owners Connoisseur
    Automobile(s): 2008 SRX Sport Pkg
    Jun 2011
    1,052
    Quote Originally Posted by heccercal View Post
    mechanic at the dealer told me to untighten it when oil is hot
    So you can scrape your elbow AND burn your hands?
    conedoctor is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS AWD Wagon 2010 BMW X5 35D 2008 GL320
    2,621
    The V6 has a cartridge on top of the engine, so I would say when hot it would come off better.
    n7don_srx is offline Cadillac Owners Enthusiast
    Automobile(s): Cadillac '07 SRX-V6 RWD, '03 Envoy, '95 S10 pu
    Jan 2007
    Gold Canyon & Happy Jack, AZ
    809
    Since the housing is busted I'd attempt to use a drift punch or chisel and try to loosen by applying torque by hitting on the side.
    xray53 is offline Cadillac Owners Member
    Automobile(s): 04 Limo 06 SRX 89 ALLANTE,06 ESCLADE Plat,06 DEVILLE Hearse
    May 2010
    Pa
    13
    Have used a 1/2" impact rite on the socket to break it loose. always worked for me .
    Oct 2012
    975
    Quote Originally Posted by xray53 View Post
    Be careful with an impact though make sure the psi is adjusted so as to not break the rest of the adapter off
    2,621
    I have only changed the oil once on my new 2010 3.0l and it was tight but came off with an L handle, maybe for fun I will try it hot and cold to see if it makes a difference.
