Page 20 of 53 FirstFirst ... 101112131415161718192021222324252627282930 ... LastLast
Results 286 to 300 of 793
Thread: Custom Short Shifter Ordering Process.
  1. #286
    Sigfod's Avatar
    Sigfod is offline Cadillac Owners Fanatic
    Automobile(s): 2006 CTS-V
    Sterling, VA
    169
    Re: Custom Short Shifter Ordering Process.
    Brian,
    Any Updates?
  2. #287
    PISNUOFF Guest
    I will have the next 4 ready to ship next Wednesday.
    Wait list:
    1. Nathan - Shipping next week.
    2. Daniel - Shipping next week.
    3. Scott - Shipping next week.
    4. Jonathan - Shipping next week.
    5. Garrett
  3. #288
    Sigfod's Avatar
    Sterling, VA
    169
    Quote Originally Posted by PISNUOFF View Post
    Wait list:
    5. Garrett
    Will this be potentially effected by the coming hurricane?
  4. #289
    whisler151's Avatar
    whisler151 is offline Cadillac Owners Connoisseur
    Automobile(s): 2012 CTS-V Sedan, 2011 CTS Coupe, 2010 Ford Raptor
    Dallas, TX
    3,547
    For you all that are waiting, this shifter is well worth the wait. I cant believe it took me over 4 years to order this.
  5. #290
    PISNUOFF Guest
    Quote Originally Posted by Sigfod View Post
    No, I live in Ohio. I have the cores, just waiting on my die shop to produce some bushings.
  6. #291
    CadzillaTN's Avatar
    CadzillaTN is offline Cadillac Owners Connoisseur
    Automobile(s): 2004 CTS-V
    Apr 2008
    2,061
    Quote Originally Posted by whisler151 View Post
    I always wondered how you could go that long with the truck shifter..
  7. #292
    punisher28 is offline Cadillac Owners Member
    14
    PayPal sent, can't wait
  8. #293
    Sigfod's Avatar
    Sterling, VA
    169
    Checking Status
  9. #294
    2007ThunderV's Avatar
    2007ThunderV is offline Cadillac Owners Fanatic
    Automobile(s): 2007 cts v
    Jul 2011
    482
    this is my best mod yet, i just installed it on friday
    alsolutley night and day difference. i bought mine used from a member who sold his car locally, and never got around to install it.
    pisnuoff your shifters are a work of art!
    one question, i have a core for you, will you credit me a core for it, i have the orignal purchasers email and information if you need that, send me an email at jonolds72@hotmail.com and let me know and i will ship the core to you on monday
  10. #295
    CadzillaTN's Avatar
    Apr 2008
    2,061
    I finally got around to (attempting) the install of the linkage bushings at the trans connection. Pita with the trans in. I may have to remove it to do this..., bummer but it seems inevitable since I also need to pull my clutch/fw for a balance.
    For those wondering,
    Brian sells bushings for the piece that connects the linkage arm to the trans. This arm connects much the same way as it does at the base of the shifter.. The part that goes through this hole is similar in form to the bolt used at the other side, but is fixed to the arm and is held in simply by a clip, not a nut. The result, the bushings wear out and it moves around in this housing causing play back at the knob. Fixing this should be similar improvement to fixing the looseness at the base of the shifter using the delrin replacement bushings, just that much more precise...
    Brian, a few questions:
    How did you guys get the old ones out?. I've tried prying a sharp knife in there to start them, and I also used needle nose pliers.. both with no luck. Seems like the original ones are plastic of some kind, you think I could torch/heat that piece and make them soft enough to remove?
    Also,
    I tried to test fit one but it wouldn't go on- Will I need to file the edges and/or lube to get the pin in? Are they so perfect in measurement I may just be a hair off on the entry angle? Same question goes for when I go to put then in the housing, I noticed they are beveled, so I hope my 04 is the same as your 07.
    I can't wait, the remaining slop will be gone after these are installed!! The old ones have worn out. I knew it just didn't feel the same anymore.......once this is done, it will be as tight a shifter one can get.
  11. #296
    PISNUOFF Guest
    You have to drill the stock ones out. Also, you have to press the new ones in. This can be done with a block of wood and a hammer. Once installed, you will have to ream out the bushings to match the linkage stud. Make it so that it will just barely insert into the bushings. Let me know if you ream it too much.
  12. #297
    V-Pilot's Avatar
    V-Pilot is offline Cadillac Owners Member
    Automobile(s): 05 CTS-V
    Feb 2008
    Brian,
    I think I'd like to order your shifter but the last time I read through this thread there was a long wait. Can you PM me with the current wait time, price, and email address. Thanks
  13. #298
    PISNUOFF Guest
    Quote Originally Posted by V-Pilot View Post
    Brian,
    It seems that you cannot receive PM's. Here is my email address. br_1868 (at) hotmail (dot) com.
  14. #299
    Overd0s3 is offline Cadillac Owners Fanatic
    Automobile(s): 2006 CTS-V blk/blk
    Dec 2009
    323
    Brian, money sent.
    Paypal ID was rickyvandyke
  15. #300
    PISNUOFF Guest
    Got it.
