Results 31 to 45 of 66
Thread: How to change your own oil (with pictures)
    stevey_frac is offline Cadillac Owners Member
    Automobile(s): NONE
    7
    Re: How to change your own oil (with pictures)
    Quote Originally Posted by PGH STEELERS View Post
    Here's a noob question and sorry, I haven't looked at the owners manual. How many quarts does the (08) 3.6 AWD Caddy take?
    I don't believe the AWD part matters at all. Both the regular and DI 3.6L engines take 6.1 quarts.
    pesticidal is offline Cadillac Owners Member
    Automobile(s): CTS, 2010 awd
    Fargo, ND
    64
    Quote Originally Posted by crystal_red View Post
    I use a Griot's Garage fluid extractor and suck the old oil out thru the dipstick tube. No jacks, no ramps, no removing drain plugs, no crawling under the car at all. Takes about 15 minutes including the filter change!
    I wish the CTS had a tube like my MB SLK. The dipstick tube goes all the way to the bottom, and I just clamp a 3/4" hose on it and suck it out with a small pump.
    akakillroy is offline Cadillac Owners Member
    Automobile(s): 2011 CTS Premium in White Diamond Tricoat
    Feb 2011
    52
    Has anyone seen or used this one?
    http://www.harborfreight.com/6-1-4-q...tor-46149.html
    Feb 2011
    52
    2011 you get free oil changes for the first 4 years so what am I worried about ;-)
    08 CTS4 is offline Cadillac Owners Fanatic
    Automobile(s): 2008 CTS4 AWD
    156
    Ok I feel a bit like a dumbass since I know my way around a car, but I cant seem to find the oil drain plug ?
    Ive got an 08', and crawled around under the car looking for the plug, and its no where to be found. The pictures that are attached are not the same bottom end as what i see ?
    Long story short, I dont see anything that would be a definate drain plug ??????
    Any help would be appreciated.
    156
    I'lll add that its an AWD, so a bit different, but still no definate plug in sight ?
    jghiller's Avatar
    jghiller is offline Cadillac Owners Connoisseur
    Automobile(s): 2016 XTS Premium
    Aug 2008
    SC/NJ
    1,425
    I watch mechanics do most of my oil changes - just had one done today - 08 CTS RWD. Never saw the mechanic remove any shroud underneath the car. Drain plug was fully accessable.
    Curious that oil was also drained and plug reinstalled and then filter was removed/replaced. I realize that filter sits upright on top so I guess oil naturally drains out completely when drain plug is removed. Not like the old style - upside down filter installs.
    Didnt see him take the upper shroud out either - must have just moved it slightly to gain full access to filter - but maybe not. Not sure.
    ceperlar is offline Cadillac Owners Member
    Automobile(s): CTS4 2011
    Oct 2011
    Charleston, WV
    2011 CTS 4, Good Directions. Followed them and even no spills. BUT tried to follow the oil maintenance light reset instructions in the manual. No luck, the reminder light won't go out. Any suggestions? 10/26/11
    GT!'s Avatar
    GT! is offline Cadillac Owners Enthusiast
    Automobile(s): 2014 SRX AWD Platinum Ice/2010 CTS Sedan 3.6 AWD Silver
    Jun 2005
    Montreal
    53
    643
    I had an idea to make oil changes easier. As we know the filter is easily accessible, but the drain plug is a lot more effort. How about installing a Fumoto valve on the drain plug - the one with the hose (http://www.qwikvalve.com/). Make a small hole for the hose to permanently hang down a couple of inches. Then make another cutout big enough to reach in with your hand to work the valve. Save the cutout and put some kind of hinge-type mechanism (perhaps just some stiff rubber) to make it a clean install.
    Does this sound like it will work? I've only just got my 2nd gen CTS and have not done an oil change on it. Comments?
    BTW, I'm not looking for comments on the merits of the Fumoto valve itself (I know some people don't trust them).
    -GT
    Nov 2011
    has anyone else have any luck with the fluid extractor? or perhaps can also vouch for "griots garage fluid extractor" ... it feels kinda iffy if one person tired it and it works while others say it doesnt. checked out prices for griots and its about $100 shipped, a little too expensive to try out for an experiment.
    atikovi is offline Cadillac Owners Fanatic
    Automobile(s): 1997 Professional Chassis Raised Roof Presidential Limousine
    May 2003
    Suburban Washington DC
    400
    Used that all the time when I lived in a townhouse where you arn't supposed to be working on your car. Works great. But if the filter is under the car, you have to drive up on ramps anyway and crawl under the car so you still need a drain pan.
    cadillacmike68's Avatar
    cadillacmike68 is offline Cadillac Owners Connoisseur
    Automobile(s): 68 DVC, 96 FLTWD Brg, 09 STS N* Platinum, 11 CTS Premium
    Left the desert - Back in FL
    56
    1,303
    Quote Originally Posted by atikovi View Post
    You might want to add that since the drain plug is at the right rear of the oil pan it's best to drive the car up on ramps and even better if the left ramp is a little higher than the right so as much of the old oil drains out as possible. Also the drain plug takes a 15mm socket, the oil filter a 24mm with about a foot of extensions and maybe a breaker bar since it can be tight.
    Watch out on this. I broke a filter cover in two because it was too tight on my wife's 2005 CTS. That oil change ended up costing me $350. The dealer recommends using an impact driver (sort of a drill with a socket on it) if its tight because it is very easy to misalign the force applied across a long breaker bar and just snap off that cover!
    Oct 2011
    Charleston, WV
    THX for the PIX and the "experience" posts. They help a lot. #2 change next week will go much better. Next project is cabin air filter.
    jeffc83's Avatar
    jeffc83 is offline Cadillac Owners Connoisseur
    Automobile(s): 2008 CTS4 DI Premium (SOLD) / 2013 XTS Luxury (TOTALLED) / 2015 BMW 328i XDrive Lux
    Southeastern PA
    1,957
    Quote Originally Posted by ceperlar
    Not to take away from the thread but the in-cabin air filter will be much easier than the oil change! 5 minute job...
    CADDYPRINCESS's Avatar
    CADDYPRINCESS is offline Cadillac Owners Member
    Automobile(s): cadillac cts 03
    Jan 2012
    53
    Can you do one of these for the trans oil ? Please tia
