Page 12 of 28 FirstFirst ... 2345678910111213141516171819202122 ... LastLast
Results 166 to 180 of 416
Thread: So... What is wrong with your NEW SRX?
  1. #166
    Professor Wizard's Avatar
    Professor Wizard is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 SRX-4 Sport / TriCoatWhite
    May 2009
    St. Louis, MO
    62
    1,096
    Re: So... What is wrong with your NEW SRX?
    I'm BACK!
    I had to take my SRX into the dealership again... This time the Roof Trim Piece on the passenger side - between the Sunroof and the Doors came off!
    It seems that the Factory Glue can't hold up to the heat.
    Dealership gave me a DTS to drive and they had the panel re-glued back on by an automotive glass repair place... They also had the work that was done to the front panel repair cleaned up a bit better.
    I still need to get the rear brakes done and tires for the front.
  2. #167
    May 2009
    St. Louis, MO
    62
    1,096
    Bummer...
    Walking around my car last night, I noticed the Parking Lamp on the Drivers side is out... Reading these threads, and looking in the service manual, I can see that changing any bulb in the front of an SRX is a PITA.. either in time for yourself - of $$$ if you have the dealer do it!
    So - - I'll take her in on Monday to see if the dealer will fix under Warranty.
    This one really gets me going though! - - Every car I ever owned until this one, had provisions to access and replace bulbs - most of the time you didn't even need any tools. But not THIS car - - this car needs 3 hours, special tools and an engineering degree to change a $1.50 light bulb.. (OK - I'm ranting, but it does really annoy me!)
    I'll update after I speak to the service guy.
  3. #168
    jackhayes is offline Cadillac Owners Member
    Automobile(s): 2008 SRX Sport Red Tint
    Apr 2011
    Nevada
    three times this week just driving along with the air conditioning on (90 outside) and the air
    stops working. fan goes, and it sounds normal -- but no cold air. after a few minutes with the
    windows open the air comes back on and life is normal again.
    communicating this to the dealer/service will be interesting. replicating it, even more so.
  4. #169
    Apr 2011
    Nevada
    Re: What is wrong with your NEW SRX?
    occasionally the dash goes totally dark during the day and I can't see anything. headlamp switch position makes no difference.
    another fairly inconvenient electrical problem. was this electrical built by jaguar (lucas)?
  5. #170
    May 2009
    St. Louis, MO
    62
    1,096
    Wow Jack - - sounds like you just could have some major electrical issues... I wish you the best of luck with that.
    I took my SRX to Elco today - - they told me the bulb is covered under warranty, and will change right away...
    Looking at the front lamps we noticed that the clear finish is starting to peal off of the tops of the bezels, giving us a strong feeling they are prematurely degrading.. My Service manager is going to ask his boss about having them replaced, because we think they shouldn't be doing that after just 2 years. We shall see what the Boss Man says.
  6. #171
    glake89's Avatar
    glake89 is offline Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6 (gone), '07 GXP, 2010 li'l red wagon 3.6
    Interlochen,MI
    82
    2,906
    jack, re dash going dark. Do the lamps go out or just dim? Could be the ambient light sensor, try the dash dimmer switch to override.
  7. #172
    PJ1520 is offline Cadillac Owners Connoisseur
    Automobile(s): 2007 SRX4 N*, 2004 Infinity G35 Coupe
    New England
    2,005
    Quote Originally Posted by glake89 View Post
    Some folks may have laughed at this suggestion, Glake, but I have to admit it happened to me once in the SRX......the dimmer rheostat switch was cranked all the way down.
    PJ
  8. #173
    May 2009
    St. Louis, MO
    62
    1,096
    Lamp / Lens update...
    Elco just called :: they replaced the entire assembly for the drivers side headlamp. (Because of the flaking.)
    The "Boss" would NOT OK replacing the Passenger Side Assembly, as it was not flaking as bad as the Drivers side - - so I'll attack that one on another day.
  9. #174
    New England
    2,005
    Quote Originally Posted by Professor Wizard View Post
    As Arnold Schwaerzenegger said, "I'll be back."
    These guys could have saved themselves some time and further discussion had they taken care of both the first time. In, out, and done. You will be back. They should also be quite familiar with your issues history. And I am certain they want to see you again, to buy another vehicle. I don't think this is nitpicking on your part. And some of us just won't be worn down in the process.
    PJ
  10. #175
    Apr 2011
    Nevada
    thank you -- I'll give it a try. certainly aggravating!
  11. #176
    May 2009
    St. Louis, MO
    62
    1,096
    What??? - Really???
    Well - - - I was hoping the light bulb and housing was the last thing for at least a month.. I was overly hopeful it seems as luck would have it...
    Sunday afternoon - I am out and about in my SRX... Sunroof shade was open and it started getting warm in the car, so I hit the button to close the shade...
    Wrrrrrrrrrrrrrrrrrrr Crackle Crackle.. screech... screech scrape crackle crackle..
    The metal bar that is a support for the sun shade down the middle, came off of the shade, then promptly prodded itself out from behind the shade crinkling up one side of the shade.
    I backed the shade up, and pulled the 3 ft long bar out. - - then nursed the shade into a closed position. It is closed, but sags now as there is no support in the center.
    So - - back we go again.. yet another time.
    Anyone know - What are the rules for a Lemon exactly?
    PJ :: You are exactly right - - I'll be back - - I am presently so annoyed with my SRX now, that I can't wait to dump it off on some other poor sod!
    Many at my work are asking me what kind of GM car am I test driving this week... as it seems to them I am driving a loaner as often as I am driving my SRX.
    I am debating whether or not to take it in NOW, or wait a week to see what else breaks.
  12. #177
    May 2009
    St. Louis, MO
    62
    1,096
    UPDATE: So.. SRX went in Tuesday AM... they still have it.
    They just called me... to instal a new shade they had to actually remove the entire sun roof.
    New sunshade was installed.
    Installing the Glass of the sunroof, they stripped out the threads for the rear mounting brackets - - so now they are getting new rear mounts.
    I'm glad I'm not paying $$$ out of pocket for this one.
    ELCO = great people, they do try hard!
  13. #178
    Detroit, USA
    12,710
    Professor Wizard,
    I am glad to hear that you got your issue fixed. If you have any other comments or concerns, feel free to let me know.
    Thank you,
    Elizabeth, Cadillac Customer Service
  14. #179
    May 2009
    St. Louis, MO
    62
    1,096
    Elizabeth...
    Thank you very much for the ping... - - My ELCO Service Rep just called to tell me they had put Humpty Dumpty back together again, and I get her back this afternoon.
    I really do wish, that when they replaced the drivers side lamp assembly - they had also done the Passenger side as well (I did request it!)... now I have a nice shiny one on one side, that makes a white/pink light.. and a weathered looking one on the other side that makes a white/blue light - - if you have any powers to authorize such a thing, I would appreciate it... it would be nice to have them the same - - and maybe a good-will gesture as well, to appease my attitude due to the multiple times I had to put my SRX in the shop. (Documented in here.) If not that, maybe a free Mobil1 Oil change or something! - -- or a Cadillac Hat!
    My co-workers are starting to tease me - - asking what car I will be test driving this week (Because I am driving a different loaner car every time mine is in the shop.)
    My SRX, has probably lost at least 5 GM product sales that I know of, because of people at my work watching me. They bought new cars, and told me that they didn't even look at GM because of the multiple problems they saw I had with my Cadillac. I can't say I blame them, as the odds are not in GM's favor for my next ride.
    At least I get good service from ELCO. Great guys - - yea, they had some issues, but where it was their fault, things were resolved. (Heater problem). They are good people.
  15. #180
    1STCADY is offline Cadillac Owners Member
    P.W. Read all your comments...wow a true Friday SRX. Just wait... can you say StabiliTrak? Wait til it goes.
