Results 16 to 17 of 17
Thread: 1994 sedan deville, engine bay HOT!!
    82,262
    Re: 1994 sedan deville, engine bay HOT!!
    Yes it should set a low refrigerant DTC. Just get the refrigerant, not one with a sealer in it. You will have to figure out why the compressor is not running to add refrigerant. Usually all you have to to is clear the DTC to enable the compressor. If you do not have one, then there is another problem and the system may not need a charge.
    DanielDeville's Avatar
    DanielDeville is offline Cadillac Owners Member
    Automobile(s): 1994 DeVille Concours
    Apr 2009
    California
    22
    Quote Originally Posted by rp0420 View Post
    update. So i wanted to be sure about the compressor and looked under the hood, it looks like the pulley is spinning but the side of the pump is still staying still, like inside the pulley if you know what i mean, im guessing this is the compressor clutch and it doesnt engage it just sits there wit the ac on, and ichecked my compressor fuse which was good, so do i need to replace the compressor?The tubes felt kinda cool at best but not cold. Also i tried to do a search on how to do the dic hack for 94's but didnt have any luck, does anyone know the title?? or link maybe? Thanks alot
    Here is the linkage. The OP is KDirk;
    http://www.cadillacforums.com/forums...t-upgrade.html
