Page 7 of 10 FirstFirst 12345678910 LastLast
Results 91 to 105 of 139
Thread: V1 Hardwire with BlendMount and Invisicord
  1. #91
    wetcoast's Avatar
    wetcoast is offline Cadillac Owners Fanatic
    Automobile(s): 2009 CTS-V Manual
    Langley, BC
    152
    Re: 2012 Which Wire to use for invisicord Radar Detector?
    I did a write-up with pics here.....
    http://www.cadillacforums.com/forums...-hardwire.html
  2. #92
    neuronbob's Avatar
    neuronbob is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 6MT V wagon, OBM, 2009 silver V sedan (traded)
    Cleveland area, OH
    4,526
    That's a good writeup. However, having owned both a 2009 and now a 2013 V, the wiring harnesses are different between the two and so is the mounting point on the mirror (none on the 2012-13, definitely present on the 2009).
    Otherwise, the same basic principles apply to that extensive an install.
  3. #93
    marcusp23 is offline Cadillac Owners Member
    Automobile(s): 2011 CTS-V Sedan
    Jan 2013
    41
    39
    Re: V1 Hardwire with BlendMount and Invisicord
    Quote Originally Posted by bbott View Post
    Can you guys confirm the wire coloring for a 2011 CTS Sedan?
    Bumping this to see if someone can help answer this question before I dive in and start messing with wiring. Thanks
  4. #94
    cadillaxe's Avatar
    cadillaxe is offline Cadillac Owners Fanatic
    Automobile(s): '13ctsvcp,'10bmwS1KRR,'13YCCchopper
    san antonio, tx
    363
    no, but hoping someone answers so i can do my '13 as well
  5. #95
    neuronbob's Avatar
    Cleveland area, OH
    4,526
    Quote Originally Posted by cadillaxe View Post
    http://www.cadillacforums.com/forums...ml#post3206235
    Here you go, bud. I had to do this on my '13.
  6. #96
    cadillaxe's Avatar
    san antonio, tx
    363
    Quote Originally Posted by neuronbob View Post
    I finally hardwired my V1 to my new wagon.
    For my 2013, there is a PINK powered cable and a black/white ground.
    Also, the regular Invisicord blades are simply too wide to fit. I bought another cord with narrow pins and I just installed it yesterday. It's from an outfit that sells on eBay, Safe-n-Sound, and it cost $11.50 shipped. It comes with a fuse attached, unlike the Invisicord, with which you have to pay $5 extra for that. Fits great and now I'm all set up. LINK
    So if anyone wants my old Invisicord for their older (2009-10) V, I'm willing to sell.
    awesome, thanks! Just ordered the safensound cable, and guess i'll also have an old invisicord to sell soon unless i can send it back. I have the blendmount ordered, but will need some tweeking to get it behind the mirror, not below it. already talked to the outfit in WPB about modifying the mirror for the display.
    only thing i have yet to figure out is will i just reach behind the mirror to hit mute or volume adjust, or do i mount that somewhere else? any thoughts?
  7. #97
    cadillaxe's Avatar
    san antonio, tx
    363
    bi+chn! posted over there since that's the relevant series for ours. thanks!!
  8. #98
    Jan 2006
    Hillsborough, NC
    Quote Originally Posted by majdewey View Post
    This past weekend I hardwired my V1 in my 2011 CTS-V Coupe. I just completed the write up with pictures for the forum, but my post was not allowed because I'm new and can't post links to photos until I have 5 post. Guess I should of read the rules. I'll post my required post tonight and redo the write up.
    2011 V Coupe, I just finished hardwiring with Invisicord yesterday. Totally different from other approaches (no plug on back of mirror). I used the 8" invisicord and and the Blendmount setup.
    1) pull the wiring cover off the mirror bracket (easy pry off, just pops off, angle the mirror down if you need better access)
    2) remove bolt from mirror holddown to window (small star head, angle mirror back up to get a straight shot at the bolt)
    3) slide up mirror until it is off the window metal tab, then rotate it 180 to where you can see/access the tiny latch in the square electrical connector (it normally is hidden facing the window, don't try to pry/push in the small white dots on each side of it like I did, they don't do anything).
    4) take a small screwdriver and just press in the latch and the connector will pop apart, now you have the mirror completely off and in your hand.
    5) Invisicord prongs are fine as is, no need to cut, shave, bend, etc if you do it my way. You will be pushing them into the "mirror-side" of the connector, so the colors don't mean anything; you have to match up the wires to the ones that are colored pink (for yellow) and black/white (for black). Watch out, there is a brown/white that threw me off for a bit (and a yellow too which other V's use, but not the Coupe).
    6) Once you have located the pink wire and black/white wire on the "car-side" of the connector, note which "mirror-side" wires match (they are both on the "bottom row" of the connector when it is sitting in installed position.
    7) Route the invisicord wire up through the hole in the bottom of the mirror bracket, to where the wire will end up coming out the "bottom" of the entire bracket, just past the window metal square.
    8) push the connectors into the two wire holes, it will take a bit of pulling/tugging/aligning, but since the whole mirror is off in your hand its easier to work with.
    9) once the wires are fully pushed in, pull the entire invisicord tight, then lay the "phone cord" body of it in the narrow channel on either side of the bolt hole that screws into the window metal square, then out the "bottom".
    10) now take the whole mirror, connect to connector, slide onto metal square (making sure not to pinch the phone cord part of invisicord), screw in mirror bolt, and pop back on beauty cover. you are done.
    This method has the cord coming out the bottom of the mirrror bracket, which curves right around and plugs into my V1 mounted on the blendmount. If you prefer the wiring coming out the "top" of the whole thing you'd need to bend the wiring 180 degrees, or try to push the invisicord pins into the "car-side" of the connector/etc. I like the clean look of the wire coming straight out/over to the V1.
    Good luck!
    Randy
  9. #99
    cadillaxe's Avatar
    san antonio, tx
    363
    ok, finally finished the radar mount project
    -bought the safe n' sound with narrow pins, but cord still too long, so made my own shorter one
    -bought blendmount, but didn't like the low hanging v1, so made a different plate to include that puts it to the right of the mirror. this allows me to not see it in my vision, but it's still hanging up high with antennas in clear view front and back, access to mute/volume, etc. but not cables down to dash, just power from the mirror
    vid to follow...
  10. #100
    Cadzilla8's Avatar
    Cadzilla8 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Cadillac STS Northstar V8
    NY
    247
    Hey neuronbob and axe. You both have extra invisacords? I would be interested in buying one of them. I have my escort hardwired to my mirror but the wire they provided aren't the base the it doesn't give very good signal/power. Shoot me a pm. Thanks
  11. #101
    neuronbob's Avatar
    Cleveland area, OH
    4,526
    Nice install axe. Very original.
    Cadzilla8, I'll try to locate my Invisacord. Note that it is the one with the wide blades.
  12. #102
    cadillaxe's Avatar
    san antonio, tx
    363
    Thanks Bob. i'm happy with it.
    zilla, I've got mine lying right in front of me. PM you in a sec.
  13. #103
    Bigron is offline Cadillac Owners Enthusiast
    Automobile(s): 2010 CTS-V
    Southfield, MI
    934
    So with a 2010 do I need the thin blades?
    Also, color for power/ground?
    Thanks in advance.
  14. #104
    khoeysr is offline Cadillac Owners Fanatic
    Automobile(s): 2012 V Coupe Crystal Red/Ebony
    Central NY State
    402
    I had the invisicord/blendmount setup in my 09 V sedan and my 11 Vcoupe. Did all the installation myself. When I got my 12 coupe I had the dealer tap in while I was picking the car up. Nothing to it, and no explosions or electrical problems since, so I can't offer much other than to say I probably would always have the dealer do the electrical stuff from now on.
  15. #105
    cadillaxe's Avatar
    san antonio, tx
    363
    i'm not positive on this, but at some point i think they went from the big connector on the mirror itself to the small connector above the mirror, and the thinner blades work best for the latter, though not sure what years. is that right, Bob? Ron, if you post a pic, would be easier to make a guess.
    the install was overall pretty basic stuff. i have a video i'm stitching together right now on it. hardest part for me was making the bracket extension for horizontal mounting of actual V1 behind the mirror. hopefully have that posted by the weekend.
