Page 11 of 17 FirstFirst ... 234567891011121314151617 LastLast
Results 151 to 165 of 245
Thread: Damn! High Oil Temp and alarms? Here is a fix for it (page 7 post #98).
  1. #151
    CancerJCC is offline Cadillac Owners Connoisseur
    Automobile(s): 04' Blown CTS-V 554rwhp 497rwtq
    Georgia
    1,786
    Re: Damn! High Oil Temp and alarms? Here is a fix for it (page 7 post #98).
    Quote Originally Posted by Twitch View Post
    I'll be getting to that one soon. It bothers me that my car rarely stays above low 13's voltage wise.
    Yeah It didn't seem to change anything for me but I need to go back through and star washer all of them. I am getting a lean spike for a second after each shift but it could actually be tied to our grounding offset and not actually a true lean spike...ah Mod Hell how I love you.
  2. #152
    heavymetals's Avatar
    heavymetals is offline Cadillac Owners Master
    Automobile(s): 05 maggied CTS-V, 03 maggied Z06
    Nov 2004
    8,788
    Take a wire brush to the lug and the surface.
    Put the star washer between the bolt head and the lug, not between the lug and the surface.
  3. #153
    Georgia
    1,786
    Quote Originally Posted by heavymetals View Post
    Hmmm I sure will, hopefully this takes care of all of the anomalies that I have.
  4. #154
    Twitch's Avatar
    Twitch is offline Cadillac Owners Connoisseur
    Automobile(s): '05 CTS-V, '00 SLS, 98 SLS, 89 Eldo, '80 Eldo
    NYC
    46
    4,001
    Quote Originally Posted by CancerJCC View Post
    Lean spikes between shifts seem pretty common. I don't pay enough attention to them to know if I get it or not. Still good to find more ground points to clean up.
  5. #155
    Georgia
    1,786
    Yeah that is what I am reading/finding as well. Also my electrical gremlins tend to come out when the revs dip low (similar to shifting). Perhaps it has something to do with the voltage drop when the motor isn't spinning the alt. as fast?
  6. #156
    Twitch's Avatar
    NYC
    46
    4,001
    If you didn't have a 122, I'd recommend an 8" pulley
  7. #157
    Georgia
    1,786
    Heads (and all the trimmings), and Cam are next on the list. Gotta beef up the valve train anyhow so I am figuring "while I'm in there"! Then perhaps I will look at getting the boost back up where it is now with an 8 rib setup including the 8" crank pulley.
    On a thread related note I spent the good part of 3 (back crunching) hours today locating and cleaning grounds. Preliminary results are good but I will wait a week or two before I say yes for sure and upload some more pics.
  8. #158
    Georgia
    1,786
    Got these fixed! All I had to do was raise the Clutch in DFCO to 284*. Everything feels much nicer when I am getting back on the throttle now and when I push the clutch in it feels nicer.
    UPDATE:
    Spent about 3 hours the other day and finally got these high temps under control! I still can make them fluctuate with turning on/off accessories but only by a few degrees and not 20 like before.
    I ended up adding star washers to the following grounds as well as sanding the lug and area the lug attached to. (didn't sand the heads just cleaned them)
    Drivers side head rear.
    Passenger side head (both rear not pictured and the side facing the fender/battery pictured)
    The ground below the underhood fuse box.
  9. #159
    Nov 2004
    8,788
    The first rule in ASIC design: GROUND IS NOT GROUND
  10. #160
    Georgia
    1,786
    I had to Google ASIC (Application Specific Integrated Circuit) and I still don't know what the heck it is! I can share in the head banging though as these damn cars and their electrical gremlins can be frustrating. Although it wasn't all for not as I was able to clean up some wiring and route the evap and fuel line a bit cleaner and out of the way...
  11. #161
    mrmojo95's Avatar
    mrmojo95 is offline Cadillac Owners Fanatic
    Automobile(s): 05 Cts-v Ls7 Clutch/Fly, Cam, LEDint/ext, side exit exhaust
    Oct 2008
    Grand prairie texas
    46
    127
    What a great tribute to the Forums! Thank you to all for this information, i will be implementing it soon...I'm curious has anyone noticed that on a cold cold day, (key on, no start) the oil temp can be quite a bit below the actual or forcasted ambient temp? I wonder if this is related or just a weird attribute of oil? I'm in Texas, so I have only seen it on a rare morning here...
  12. #162
    Georgia
    1,786
    Quote Originally Posted by mrmojo95 View Post
    I'd say its the correct temperature in that scenario. The engine would hold the cold from the night before and even though the ambient was now warmer it would read colder.
    The grounding offset issues take some driving time to show themselves.
  13. #163
    AAIIIC's Avatar
    Where the Navy takes me...
    6,447
    I figure it's just a bit of gauge inaccuracy. The oil temperature sending unit is optimized for measuring temperature well above freezing, whereas the external air temperature sending unit is optimized for measuring the typical range of air temperatures.
    A sump full of cold oil will warm slowly as the ambient temperature rises (so the oil temp will lag behind the air temp), but I've seen my oil temp indicating 3 or 4F lower than the air temp ever got. That's not a weird attribute of oil, that's just error in the indications.
  14. #164
    kevm14 is offline Cadillac Owners Connoisseur
    Automobile(s): 05 Stealth Gray CTS-V, 08 Light Platinum SRX V8, 05 White Diamond STS4 V8
    May 2008
    1,357
    You'd get a better feel for accuracy by comparing oil temp to coolant temp right at startup.
  15. #165
    Twitch's Avatar
    NYC
    46
    4,001
    Check this thread for reference: http://www.cadillacforums.com/forums...connector.html
    I noticed the plug was loose during my clutch install. Slid it back in, but with all the work going on I forgot to secure it . Anyways, my oil temp has not gone above 210 (usually around 235 with light driving) and I'm up at least .5V.
    Tony
